Easy Leslie Effect For Guitar Discovered...
Discussion in 'Burnt Fingers DIY Effects' started by GoldDeluxe5E3, Aug 25, 2017.
Tags:
  1. GoldDeluxe5E3
    GoldDeluxe5E3 Tele-Holic
    Concord, California
    Last night I was playing around with my Fender Champion 20. I'd bought the amp for portability and to have a counterpoint to my 5e3.
    I use several pedals with the Tweed Deluxe, among them a Joyo tremolo. I'd forgotten I'd plugged into the Champion through the pedal set, and at one point, I had the Champion's on-board tremolo effect working at the same time as I had the Joyo engaged.
    To my surprise, the two trem effects cycled through a pattern where they augmented each other, diminished each other, and finally cancelled each other out - and around and around again. It sounded alot like a leslie speeding up and slowing down! EUREKA!
  2. JuneauMike
    JuneauMike Friend of Leo's
    Alaska
    Never thought to do that. Brilliant.
    GoldDeluxe5E3 likes this.
  3. GoldDeluxe5E3
    Concord, California
    I learned that the closer you match the cycle rates between the two trems, the longer the leslie cycle rate. It's fidgedy, but once you've got it dialed in, it's on tap when you're ready to use it.
  4. tubejockey
    tubejockey Tele-Meister
    the bozone
    Even better, use a subtle pitch shift in sync with tremolo.
  5. GoldDeluxe5E3
    Concord, California
    Great. My Champion 20 has vibrato as well as tremolo. May be the next big discovery. (I use the term "big" loosely.)
  6. brookdalebill
    Austin, Tx
    I have used chorus and tremelo together for a groovy Leslie effect.
    It is not as versatile perhaps as your rig.
    I have had good luck varying tremelo speed and chorus intensity.
  7. JD0x0
    JD0x0 Poster Extraordinaire
    New York
    I just use a rotating speaker :eek:
    BBill64 likes this.
  8. bsman
    bsman Tele-Afflicted
    Santa Clara
    This is what I was expecting:
    kafka, RodeoTex, fatcat and 2 others like this.
  9. radiocaster
    radiocaster Friend of Leo's
    europe
    Would be better to put the amp on a turntable.
    paparoof and GoldDeluxe5E3 like this.
  10. Ira7
    Ira7 Doctor of Teleocity
    Coral Springs, FL
    Oh my God:
    I am all over testing this idea tomorrow! I got a Behringer Ultra Tremelo pedal, and maybe now I won't feel so stupid about buying it!
    Cause I got onboard Trem on my X2 head, but I hate tap tempo.
  11. GoldDeluxe5E3
    Concord, California
    Same tap tempo system on my champion too. It's easiest to approximate the trem speed on the tap tempo first, and then dial in and fine tune the pedal trem speed second to control the leslie cycle rate.
  12. Deeve
    Deeve Friend of Leo's Silver Supporter
    Ballard
    Yup; I'm a fan of this method too.
  13. homesick345
    Beirut, Lebanon
    You're kidding, but Lonnie Mack used that trick
  14. ICTRock
    ICTRock Tele-Afflicted
    Tampa,FL
    lovetone wobulator ... just sayin
  15. memorex
    memorex Friend of Leo's
    Chicago
    Mount this under your speaker, throw in a treat when you want to change speeds:
    Anode100 and GoldDeluxe5E3 like this.
  16. BigDaddyLH
    Kelowna, BC, Canuckistan
    One day, someone is going to buy a used Leslie cab, open it up ... and see this!
  17. Endless Mike
    Endless Mike Friend of Leo's
    Arlington, Texas
    I suppose it depends on what you're wanting to hear. Few things, including some actual leslie simulators, don't provide the swirly midrange shifting that is the hallmark of the leslie sound.
  18. Iago
    Iago Friend of Leo's
    Brazil
    I've tried vibe and tremolo together and it sounded really pretty. Still have to try 2 trems one day.
  19. telemnemonics
    Half of us just want to get our guitars to play in tune, while the other half seems to want to screw it up!
    How about two amps with different rates?
  20. xafinity
    xafinity Friend of Leo's
    my Mom's basement
    I'm still trying to find Fb
