Dusty Hill Style T-bass
Discussion in 'Tele Home Depot' started by The Crash Cowboy, Apr 4, 2019.
  1. perttime
    perttime Tele-Afflicted
    Finland
    Not so tight you'll split the wood, I hope.
    The Crash Cowboy likes this.
  2. The Crash Cowboy
    The Crash Cowboy Tele-Meister
    The Netherlands
    No, that’s ok.
  3. The Crash Cowboy
    The Netherlands
    Neck mounting screw holes:
    Ekko likes this.
  4. The Crash Cowboy
    The Netherlands
    Another moment of truth ! :)
    For some strange reason the depth of both cavities is wrong. The pickup cavity is way too deep, and the neck pocket isn’t deep enough.
    I found the depths for both on the internet:
    - Neck pocket 5/8’’ = 15,875 (16) mm.
    - Pickup cavity 3/4 ‘’ = 19,05 (19) mm.
    My routing wasn’t very accurate: the neck cavity depth is 14,9 mm, and the pickup cavity is 20,3 mm. Both are around 1 mm off.
    If I put a string on it, it looks like deepening the neck pocket just 1 mm is way too little. And the pickup cavity looks way much deeper than the 1 mm difference I measure. Well, nothing I can’t fix: I need to route the neck cavity a little deeper, and I made a patch to put into the pickup hole.
    Anyone know the exact right depths ? Especially that of the neck pocket ?
    Patch installed:
    Depth of the pickup hole without the patch:
    Neck pocket depth:
    String height is nihil. I already raised the saddle height.
    Ekko likes this.
  5. crazydave911
    East Tennessee
    I hope this all comes out fine, being as you're here I have no doubt about that.I just wanted to thank you for building what I consider the most beautiful bass ever made.Heck,even inspired my strat bass (build thread promised). It's a little shorter,a little smaller and has a single humbucker instead of a single coil but mostly resembles one of these slightly shrunk in the wash lol. Looking forward to the finished article ;)
  6. The Crash Cowboy
    The Netherlands
    Thanks ! I'm no bass player myself (I play guitars), I build this for a friend who is. When we were deciding about what kind of bass it should be, there only was one option for both of us: it had to be a Dusty Hill signature lookalike. I agree on you that that's the most beautiful bass even made: the sheer simplicity of it is breathtaking, IMHO. It's all a bass needs: neck, pup, body, volume, tone (though we even have considered leaving out the latter). The Fender production model just has two disadvantages: the exorbitant price, and the fact that it's reliced ...
    My friend even thinks about finding a reversed headstock neck now, LOL !
    kodiakblair likes this.
  7. The Crash Cowboy
    The Netherlands
    I routed the neck pocket 2 mm deeper, and it seems that’s all she needs. Ofcourse I have to clamp the neck tight to judge that better. The bridge is high up now, so maybe the pocket needs a little more routing.
    I compared the height of the neck over the body to my Squier bass; that was 1,5 mm deeper in the pocket.
    Alignment is fine !
    brookdalebill and Ekko like this.
  8. perttime
    Finland
    Have you checked that the neck pocket is straight and not angled?
    My first instinct would be to get the neck pocket where you don't have to have the bridge all the way up. Don't take my word for it, though. Let's see if someone who actually knows something chimes in.
  9. jimilee
    jimilee Tele-Holic Silver Supporter
    Chattanooga
    Heck yeah! Looks great. Looks like you’re in the building phase home stretch.
    Just judging by the string height, the bridge will be adjusted down anyway.
  10. The Crash Cowboy
    The Netherlands
    It’s straight. To judge the fit I’ll clamp it down later.
  11. The Crash Cowboy
    The Netherlands
    There were some old screw holes in the neck heel. I drilled them out and doweled them.
    Ekko likes this.
  12. The Crash Cowboy
    The Netherlands
    As far as I can see, all the necessary holes are drilled now. I am going to take it all apart, and I’ll apply one last layer of Z-Poxy with a little added accohol to the wood. After drying, I’ll sand it very lightly, and I guess we’re ready for paint then !
    nnieman, Ekko, brookdalebill and 2 others like this.
  13. TRexF16
    Tucson
    Just to be sure, you are going to wait to install the ferrules until after the finish is complete, right? That's the normal path.
    Also, rather than hammer them in, try pressing them in using your soldering iron to heat them up just a bit. That causes both the finish and the wood fibers to soften just a bit an let the ferrule slip in easier. Don't let them get too hot though or you can bubble your finish.
    Cheers,
    Rex
  14. The Crash Cowboy
    The Netherlands
    Thanks again ! I’ll assemble the guitar after the finish work is all done.
    I applied the last layer of epoxy/alcohol with a clean cloth.
    After the last layer of filler and sanding, do I need to clean the wood before applying the nitro ?
    Ekko likes this.
  15. The Crash Cowboy
    The Netherlands
    I cutted a piece of foam (from the pickup package) to put under the pickup, to get the right height and to stabilize it a little.
    crazydave911 and Ekko like this.
  16. TRexF16
    Tucson
    If you had posted this picture without any of the previous posts about how you fixed that drill bit blow through, and not said a word about it, I don't think anyone would have noticed the repair. It just looks great! Be proud!
    Rex
    jimilee, kodiakblair, Ekko and 2 others like this.
  17. Dangerous Dirk
    Dangerous Dirk TDPRI Member
    Austin
    You are not kidding!!!! Just awesome.
  18. The Crash Cowboy
    The Netherlands
    I sprayed the nitro on the body. My first nitro finish job ever ! We chose this colour: transparent butterscotch blonde. I like the result ! Tomorrow I’ll spray some clear coats.
    First I sanded the Z-Poxy smooth with 1000 grit. I started spraying outside, but there was too much dust in the air, so I went inside. And yeah, I wore a mask !
    First image is the original Dusty Hill Signature.
    I masked the control cavity and the neck pocket.
    My spray stand.
    Before spraying, I warmed the rattle can in hot water, to get a finer spray.
    Layer 1.
    Layer 2.
    Ekko likes this.
  19. The Crash Cowboy
    The Netherlands
    Layer 3.
    Layer 4.
    Layer 5.
    The pores aren’t filled completely, but I can live with it.
