Do Squier Teles have humbucker routing?
Discussion in 'Squier Tele Forum' started by david-rf, Jul 5, 2018.
  1. david-rf
    david-rf TDPRI Member
    27
    Aug 16, 2011
    Italy
    Hi there, I'm looking for a Squier Tele for a little project... I want an inexpensive Tele with humbucker-sized P90 on the neck and humbucker on the bridge (but in the bridge a DiMarzio single coil sized humbucker would do).
    Which Squier models come with HH or at least SH routing? Thanks
  2. jfgesquire
    jfgesquire Tele-Meister
    215
    May 23, 2018
    Lake View
    Classic Vibes have larger neck pickup routing.
    tintag27 likes this.
  3. nicod98
    nicod98 Tele-Afflicted
    Jul 7, 2014
    Belgium
    The standard used to be routed SH. (haven't checked that lately)
    And of course there were some HH models in the past. Like The VM Custom (HH) or the new contemporary series HH tele. And of course you could replacethe pickups in a VM '72 Custom.
  4. Ira7
    Ira7 Doctor of Teleocity
    Jan 8, 2008
    Coral Springs, FL
    Does Squier make a 72 Thinline?
    That would be HH.
  5. bender66
    Jan 18, 2010
    on my bike
    Yep & yep.
  6. reactor99
    reactor99 TDPRI Member
    24
    Jan 1, 2017
    Georgia, USA
    The 2017 Standard Tele (Indonesia) has a humbucker neck route and a standard bridge route.
  7. LooseJack
    LooseJack Tele-Meister
    426
    Feb 4, 2017
    transit lounge
    My 2005 standard doesn't.
  8. nicod98
    Jul 7, 2014
    Belgium
    Strange that the 2005 standard didn't have routing for a humbucker. At that time they sold a Fat Telecaster (SH) in the Squier Standard series.
  9. IronSchef
    IronSchef Tele-Holic Platinum Supporter
    my 2012 Sq Standard Tele had an HB route in the neck:
    And so did my CV 50s BSB:
  10. Ira7
    Jan 8, 2008
    Coral Springs, FL
    How come Fender puts those lips in the pocket?
  11. jfgesquire
    215
    May 23, 2018
    Lake View
    The neck pocket? Because the router bit is a bigger radius than the corners of the neck itself, so for the neck to fit all the way down, the router has to continue past what would make a "normal" curved corner.
    A smaller router bit would make for a better looking corner, but that would take more time and time is money.
  12. The Angle
    The Angle Tele-Meister
    306
    Dec 19, 2017
    Seattle, WA
    I was typing my answer when jfgesquire beat me to the punch. If you look at the routs, they all appear to have corners of the same radius. The factory either didn't have, or didn't want to take time to swap out, smaller router bits that match the radius of the neck corners. They wanted to use the same router bits for all the routs, to save time and money.
  13. Ira7
    Jan 8, 2008
    Coral Springs, FL
    My GFSs don't have that, or my older Affinty or MIM Standard.
    jfgesquire likes this.
  14. jfgesquire
    215
    May 23, 2018
    Lake View
    Manufacturers are always looking for ways to cut time from the production schedule.
    The Telecaster is a wonderful example of that . . . at this very moment I'm learning all about the neck pickup-to-control cavity rout that disappeared in 1968 give or take 6 months.
    It's interesting because that little drill hole from the neck pocket down to the control cavity can really drive you nuts trying to feed 2 cloth pushback wires down it... But AHA! Fender changed to the PVC right around the same time!
    So did they change to the PVC because the cloth was a pain to feed, or because the PVC was cheaper?
