Eventide Space or ..
Discussion in 'The Stomp Box' started by kupasa, Feb 21, 2012.
  1. kupasa
    kupasa Tele-Meister
    352
    Jun 10, 2011
    Murky northern forest
    I'm thinking about selling one or two of my guitars to upgrade my reverb. The t-rex tonebug reverb I'm using now is ok and has given me an appreciation for modern style reverb types but it's hissy and not so versatile.
    I've done some research and the Eventide Space seems to be just what I'm looking for.
    Is there any other reverb pedal I should consider?
    Presets is a must.
  2. flinx
    flinx Tele-Meister
    231
    Jul 4, 2010
    Mobile,Alabama
    The space has 100 presets...i can't think of anything close to that...i treasure my space...may not be for everybody but i sure have the bases covered when it comes to reverb.
  3. Twangasaurus
    Twangasaurus Tele-Afflicted
    Sep 26, 2010
    Perth
    I use a Stymon Bluesky and a Neunaber Stereo WET. It doesn't have the presets or the amount of control provided but the Space but the sounds are superior in my opinion. You also have analog dry through (if you care about that sort of thing).
    Think about what you want out of your reverb, are you going to be using several sounds in your music and will you need to switch between these sounds quickly? The Space is probably overkill for most people and they are sacrificing quality of sound for versatility they don't need.
  4. kupasa
    kupasa Tele-Meister
    352
    Jun 10, 2011
    I'm also impressed by this unit. It's a strong contender.
    It's a question of pedalboard real-estate mostly. As an old shoegazer the mangled reverb setting is a way to eliminate fuzz after reverb. Spring + tremolo is another example.
    Living in the middle of snowy-hell-nowhere I have few chances to actually a/b these stompboxes, especially the bluesky. So your impressions and thoughts are important to me.
  5. teleup
    teleup Tele-Holic
    993
    Apr 22, 2010
    between Milwaukee and Chicago
    the Neunaber WET is an excellent sounding reverb, nice and compact too!
  6. Twangasaurus
    Sep 26, 2010
    Perth
    Well if it's shoegaze then I change my opinion and so go for the Space! To be honest if your running the amount of effects that most shoegazers are then signal degradation is the least of your worries, this applies ten fold if your running heavy modulation and dirt. Cool thing about the Space is that you also get two reverbs in one (DualVerb) and a delay (ModEchoVerb) not to mention the amazingness of the Blackhole algorithm (which is get you sort of close to the Neunaber WET I believe). The only thing I wish it had was the ability to lower the bit rate of the reverb to get all those old school 16 bit rack reverb sounds. Makes the verb disperse really nicely and gives it lovely grit, one of my favorite examples of this is in Tears Run Rings stuff:
  7. kupasa
    kupasa Tele-Meister
    352
    Jun 10, 2011
    I'll go for the Space. I don't have that many effects these days. I sort of evolved(devolved?) from my shoegazing days into a Bill Frisell soundscape type of person, without the Bill Frisell type of talent I might add.
    I hope I'll be able to raise enough cash to buy the Space and E-H Freeze + JamMan Solo.
    Thank you all for great answers and great music.
  8. Green Lantern
    Green Lantern Tele-Afflicted
    Oct 10, 2010
    Southern California
    I use an Electro-Harmonix Cathedral Stereo Reverb. It has presets and sounds really good to my ears. It's also not nearly as expensive as the Eventide. I think it's worth looking into.
  9. redriding
    redriding Tele-Meister
    165
    Jan 20, 2012
    huddersfield uk
    I'd love to get Space!
    I had the mono neunaber wet but it wasn't really doing it for me.
    The shorter decay times sounded overly digital and the long decays sounded like they were added over the top of my core sound instead of blending with it (like a wash in the background) unless you set it 100% wet but thus resulted in a gigantic volume drop.it defo needed a tone control too which I believe has been added to the new stereo version.
  10. bossking7
    bossking7 Tele-Afflicted
    Sep 11, 2011
    Virginia
    +1
  11. mal paso
    mal paso Banned
    Nov 24, 2011
    Bloomington, IN
    Well, while I'm here..
    +1 for the Cathedral!
  12. tylermoss
    tylermoss TDPRI Member
    stereo wet, i played with one of my buddie's SPACE, it was cool, but way to much reverb to really use it. I just ordered my stereo wet, and might get a blue sky if i need more. the wet should be getting a shimmer option soon via software update, as well.
  13. misc1600
    misc1600 Tele-Meister
    185
    Mar 13, 2011
    Erie, CO
  14. Green Lantern
    Oct 10, 2010
    Southern California
    Actually, let me clarify what I said about the Cathedral having presets. It actually doesn't have factory presets, but it allows you to save your settings with 8 different types of reverb, so you can make your own and save them in the Cathedral's databank and switch to them easily. It's also easy to change your presets or not use them at all and just use the knobs to control your sound at that given moment. For the quality of sound, and the amount of features and reverbs it offers, I think the Cathedral is the best deal around for people who want more than just a basic spring reverb emulator. It's my personal opinion that, while they are of great quality, there are several other options that are either over-bloated, or ridiculously expensive for what they do, or both.
  15. mal paso
    mal paso Banned
    Nov 24, 2011
    Bloomington, IN
    +1 for Green Lantern
  16. kupasa
    kupasa Tele-Meister
    352
    Jun 10, 2011
    Ok green lantern and mal paso. You've convinced me. I'll go for the cathedral. It'll let me keep my strat. Thank you all again.
