Join TDPRI Today
Do Limiter Pedals Exist?
Discussion in 'The Stomp Box' started by Magnawolf, Apr 24, 2012.
  1. Magnawolf
    Magnawolf Tele-Meister
    247
    Dec 21, 2009
    California
    I was wondering if there was a pedal that limited the amount of volume output. That way you could crank all your pedals and they would all be the same volume.
  2. WireLine
    WireLine Tele-Holic
    712
    Mar 23, 2003
    Midland TX
    Yes...MXR used to make a limiter, as did Boss, several others.
    Please know that a limiter is not anything more that a compressor with an extremely high or even infinite ratio. It also is NOT something that does what you described, as it does not do anything below the threshold; a limiter only prevents things from going over a certain peak (hence the name)
  3. DoodlySquat
    DoodlySquat Tele-Holic
    601
    Feb 28, 2012
    Uranus
    Yeah I'm guessing you're looking for a compressor. I'd strongly recommend the MXR Dyna Comp.
  5. Teleworshipkid
    Teleworshipkid Friend of Leo's
    Mar 20, 2011
    Newport Beach, CA
    Uh... You mean a volume pedal?
  6. ProdableOne
    ProdableOne TDPRI Member
    8
    May 25, 2011
    Brisbane, Aus
    I own one of the boss lm-2's and yes technically you could but you'd have to run it at the end of your effects chain to do as you've described. Not really the place you'd put a compressor
  7. Frank B
    Frank B Tele-Holic
    823
    Jan 13, 2008
    quebec, canada
  8. mal paso
    mal paso Banned
    Nov 24, 2011
    Bloomington, IN
    I think a compressor would do the trick
  9. hannigan
    hannigan Friend of Leo's
    I used to use an Art limiter in my signal chain, I was just recently wondering what ever happened to it. It sounded nice had a tube in it. It was useful for recording if I remember correctly .
  10. redriding
    redriding Tele-Meister
    165
    Jan 20, 2012
    huddersfield uk
    Boss lm-2 limiter.
    I've got one on my board and its just great.very neutral sounding and way cheaper used than a boss cs-2.Couldnt be without mine.
