Esquire pickguard for Bullet Tele?
Discussion in 'Squier Tele Forum' started by mnutz, Jul 10, 2017.
  1. mnutz
    mnutz Tele-Afflicted
    I'm thinking about grabbing one of the FSR Bullet teles for an Esquire project? Will any standard pickguard fit?
    Thanks!
  2. Ira7
    Ira7 Poster Extraordinaire
    Jan 8, 2008
    Coral Springs, FL
    Yep.
    Do you have anything planned for a new pickup?
    The only thing is, I think Esquires look weird with modern 6 saddles bridge.
  3. mnutz
    Thanks!
    Probably go with a Huge Lion for the pickup.
    Do the bridge plates not swap with no modifications? On my MIM standard it was a straight swap for a Fender branded 3 saddle bridge.
  4. rockymtnguitar
    rockymtnguitar Tele-Meister
    339
    Aug 30, 2012
    Colorado Springs, CO
    Wanting to do this too with a Lil59 that's been gathering dust for a long time.
    mnutz likes this.
  5. Ira7
    Jan 8, 2008
    Coral Springs, FL
    No mods swapping Modern 6 and Modern 3.
    Is your guitar string through or top-loader? If top loader, you may want to go nuts and do a Vintage bridge with ashtray cover.
    But either way, make sure you get the right bridge--string through or top loader. I don't think Fender itself makes a dual loader.
    (Note that I edited this post here.)
    mnutz likes this.
  6. mnutz
    This is my MIM Standard. The bridge I used was a direct bolt on, no mods required. It was $39.99 complete with saddles and sounds great. It was packaged as Fender Mr. Gearhead.
    Will it work on the Squier bullet teles?
    Thanks!
  7. Ira7
    Jan 8, 2008
    Coral Springs, FL
    Do you see how mnutz's bridge is for string-through body only?
    I gotta look and see if the Bullet is string through.
  8. Ira7
    Jan 8, 2008
    Coral Springs, FL
    Yep. It's string-through.
    Musician's Friend has it now for $149, but not available for two weeks.
    Keep in mind that Rondo always has a bunch of comparable quality Teles at around a hundred bucks. Yeah, no Fender or Squier logos or stamps, but for inexpensive project guitars like these, does it really matter?
  9. Ira7
    Jan 8, 2008
    Coral Springs, FL
    That looks like a vintage bridge, not modern.
  10. mnutz
    Yep that's what I'm after. Vintage style bridge.
  11. mnutz
    This is the unit I installed on my MIM Standard pictured above. Just wondering if this is also a direct bolt on for the Squier Bullet?
  12. Sollophonic
    Sollophonic Friend of Leo's
    It looks like it has got a modern string through bridge that is similar to the Squier Standard, which means that putting a vintage style bridge on these is not straightforward.
    It is a straight swap on the MIM Stds, but if it is like the Affinity string throughs and the Squier Stds a vintage bridge won't fit straight on unless you keep it a topload.
    The MIM Std bridges have mounting screw holes further forward, plus the string holes line up.
    The Squier Stds and other Squier Teles don't.
    mnutz likes this.
  13. Ira7
    Jan 8, 2008
    Coral Springs, FL
    I thought you wanted to go 6 saddles.
