Duncan Broadcaster...why not Alnico III
Discussion in 'Just Pickups' started by GuitarJonz, Dec 21, 2008.
  1. GuitarJonz
    GuitarJonz Poster Extraordinaire
    MA
    Just curious...didn't early blackguard Broadcasters use Alnico 3 magnets? I believe that the SD Broadcaster uses Alnico 5, why didn't he use A3? Availability, cost??
  2. Darrell
    Darrell Friend of Leo's
    Houston, Texas
    probably because
    Fender uses Alnico III on their Nocaster/Broadcaster equivalent offering.
    (To be different)
  3. boris bubbanov
    New Orleans, LA + in the
    Mr. Duncan DOES use a lot of alnico 2 and alnico 5 doesn't he?
    I don't think it is cost or availability; although I can imagine in the next few months and years with commodity prices having jumped up and down that there may be some switching to whichever slugs can be found cheaper right now, today, especially lower down the chain. For the same reason I'm using regular gas as its price plunges down ahead of the prices of stale premium gas.
    I think it is Personal Preference. Seymour Duncan likes what he likes, and if he's of the belief he can get to a Broadcaster by way of Alnico 5 slugs, I will not naysay.
  4. Don Mare
    Don Mare Tele-Afflicted
    CA.
    The main thing about AlNiCo is just Gauss - the metals / materials used in the different grades will create different "loads" "inductance " - you can add or remove winds and add the same "load" - so it boils down to Gauss = Strengths
    A possible reason Duncan uses II's is because the old A-3 would gauss up to 750
    and todays A-2 hits 750 gauss - while todays A-3 only hits 650 -
    I have learned to Magnetize my A-3's with the Copper coated Steel Base Plate attached to the pickup - only then do I see the gauss near 700 to 750..
    Also a slightly degaussed A-2 would end up like Fully gaussed A-3
  5. Mitch Roberts
    Mitch Roberts Tele-Holic
    CT
    Good insight, Don. Thanks for that. I, too, have noticed that Duncan doesn't appear to ever use A3. I have concluded (possibly wrongly) that is why I have never really liked any of the MANY Duncans I have tried. I find myself gravitating to pickups that have A3 magnets. I just never "warmed" up to an A5 based pickup for some reason. However, I don't think I have ever heard an A2 based pickup, but would like to, especially based on what Don has told us.
  6. old_picker
    old_picker Tele-Afflicted
    Melbourne Australia
    during the definitive blackguard [broadcaster / nocaster/early tele/ esquire] era leo fender used Alnico 5 for bridge and alnico 3 for neck pickups - according to the blackguard book =- also corroborated by duchossoir
  7. Don Mare
    CA.
    Read that too. but every Blackgaurd from 50 to 54 Bridge sent here for repairs ->so far has been A 3's - an so were the necks too ( A-3).
    also Fred Stuart and Alan Hamel also
    noticed A-3s were on these years too
  8. yegbert
    yegbert Poster Extraordinaire
    Maryland (US)
    The only info I see in the Duchossoir book about the AlNiCo grade is in the specifications in the tables on page 62, and that reflects AlNiCo V for the bridge and neck single coils.
    I don't have a copy of the Blackguard book, but from the buzz here when that was coming out I thought the recent research had led many to believe that AlNiCo III was used in the early '50s, and in the mid '50s Fender began using AlNiCo V.
  9. Zhangliqun
    Zhangliqun Tele-Meister
    Los Angeles
    Went to the factory on User Group Day a few years back and Seymour said that via charging to different levels he can get whatever he wants out of just A2 and A5. Rarely uses anything else. He put out a Forum special pickup with Alnico 8 a few months back and I think his lipstick Dano pu uses Alnico 6, but other than that, he's totally faithful to A2 and A5.
  10. rhh7
    rhh7 Tele-Afflicted
    Calgary, Canada
    Well, I had my J S Moore custom pickups wound to duplicate the Broadcaster, and he used 43 gauge wire, Alnico III magnets, and 7800 wraps. I think they wound up 7.2k ohms neck, and 7.3k ohms bridge.
  11. DMace
    DMace Friend of Leo's
    Brooklyn, NY
    7800 wraps...man, you sure have to be a patient person to wind pickups. I'd go nuts.
  12. 11 Gauge
    11 Gauge Doctor of Teleocity
    Near BWI Int'l
    That says it all right there - Duncan can achieve the same thing with different magnets. If Jerry Donahue, Brent Mason, and countless others find the II and V acceptable at a bare minimum, SD must have figured this one out.
    One also tends to forget that Leo used whatever was plentiful and cheap - as long as III met those criteria, it was used. It's obvious that Duncan didn't want to chase a specter that was based on economical principles and not tonal ones.
    I'd be willing to bet that if you optimized the gauss that DM suggested, as well as other critical design factors, that you'd never be able to tell the difference in a double blind. So why do others use III? Probably to make the most accurate replicas possible, even if there's no audible advantage. Even DM has admitted that with modern III you have to futz with the magnet processing to make it match the early stuff, so there's still a physical difference even with (new) III.
    The best part is that if the Duncan V or II only thing doesn't float your boat, you can run with any of the III's that are currently offered by others.
  13. mellecaster
    mellecaster Former Member
    Desperadoville..USA
    I sure wish I had "Dog Ears" like some of you Guys...well as I rethink it, Maybe not......;)
  14. sapi
    sapi Tele-Meister
    Malta
    So what we are saying is basically that an A2 and an A5 at 750 gauss would sound the same in the same pu. Or am i getting it wrong?
  15. 11 Gauge
    Near BWI Int'l
    I actually am intrigued by Scott at Harmonic Design's viewpoint of AII:
    What do Alnico II magnets do to the guitar's sound?
    If you want to 'compress' your sound, Alnico II magnets are the natural way to go. The output will be quite low, but very flat and smooth, and sustain longer. Players either love or hate this sound, depending on how much they like the 'spank', 'pop' or 'dynamic range' of single coil pickups to begin with.
    You will find the compression effect so strong that they don't get much louder, no matter how hard you play, even if you really sock them strings.
    While I've designed and built Alnico II pickups in the past, I think it's more of an 'Anti-Fender' tone, and I've used them mostly on active, pre-amped guitars where there are several electronic benefits from the compressed, lower-output tone. They were used by Fender for these reasons on their 'active' Strats and Teles during the 80's, but keep in mind the active electronics in these guitars restored the dynamic range.
    It kinda makes me wonder where AIII fits into the whole scenario. I have my own thoughts, but feel that they're kinda subjective, so I won't subject anyone else to them (no pun intended).
  16. teleftcaster
    teleftcaster Tele-Meister
    Oklahoma
    I love the tone of my SD Broadcaster. Whatever reasons for the choices he made, I think Mr. Duncan made a great, vintage sounding pickup.
  17. champtone
    champtone TDPRI Member
    Saratoga Springs
    Interesting stuff regarding Alnico magnets guys! Can anyone else comment on the sound of the SD Broadcaster pickup?
    I have a '04 Mex Esquire that I'm trying to sweeten up (by replacing the PU amongst other things) and the SD Broadcaster was one PU I'm considering. Going for a period correct vibe with this guitar.
    Thx-
  18. mellecaster
    Desperadoville..USA
    You could do a lot worst...the SD Broadcaster and Fender's Original Vintage 52 are two of my favs, for capturing the Traditional Early Vibe....YMMV
  19. drail
    drail Tele-Meister
    north central florida
    I tried three lead pick-ups in my fender 62 reissue, stock,alnico 2,before trying SD Broadcaster ,which is great for this guitar, the SD alnico 2 where to mellow for me,but the Broadcaster has that twang..
  20. champtone
    Saratoga Springs
    Thanks for the response...
    I am also the proud owner of a '52RI which I love......everything is stock and I'm leaving it that way. I'm assuming the stock PUs are the Fender PUs you mention above......they sound great.
    My Esquire has a brighter tone than the '52RI, even when played acoustically so I'm thinking that the SD Broadcaster might even 'er out a bit.
