Dusty Hill Style T-bass
Discussion in 'Tele Home Depot' started by The Crash Cowboy, Apr 4, 2019.
  1. The Crash Cowboy
    The Crash Cowboy Tele-Meister
    The Netherlands
    A friend bought a second hand Allparts Tele bass neck. He asked me to build a body to it, using the (ridiculously expensive) Fender Custom Shop Dusty Hill Signature Precision as an example. So I started the works. My friend bought a piece of abachi wood.
    The Dusty Hill Signature. Back to the basics.
    Template.
    One piece abachi wood.
    Bandsaw.
  2. The Crash Cowboy
    The Netherlands
    Routing the body with the MDF template.
    The body is almost 60 mm deep and my biggest router bit only 38 mm. It needs two passes.
    A chip broke away, but I repaired it.
  3. The Crash Cowboy
    The Netherlands
    Pickup cavity. After bringing the body to it’s final thickness (40 mm) the cavities will be deeper. For now it gives me a reference when the template is removed.
    The control knob cavity will be routed at the back later.
    Routing the neck pocket.
    Neck alignment jig.
    I routed the lower parts of the sides, using the already routed upper part as a reference. First I had to remove the template, to allow the router to go deep enough.
    As you can see, I used the ‘masking tape & superglue trick’ to hold the template on the body.
    Tommy Biggs, richiek65, DonM and 3 others like this.
  4. The Crash Cowboy
    The Netherlands
    I did some sanding on the sides, to see how they will look. I’m happy so far !
    I deepened the cavities some more. Tomorrow we will make the final thickness of the body using a machine thicknesser. After that I can route the cavities to the right and final depth.
  5. Mike SS
    Mike SS Poster Extraordinaire
    Nebraska
    I envy all you woodworking gents. The bass will be awesome.
    MattMrdck and The Crash Cowboy like this.
  6. The Crash Cowboy
    The Netherlands
    This is my first ever wood body :)
    I did build some steel bodies a few years ago.
    Tommy Biggs and Treadplatedual like this.
  7. nojazzhere
    Foat Wuth, Texas
    This is incredible......please post pictures of the final results!!!!!
    The Crash Cowboy likes this.
  8. RickyRicardo
    RickyRicardo Friend of Leo's
    Calgary, Alberta
    I was worried about tear out in the lower bout since you left a lot of material in there. Since it's your first I recommend you cut and/or sand as close to the line as possible before routing. Chances of tear out are greatly reduced. I've never heard of abachi. I'll have to look that one up.
    I really like your steel ones. Very cool.
    Nice job and recovery.
  9. The Crash Cowboy
    The Netherlands
    I did sand it down almost to the line. Abachi tears out even by looking at it !
  10. perttime
    perttime Tele-Afflicted
    Finland
    The Wood Database says:
    Generally easy to work, though the interlocked grain can cause some rough surfaces in some machining operations. Carves, stains, glues, and finishes well.
    and
    This African hardwood is very soft and lightweight, but has a decent strength-to-weight ratio. It’s fairly stable in service, and its bland grain patterns are frequently stained a darker color.
    https://www.wood-database.com/obeche/
  11. The Crash Cowboy
    The Netherlands
    We put the body trough a machine thicknesser/planer. The depth is 40 mm now, instead of 52 mm.
    I have to be very careful from now to avoid damaging the wood. This is the final shape, except from sanding the wood and rounding the edges, and routing the cavities.
    Oops ... router mistake.
    Tommy Biggs, DonM and Ekko like this.
  12. Chunkocaster
    Chunkocaster Friend of Leo's
    In space with Ziggy
    Looking good, when does the fur go on?:);)
    tintag27, DonM, soul-o and 1 other person like this.
  13. The Crash Cowboy
    The Netherlands
    That depends on what my friend wants as a fur/finish. He’s not decided yet ... Just transparent ? Colour stain ? Oil ? Nitro ? Let us know ! And keep the Dusty Hill look in your minds ... and the fact that I never finished wood in my 60 y lifetime. I’m a finish rookie.
    To consider: the abachi wood is very soft and sensitive to damage from outside. C’mon ! Advise us !
    Chunkocaster likes this.
  14. The Crash Cowboy
    The Netherlands
    If you ever need a reason:
    MattMrdck, RLee77, wetterhorn and 4 others like this.
  15. E5RSY
    E5RSY Poster Extraordinaire
    Georgetown, TX
  16. The Crash Cowboy
    The Netherlands
    I rounded the sides and sanded the top to 240 grit. I start liking the grain !
    GearHund, Ekko and pepperfox like this.
  17. pepperfox
    pepperfox TDPRI Member
    Dallas, TX
    Love the router tear out repair. Great recovery! The neck pocket one is a trickier, but a little finesse sanding could probably blend it in. Then you could modify your neck heel contour to match if you wanted.
  18. The Crash Cowboy
    The Netherlands
    Well, there’s no disadvantage in playability and construction. I’ll sand it a little and leave it like this. It’s a mistake, but hey, it’s my first wood body.
    E5RSY and pepperfox like this.
  19. pepperfox
    Dallas, TX
    My first wood body got burned in a fire bit :lol: You'll probably be the only one to notice it. Keep posting updates!
  20. E5RSY
    Georgetown, TX
    Don't sweat router mistakes that aren't readily apparent...see that Strat in my avatar to the left. Zoom in on it and look at that neck pocket. :D And, that's no cheap Strat. It's an American-made '57 re-issue. Hasn't bothered me a bit over the years (since 1991). If I were buying it today I probably would have caught it and picked another one, but back then I was happily clueless about such things.
    Ekko and The Crash Cowboy like this.
