Dusty Hill Style T-bass
Discussion in 'Tele Home Depot' started by The Crash Cowboy, Apr 4, 2019.
  1. perttime
    perttime Tele-Afflicted
    Finland
    The straight grain looks nice. A bit like the top of an acoustic guitar. Maybe stain or tint it. Let the world see it.
    tintag27 and The Crash Cowboy like this.
  2. Treadplatedual
    Treadplatedual Tele-Meister
    Indianapolis, IN
    Every build I've made, there's a flub somewhere. Some you can see, some you can't - keeps me humble :)
    Also, there's a lot of charm in knowing it was hand made, not made "perfect" by a computer.
  3. E5RSY
    E5RSY Poster Extraordinaire
    Georgetown, TX
    Very nice.
    The Crash Cowboy likes this.
  4. The Crash Cowboy
    The Crash Cowboy Tele-Meister
    The Netherlands
    I routed the neck pocket to the final depth: 0.652’’ or 16,5 mm. It fits tight !
  5. The Crash Cowboy
    The Netherlands
    I want to use a transparent (poly-urethan or nitro ?) lacquer as a finish. Do I need some kind of filler to treat the wood first, with a sanding sealer or something like that ? Or will some layers of lacquer, and sanding with different grits after each layer, do ?
    DonM and Ekko like this.
  6. The Crash Cowboy
    The Netherlands
    I guess this’ll do: Z Poxy Resin Filler. Any thoughts ?
  7. RickyRicardo
    RickyRicardo Friend of Leo's
    Calgary, Alberta
    That's the stuff. I use drywall putty that I darken with a deep brown dye.
    Edit: Seal it first then fill it.
  8. perttime
    Finland
    If you want it smooth, then I guess you should fill it. Some like it when you can see and feel the minor irregularities of wood. Some don't.
    cjp60, The Crash Cowboy and Jim622 like this.
  9. The Crash Cowboy
    The Netherlands
    Z Poxy does both, I heard.
  10. The Crash Cowboy
    The Netherlands
    My mate has made up his mind and decided: the colour will be Butterscotch Blonde Transparent. As close to the Dusty Hill Signature as possible. We only don’t like artificial reliced guitars, so he’s just gonna play the hell out of it to give it that road-worn look, LOL. It will be a brand new looking body, I hope.
    So: seal & fill with Z-Poxy Resin PT-41, and finish it with nitro Butterscotch Blonde. Maybe I have to add a full transparent layer to polish it to a beautiful shine.
    But first I have to route the controls cavity in the back, and sand that side too.
  11. The Crash Cowboy
    The Netherlands
    I routed the control knob cavity in the back, and made a cover for it.
    First I routed the cavity.
    The edge for the cover. I had to make a new template for that, with a better shape than the cavity.
  12. The Crash Cowboy
    The Netherlands
    The cover:
    Treadplatedual, Ekko and Arch Stanton like this.
  13. The Crash Cowboy
    The Netherlands
    ... and sanding again ... and sanding ... and ..
    And after all that work, this is the only thing you’ll see at the front:
  14. crazydave911
    East Tennessee
    I have to say I find that wood fascinating. Despite being so soft it has ribbons like mahogany. Me I would likely custom stain it with my hand mixed shellac,use the Z poxy and shoot clear to let that beauty shine for the ages
  15. The Crash Cowboy
    The Netherlands
    It’s nice wood to work with, considering this is my first wood body ever.
    About the colour: my mate wants to go as close as possible to the Dusty Hill style bass look. I hope the stain will be visible trough the butterscotch lacquer; it’s transparent.
  16. The Crash Cowboy
    The Netherlands
    Volume & tone pots mockup installed. I had to route the cavity deeper. I’m glad the cover edge is well shaped ! ;-)
    I like the basic look a lot.
  17. The Crash Cowboy
    The Netherlands
    The results of today. I noticed after finishing that the controls on the original DH Signature are located much higher on the body; I used the template of a regular ‘51 P-bass to locate the knobs on mine. I never realised the difference ... Well ... I can live with it.
  18. The Crash Cowboy
    The Netherlands
    Do you think applying a layer (or more) of some oil (Tru Oil) to the wood before spraying the butterscotch nitro will brighten the grain more than just nitro ? I already found that nitro can go over Tru Oil.
    And if so, do I use the Z-Poxy before or after applying the oil ?
  19. The Crash Cowboy
    The Netherlands
    The neck fits very tight in the neckpocket. There’s no movement at all to the right or left.
    When I align the neck, there’s a difference in alignment of about 1 or 1,5 mm at the bridge, compared to the centerline.
    What would you do ? Mount the bridge in alignment with the neck as it fits now, or give the neck a little space in the pocket and align it spot on to the centerline ?
  20. crisscrosscrash
    crisscrosscrash Tele-Meister
    Montreal
    I'd mount the bridge in line with the neck as is if the fit is good and it's only 1.5 mm out - I don't think anyone will ever know!
    Looks great so far.
