DIY tools & jigs
Discussion in 'Tele Home Depot' started by melomanarock, Nov 6, 2010.
  1. melomanarock
    melomanarock Tele-Holic
    Argentina
    Well a couple of months ago there was a thread talking about opening a tools and jigs section and since it hasn't happened I thought It would be cool to start a thread where we can all contribute with home made tools and jigs, and hopefully it would become sticky.
    I'll start with a couple of my own:
    here's a jig for jointing
    one for planning
    This is my army of robosanders.. they are just paper rolls, the ones used in cash machines. The cool thing about them is that you can take off as many layers of paper as you want and have custom diameters.
    And here's my fret bender
    Please people feel free to chip in..
    Cheers!
  2. Colt W. Knight
    Tucson, AZ
    Your sanding drums are genius! How do they hold up?
  3. PapaLion
    PapaLion Tele-Afflicted
    SW AZ
    One of the best threads on a welding site I like has just such a thread. Excellent idea well worth a sticky. The ingenuity sometimes amazes U. I'll take a pic or two of some very simple things made to do a specific task soon. Good!! MellowMan.
  4. crane550
    crane550 Tele-Meister
    Boise, Id
    Here is my home made tool that does most of the work at my shop.
  5. Engraver-60
    Engraver-60 Friend of Leo's
    Brentwood, TN
    Yeah, sure, but can it hammer (remember the old Dremel commercial?)
  6. gitlvr
    gitlvr Friend of Leo's
    Northern Va.
    Show off!:D
  7. Vizcaster
    Vizcaster Friend of Leo's
    Glen Head, NY
    Here's a fret slotting jig. The scrap has slots in it that are used to index the blade.
    The neck is double-stick taped to a sled, hopefully staying aligned with the centerline, then another clamp (not pictured) is thrown on when it's aligned, just before cutting
    No fancy measuring to lay out the stops, just transfer the marks from a known neck (this one was from Musikraft):
  8. Vizcaster
    Glen Head, NY
    Headstock plug drilling jig
    Lining it up before drilling is the nerve wracking part:
    Oh, and remember to use hearing protection with those aircraft bits - dunno if I'm doing something wrong but boy do they squeal.
  9. Vizcaster
    Glen Head, NY
    Trussrod routing jig
    [​IMG][​IMG]
    [​IMG][​IMG][​IMG]
  10. melomanarock
    Argentina
    Here's another one.. actually it isn't a tool or a jig.. it's just a tool modification.
    The problem: my drill press's throat wasn't deep enough to fit the guitar body up to the line of the string through holes.. and I wasn't going to drill them whit the hand drill having a drill press.. this is what a came up with..
    Before:
    After:
    the solution:
    hope someone finds it helpful.
  11. SixShooter
    SixShooter Friend of Leo's
    Cincinnati
    Are you cutting your templates with a "LASER"?
  12. melomanarock
    Argentina
    Yes, they are laser cut, but actually I don't like them that much. The sides don't end up being perpendicular to the surface, and the thicker you want the template the worst this thing gets. The one on the picture is 10 mm. I'm going to make some the old hand way and try both to see if there's an important difference
  13. kwerk
    kwerk Poster Extraordinaire
    New Zealand
    :cool:
  14. kwerk
    New Zealand
    jigs n. see "Scatter Lee"
  15. rewind
    rewind Tele-Meister
    Alberta
    A very timely thread. Thanks for this.
  16. bullitt
    bullitt Tele-Holic
    mooresville indiana 46158
    Did u make the cnc router too,that is cool?
  17. crane550
    Boise, Id
    Yea, thats my baby. Built her from scratch.
  18. Nick JD
    Queensland, Australia
    A jig for vacuum-forming laminate/composite acoustic sides.
  19. andrewdoeshair
    andrewdoeshair Tele-Meister
    corona, CA
    This is my fret bending jig, made from skateboard bearings and scrap pine
    This is some sort of jig made from two pieces of scrap pine screwed into a piece of plywood, to keep my radius block from twisting as I push it down the fretboard.
    I made one of these popular guys, too...
  20. Gregmw
    Gregmw Tele-Meister
    Here is my Router Thicknessing jig -
    Probably a little over kill but it work's will to thin down necks
    Here is my binding laminator - cost less than $5.00
    Guitar body bench clamp.
