Duplicolor metallic - ok to sand the color coat?
Discussion in 'Finely Finished' started by waygorked, Dec 2, 2012.
  1. waygorked
    waygorked TDPRI Member
    48
    Nov 9, 2009
    I'm finally getting to finish a Jazzmaster body I've been working on for some time. I found a rattle can Duplicolor blue metallic, apparently a Honda color, that makes for a pretty reasonable faded ice blue metallic. I put down some color today, andwas on the verge of a nasty sag. I flipped the body sideways and clamped it to a shelf for a few minutes to let it dry a bit rather than risk a big run. This worked, but I picked up some specks of crud as a result. And unlike the Reranch nitroI have used in the past, apparently you can't just pick the specks out of acrylic lacquer.
    As it looks like I will need to lightly sand the color coat, can I expect that I will need to lay down some more color? I'd really like to be able to finish this over the next day or 2 (good weather forecast. if I need to put on more color, I won't be able to get to clear before the weather gets too humid again.
    I am much more about the color than the metallic flecks, FWIW.
  2. FingerMullet
    FingerMullet TDPRI Member
    81
    Aug 4, 2008
    Southwest, Fl
    Go to reranch and read about shooting metallic. Very good pointers. Wish I would have read it before I started mine. Can't rush it ! If you sand it, you will not like the results. After it drys, build up two or three coats of clear coat and lightly sand the last one. Then spray the final clear coat. PS, If you have to sand the crud, reshoot the metallic
  3. wired to go
    wired to go Tele-Meister
    371
    Aug 22, 2010
    Bridgeport,NY
    My experience with automotive paint tells me if you sand metalic paint you will have to recoat. You can colorsand it , But as far as a sag, You will raise the metalic giving you an uneven metalic.
  4. oramac7891
    oramac7891 Friend of Leo's
    Sep 10, 2009
    I would not suggest sanding the color coat, it won't turn out well
  5. MichaelAa
    MichaelAa Tele-Holic
    928
    Jun 9, 2012
    Norway
    No, I don`t think you should sand it. Btw, I just finished a guitar the other day, using a dupli color ice blue metallic-ish as well. But I shot some tinted nitro over it, so it`s more green now. Turned out pretty nice.
  6. waygorked
    48
    Nov 9, 2009
    I know! I saw yours, and it looks great!
    So last night I did a touch up with my remaining color. I managed to get it all looking proper, when as a parting shot my last drop of paint decided to give me a small spatter on one of the horns.
    Can I expect this to melt at all with the application of Duplicolor acrylic lacquer clear, or an I stuck with it?
  7. Peltogyne
    Peltogyne Tele-Afflicted
    Oct 29, 2012
    Northern California
    I'm not an expert with finishing by a long shot but I have been playing with Duplicolor metallics lately. I had to fix something in a color coat and sanded it and it looked horrible. I needed to spray a few light coats to get the flake to look good again.
    Also I watched a bunch of duplicolor videos online and they seem to think it's fine to spray many coats a day with just 15 minutes or so between them. So when I resprayed the headstock after a decal disaster required me to sand it clean again I sprayed primer, color and clear on the same day and it looks great and is hardening nicely.
