Join TDPRI Today
Does time or use cause the caps to degrade?
Discussion in 'Shock Brother's DIY Amps' started by AllenR, Feb 28, 2012.
  1. AllenR
    AllenR TDPRI Member
    18
    Feb 9, 2012
    NJ
    I have a 1964 Ampeg SB-12 that hasn't been used in decades. So I took it to Dennis Kager at Central Jersey Repair and had him go over the amp. Besides changing the plug to a 3-prong, the report came back with the amp in very clean shape and with a suggestion of putting in a set on NOS tubes (old ones were only putting out 20wts).
    I asked about the capacitors and he said they were fine. I forgot to ask what causes them to fail so does anybody know? I was suprised it didn't need them replaced.
  2. jefrs
    jefrs Doctor of Teleocity
    Nov 20, 2007
    Newbury, England
    Using the capacitors keeps them healthy.
    Leaving them idle lets them deteriorate, but they can often be re-formed.
    Easy enough to test on a capacitance meter. If they ain't bust don't fix them.
    They do go down and when they're bad they're horrid.
  3. telex76
    telex76 Doctor of Teleocity
    Jun 24, 2006
    Fort Worth,Tx.
    +1, this.
  5. celeste
    celeste Friend of Leo's
    Jun 24, 2006
    Maryland
    Electro's most common failure mode is an increase in ESR. If you don't have an ESR meter, then you have no idea. A capacitance meter alone does not cut it. If you fix switch mode power supplies, one of your mandatory tools is an ESR meter
    Using an electro keeps the oxide dielectric in good condition, and as jefrs says they can be reformed IF the acidic jelly electrolyte has not dried out.
  6. BobbyZ
    BobbyZ Poster Extraordinaire
    Jan 12, 2011
    Snellman MN
    I have a 62 Ampeg to recap this week. It hums I'm doing a recap. Since it works I'm thinking the tone caps are fine but all the E caps are going in the trash can.
    I'm one of those just recap it guys. Seen too many leaking filter caps to screw with testing them.
    Did my SFSR this summer had it for 10 years play it alot the filter caps started bulging. So even playing them alot sooner or latter thay can go bad.
  7. celeste
    Jun 24, 2006
    Maryland
    There was a major rash of bad caps about 10 years ago. It seems that only like 3 companies make he electrolyte, and one of them changed their formula.
  8. Rich_S
    Rich_S Friend of Leo's
    Dec 29, 2006
    Potsdam, NY
  9. celeste
    Jun 24, 2006
    Maryland
    I don't recall them being, but most of the big name American and Japanese makers were.
