Join TDPRI Today
Epiphone Emperor Regent
Discussion in 'Telecaster Discussion Forum' started by Jesse James, Feb 6, 2005.
  1. Jesse James
    Jesse James Tele-Meister
    164
    Jan 31, 2005
    Cimarron, Kansas
    Sorry this isn't about a tele, but I need some help. I just bought an Emperor Regent, and that thing feedbacks like crazy. What can I do to stop it? I have a jazz concert next weekend, and I don't want any issues. Thanks
  2. Joe-Bob
    Joe-Bob Poster Extraordinaire
    Sep 6, 2004
    Dallas, Texas
    I've played in a couple of different big jazz bands, and feedback has never been an issue. The volume has not been anywhere near high enough to be a problem. I sit off axis to my amp, it's about 4 feet behind and to my left.
  3. KokoTele
    KokoTele <img src="http://www.tdpri.com/gifs/vendor.png" /> Vendor Member
    albany, ny [not chicago]
    If it's feedback coming from the sound holes you can cover the holes with something or you can turn down. And now that I think of it more, changing your EQ might have some effect.
    There is always the possibility that you have a microphonic pickup or something causing the feedback as well.
  5. weelie
    weelie Friend of Leo's
    Stuff it well and quite tight with rags/foam/cotton wool/socks.
    In addition: tape the F-holes, damp the strings you are not playing, use EQ to cut feedback, put a damper between the pickup and body (or similar) etc.
    (That's what I've been told, anyway)
  6. stantheman
    stantheman Doctor of Teleocity
    Jun 10, 2003
    White Mountains
    Those Guitars (that style - floating Pickup) are really meant to be played unprocessed. The Guitar, The
    Cord, The Amplifier and that's "it". The "Top" on Boxes with floating pickups is usually thinner. An exception
    would be the Ibanez George Benson Model.
    Hey, it could be a Pickup malfunction too. If it's going through an Amp with everything set on "4" as I described above and it's still doing it have someone look
    at or replace the floater with one that works good. There are a bunch of "floating pickups" on the market.
    If You can afford one go for a "Rhythm Chief " by Deamond or a Kent Armstrong.
  7. SteveY
    SteveY Tele-Afflicted
    Mar 26, 2004
    Santa Cruz, CA
    When using that type of guitar I always had to keep my right arm damping the top, ESPECIALLY with the amp behind me!
    If I let go it would go "wwwWWWOOoooOONK!"
    Then, as the leader turned around to see what was going on, I'd scowl at the bass player! ;)
  8. Jesse James
    164
    Jan 31, 2005
    Cimarron, Kansas
    Thanks
    Thanks for all the advice, guys. I'll do some experimenting tomorrow at rehearsal. Later
  9. jimmymackisback
    jimmymackisback TDPRI Member
    58
    Jul 30, 2004
    New York City
    Remedies
    That style of guitar will always feed back at higher volumes. The feedback is dependent on a few things: volume, proximity to the amp, direction of the amp and volume relative to the former.
    It is not the quality of the pickup, it is the resonance of the guitar body and the sound waves reinforcing the vibrations of strings and the top of the guitar.
    Your quickest solution, and least painful, is to stuff the guitar with rags or foam, and thereby cut down on the internal resonance. I played for years that way, and very loudly. You can move the amp to your side and point the speaker away from you, but you don't always have that option, and you want to be comfortable while performing, which means hearing yourself closely.
    Start stuffing. Start out with a minimum, experiment, and keep adding until you have it. Careful of the internal wiring. You will sacrifice some of the "acoustic" tone, but once you have it packed, you can concentrate on your performance. Good luck.
