Dual P90 Tele Build
Discussion in 'Other T-Types and Partscasters' started by tjl161, Apr 17, 2019 at 12:35 PM.
Tags:
  1. tjl161
    tjl161 TDPRI Member
    Pennsylvania
    First time poster here with my first real build. Ordered a Tele body from Warmoth with daul P90 routs in Olympic White. Also got a MIM Fender Tele neck in Pau Ferro. Bridge is Callaham hardtail w/ compensated brass saddles. Pickups are Parson Street Originals in RWRP from StewMac. Wired the control plate w/ CTS pots and a .033uf cap.
    I cannot find a pickguard with dual P90 routs. You can see in the last picture that there is space in front of the bridge pickup where a normal tele bridge would be. Any tips on locating a pickguard would be appreciated.
    Got it all setup last night, plays great. Just have to get the pickguard sorted. Thanks for checking it out.
    Matthias, Steve 78, Brucesu and 7 others like this.
  2. gkterry
    gkterry Tele-Meister
    Paris, IL
    Very, nice. I really dig P90s. Hard to beat the sound. I think I like it without a pickguard actually. Ever considered doing that?
    I had PickGuardian custom make a pickguard for a Mustang I used to have and it turned out great. Check them out.
    https://www.pickguardian.com/
    tjl161 likes this.
  3. tjl161
    tjl161 TDPRI Member
    Pennsylvania
    Thanks, Greg. I'll check them out. It looks so naked w/o the pickguard.
  4. bgmacaw
    bgmacaw Tele-Afflicted
    Near Athens GA USA
    I think it looks pretty cool nekkid with no pickguard. But, you might consider a humbucker bridge with P90 neck cut, Warmoth has those. Another option would be a Cabronita pickguard.
    tjl161 likes this.
  5. Mosstone
    Mosstone TDPRI Member
    I only know my speed
    I'm a little confused. You say you need a pickguard, but the last two photos show the guitar with a PG on it. Are you looking for a different color?
  6. Lies&Distortion
    Lies&Distortion Tele-Holic
    SE Michigan
    He means one without the gap that a standard pickguard has for the bridge.
    Mosstone likes this.
  7. tjl161
    tjl161 TDPRI Member
    Pennsylvania
    The pickguard is not mounted in the pics. It is just held snugly around the neck pickup.
  8. Ian T
    Ian T Tele-Holic
    Tampa Bay
    It looks like you could use a standard Tele control plate and no pickguard. Not sure if that meets your tastes but I greatly prefer having easy access to the electronics without having to remove the entire pickguard.
    Given its a Warmoth body they should have no problem making a pickguard. There is no arbitrary place for the pickups to be mounted on a dual p90 Tele, namely the bridge, so you'll have a hard time finding one "off the shelf" that fits. I've used Pickguardian too, they do good work, but you'll need to give exact measurements or trace the body.
  9. tjl161
    tjl161 TDPRI Member
    Pennsylvania
    Warmoth would not make one for me. I'll check out Pickguardian but I might just have to make my own.
  10. Ian T
    Ian T Tele-Holic
    Tampa Bay
    Wow, I'm surprised Warmoth couldn't provide a pickguard for the body they routed.
    If you are comfortable with using a router, that may be the way to go. You could just widen the pickguard you have slightly so that the gap around the bridge pickup is consistent. A P90 routing template would help. There is a gap there on a standard Tele bridge plate so it would probably look fine.
    Or you could trace the pickguard and mail or scan it to Pickguardian.
    tjl161 likes this.
  11. Macrogats
    Macrogats Tele-Afflicted
    Auckland, New Zealand
    Cool looking guitar dude. The pg you have there looks fine if you could just tweak it a little.
    tjl161 likes this.
  12. rickthescot
    rickthescot Tele-Meister
    I'm a big + for nekkid. Just like my Epi Special.
    tjl161 likes this.
  13. mad dog
    mad dog Friend of Leo's
    Montclair, NJ
    My partscaster tele has two P90s, spanish cedar body. Judging by what I hear in this one, you're in for a lot of tonal fun. Gave up on the pickguard. Seems like so much trouble to go to, and I like the look of my darkburst just as it is. So doing without a pickguard.
