Do WRHBs normally hum?
Discussion in 'Just Pickups' started by bigballs, Jan 30, 2013.
  1. bigballs
    bigballs Tele-Meister
    133
    Feb 12, 2011
    Taipei, Taiwan
    I know this may sound like a trivial question, but it has been haunting
    me for too long that, with much agonizing, I have decided to appeal to
    collective wisdom...
    Shortly after I purchased my tele, I fount out that the WRHB hums. The humming is much more noticeable than Gibson-style humbuckers, and even more so at high gain.
    A couple o'weeks ago, I had a chance to try out an American made 72 thinline.
    Both WRHBs hummed, at a volume close to mine.
    And it seemed that Jimmy Vivino's reissue WHRB also hums quite a bit too.
    (at 1:22, he lifted his hand, the WRHB let out a loud hum, and he muted the strings with a nervous laugh.)
    So...Do YOUR WRHBs hum? How serious is it?
    I need to know before this issue gets the best of me. :(
    Thanks a million.
  2. Topbanana
    Topbanana Tele-Meister
    164
    Oct 3, 2011
    Walmart, Europa
    You have any dimmer switches in the house?
  3. indiobravo
    indiobravo Tele-Afflicted
    Mar 14, 2009
    Raleigh NC
    it shouldn't. may just be a grounding issue.
  4. KevinB
    KevinB Doctor of Teleocity
    Mar 4, 2007
    New Jersey
    The WRHB on my '74-ish Tele Custom is very quiet. No hum at all.
  5. Kitty
    Kitty Tele-Meister
    314
    Oct 11, 2012
    Space
    I have WRHB's in both neck and bridge.. no hum for me either.
    I'd check your grounding....
  6. HopDog
    HopDog Tele-Meister
    162
    Sep 7, 2009
    Upstate NY
    Agree with what others have said...if it disappears with touching the strings, bridge, jack, etc... it is a grounding problem.
  7. FredDairy
    FredDairy Friend of Leo's
    Mar 25, 2007
    Chicagoland
    Both my '72RIs bridge pickups are noiser than their WRHBs.
  8. fender4life
    fender4life Friend of Leo's
    Sep 18, 2011
    los angeles
    Mine do, at least more than any other HB.
  9. bigballs
    133
    Feb 12, 2011
    Taipei, Taiwan
    Have you tried fixing or improving it?
  10. telepath
    telepath Friend of Leo's
    Jun 26, 2009
    Wales, UK
    Is this with gain / dirt - or clean amp?
  11. bigballs
    133
    Feb 12, 2011
    Taipei, Taiwan
    Just tried it today with a VOX AC-4 C1 tube amp, noticeable hum while clean
    that went unbearably loud while cranked up.
    With solid states, the outcome is pretty much the same. In addition, my WRHB hums louder than any Gibson-style humbucker I've compared it to.....
  12. blimpo
    blimpo Tele-Meister
    492
    Mar 29, 2009
    southern indiana
    I read somewhere that the ground from the pickup switch to the output jack needs to be replaced.
    I never knew there was such a ground wire. Still don't know if there is.
    Mine makes a little noise, but not enough to worry about.
  13. bigballs
    133
    Feb 12, 2011
    Taipei, Taiwan
    Thanks for the feedback guys! I will have it regrounded.
