Excelsior "Brown Princeton" mod question
Discussion in 'Shock Brother's DIY Amps' started by TNO, Jun 19, 2013.
  1. TNO
    TNO Friend of Leo's
    Apr 25, 2003
    NC-USA
    Can anyone tell me which three resistors I need to change to do this?
  2. tubeswell
    tubeswell Tele-Afflicted
    Jul 1, 2008
    NZ
    Somebody's pulling your chain. I think you need to change more than 3 resistors.
  3. printer2
    May 24, 2010
    Depends on how far you want to go. Bad schematic so I take no responsibility if these are the wrong part numbers but you can change R5, R7 which are 220k plate resistors on the first two gain stages to 100k and R44 which is the cathode resistor on the first stage to 1.5k from 3.3k. The input resistors are 100k, might make the tone a little darker or not, 68k is normal for most amps.
    If you want variable tone rather than a switch you can change R5 and the switch to a 500k pot. That will get you most of the way there.
  4. TNO
    TNO Friend of Leo's
    Apr 25, 2003
    NC-USA
    Thanks printer2, I've already bumped up the coupling and bypass caps, removed the bypass cap fro the second stage and changed the 6v6 bypass cap to 22uF.
