Earthquaker Devices Dispatch Master?
Discussion in 'The Stomp Box' started by doveman, Nov 24, 2011.
  1. doveman
    doveman Tele-Meister
    454
    Jul 4, 2006
    I'm considering getting one of these Reverb & Delay devices for a simple grab & go board. Anybody tried one?
    I would not want to run it as "wet" as any of the demos I've seen. Looking for something I can run a bit of delay out in front of an amp with a bit of hair to giver a bit of ambience. But at the same has the ability to add a bit of reverb in a dead room or at home practicing.
    Thanks in advance ...
  2. JesterR
    JesterR Tele-Afflicted
    Jul 8, 2009
    Russia, St.-Petersburg
    Maybe mxr CC? Does not have reverb, but it's sound is so warm and organic. Great for add some ambiance.
  3. doveman
    454
    Jul 4, 2006
    Would like to have both RV & DL ... I actually have a Hardwire RV-7 (Reverb) & DL-8 (Delay/Looper) that do a decent job, but both together have a large footprint. Liked the idea of both in this small footprint.
    The "Dispatch Master" must be pretty new ... seeing very little about it in the searches. Anybody ... anyone seen one of these?
  4. lareplus
    lareplus Tele-Afflicted
    Mar 9, 2010
    tucson, az
    It is a dreamy sounding delay, from what the demos show. I wish there were demos focusing more on the reverb side of the pedal. I am more interested in a reverb with delay than delay with reverb.
  5. doveman
    454
    Jul 4, 2006
    The more I think about it and play with the Hardwire RV-7 and DL-8, the better I think these guys sound. I know it's hard to compare using Youtube clips ... but these sound pretty good. I might be OK with what I already have now.
    When I'm running through my "Richter Tweed", I use this set up on the Pedaltrain Mini. When I take the Brown Note, I run the two Hardwires and the Pitchblack tuner in the loop on the smaller Pedaltrain Nano since I don't need any boosters with that amp.
    Can anybody directly compare either the "Dispatch Master" or the "Deep Blue Delay" to these pedals ... specifically the DL-8.
  6. doveman
    454
    Jul 4, 2006
    Nothing like mentioning you might like your old gear to stop a thread dead in it's tracks. I did pull the trigger on the EQD Dispatch Master. My thought is to load it up on this MINI board ... replacing the two pedals to the left with the one. This will give me room for one more OD flavor (EP or 1/2 Gainer). I'll then move the two Hardwire pedals to the NANO board and run it in the loop with the Brown Note. Might pick up another tuner and have a dedicated board for each amp. I'll report on how it goes ... thanks for the feedback.
  7. doveman
    454
    Jul 4, 2006
    EQD Dispatch Master came today. I like it with the controls turned down. Can get both reverb and delay out of the same pedal. Don't detect it's any better than the Hardwire RV-7 and DL-8 pedals (less flexible since it's simple) but it seems to do a good job. I like the basic sound of both the reverb and the delay. So I think it is a good choice and a much smaller footprint.
  8. lareplus
    Mar 9, 2010
    tucson, az
    How do you like the reverb alone? I am interested in this as a reverb pedal but like the dreamy combination of echo with reverb, however it's got to have great reverb because that would be my main use of the pedal.
    What do you think? Would this be a good reverb pedal if it didn't even have a delay aspect???
  9. doveman
    454
    Jul 4, 2006
    Yes ... it sounds like a good "plate" reverb to me. Not a "spring" reverb. I will probably run it between 9:00-11:00 with the mix at about 9:00-10:00. You can get it to "bounce" a little in reverb only mode by turning up the repeats but I wouldn't. If you drop in a little short delay and back off the reverb it gives the feel of a medium sized room that you might gig at ... say all the controls a bit over 9:00. I never saw anyone run it that way in any of the videos ... just cranked it up over 12:00 or dimed ... useless settings for what I need.
    I especially like the small footprint ... about 75% of just one of the two Hardwire pedals I've been using.
  10. Bertymoe
    Bertymoe TDPRI Member
    19
    Nov 24, 2009
    Got one recently.Love it...Very small footprint... I run the reverb at 9 o'clock..Mix around 9 or 10 o'clock. then I play with the delay time....or just turn it to zero to run reverb only.ONLY problem ..minor ...the delay time setting is very 'touchy" a small move of the dial will change the time quite a bit.Just a matter of getting used to.It will replace 2 delays on my board.
    I consider it a real keeper.
  11. Tarnisher
    Tarnisher Friend of Leo's
    Apr 12, 2008
    Brooklyn
    My Mooer Shimverb has convinced me of two things:
    1. I need reverb.
    2. I need a better reverb than the Shimverb.
    I'm trying to keep my board small, so the idea of combining delay and reverb is very appealing. Anyone have any new thoughts on the Dispatch Master?
