Join TDPRI Today
Diminished Chords
Discussion in 'Tab, Tips, Theory and Technique' started by mozzarate54, Dec 29, 2012.
  1. mozzarate54
    mozzarate54 Tele-Holic
    573
    Aug 8, 2012
    California
    So I was listening to John Mayer today (I'm Gonna Find Another You) and he has this really awesome chord progression in the song which uses a diminished 7th chord. And I know I how play the chord my only problem is how do you use it in a progression? whenever I try to use it, it just doesn't sound right. Any tips and examples
  2. Alex Strekal
    Alex Strekal Tele-Meister
    142
    Dec 25, 2012
    Euclid, OH
    I suspect the main reason it's not sounding right is precisely because it isn't normally a chord you use by itself - it's mainly used as a dissonance that resolves. Example: Bdim7 -> Am. x2x131 -> x0x210.
    One little trick or relationship to realize is that if you take any given note of a dim7 and lower it by a halfstep, this produces a dominant 7 of one sort or another. Ex: Fdim7 (xx3434) becomes E7 (xx2434) by lowering F to E. Or suppose instead we take the Fdim7 (xx3434) and lower the D to C#: it now becomes a 1st inversion C#7 (xx3424). This relationship is part of why dim7 chords are popular as transition chords to new keys, since a change of one note creates a pivot to 4 possible dominants.
    Another relationship is that if you impose them over a bass note a halfstep under or in other strategic spots, it creates a dom7b9. Ex: G#dim7 (xx6767) becomes E7b9 when you add an E in the bass (x76767). In isolation, this may "not sound right", but if you know how to resolve them, they take on a purpose. That E7b9 will "sound right" going to an Am: x76767 -> x07555. Relatedly, sometimes you may find that a dim7 chord is meant to function as an incomplete dom7b9, and the bass player's role is to hold the root.
    Another use of a diminished 7th chord may surprise you: in a blues. It's not all that uncommon to slightly alter a 12 bar blues format by adding a diminished 7 or two, like this:
    A7 D7 A7 A7
    D7 D#dim7 A7 A7
    E7 D7 A7 A7
    An example of voice-leading that D7->D#dim7->A7 move: xx0212, xx1212, xx2223.
    Generally, you will most typically find dim7 chords taking on a dominant function, or used as passing chords. They are closely related to dominants, as my above examples show. If this is too much too take in, my apologies, I'm a pretty theory-laden guy.
  3. Leon Grizzard
    Leon Grizzard Friend of Leo's
    Mar 8, 2006
    Austin, Texas
    The most common use of the chord is using on the last beat or two of IV going back to I ie IV IV#dim I, like G G7 C C#dim G. Use that in blues and swing. Also as a passing chord in a vamp like I I#dim ii7 V7 I, like G G#dim Am7 D7 G.
  5. mozzarate54
    573
    Aug 8, 2012
    California
    Ok so in order for me to use that dim7 chord I have to use a 7chord in the progression. So would this work?
    (sorry if progression is crappy)
    A-> Em -> G -> G7 -> D -> G -> G#dim7 -> back to A
    ^^^ That would work?
  6. Alex Strekal
    142
    Dec 25, 2012
    Euclid, OH
    G -> G#dim7 -> back to A certainly is an example of a workable musical idea with a dim7 as a passing chord or substute dominant. But to clarify, you don't have to use a 7th chord with it per se; my point was to show a relationship to dominants by changing one note, and using that as one possible manuever to make in a chord progression (dominant preparation).
    I would suggest, short of thinking about entire progressions, getting used to the function and sound of a diminished 7 resolving to another chord in general. Tension-release. 9/10, the notes will pull in the same way a dominant would or otherwise function as an altered dominant.
    Example: You establish the familiar sound of an A major chord, as home base. Maybe the voicing is: xx7655. Then comes a G#dim7: xx6767. Then resolve back to the A: xx7655.
    This is an example of the diminished 7 chord as a substitute dominant - it creates a similar effect as a I-V7-I, and is indeed only one note different. It has a tension (tritone and leading tone function) that pulls smoothly back to an "inside" sound.
    Now, let's think of using it to transition to another chord instead. We can start with our A (xx7655), then play G#dim7 again (xx6767). What other chords could this pull to? Staying in the key of A major, one possibility is the relative minor: an F#minor chord. So we could do this: xx7655 -> xx6767 -> xx4675.
    Notice that this is, once again, serving a dominant function - it's as if we went I -> V7/vi -> vi. If there is a bass player hitting a low C# when we play that G#dim7, it in fact *is* V7/vi (V7b9/vi to be exact). The G#dim7 is then functioning as every note but the root note of a C#7b9.
    Here's an example of a tonal chord progression that uses a few dim7's as passing chords and substitute dominants:
    A - G#o7 - F#m - Dmaj7 - Bm7 - Bo7 - E7 - A
    I - o7/vi - vi - IV7 - ii7 - o7/V - V7 - I
    In this example, the G#o7 is a substitute dominant for V7/vi, and the Bo7 is a passing chord that functions to prepare the V (E7).
    My basic point is that you can use a dim7 chord in place of a dominant 7th chord, if you desire the color. If you understand how a dominant chord normally *functions* (including 2ndary dominants), you will understand how a diminished chord typically *functions*.
    There are of course other uses of diminished 7th more for color than function that I'm not covering.
  7. Leon Grizzard
    Mar 8, 2006
    Austin, Texas
    What you had would work. The diminished chord often works to chromatically connect two chords or inversions a whole step apart.
  8. klasaine
    klasaine Poster Extraordinaire
    Nov 28, 2006
    NELA, Ca
    Here's another 'standard' º7 prog, two beats each chord:
    | Cmaj7 C#º7 | Dm7 D#º7 | Em7 Bbº7 (XX5656) | Dm7 G13 |
    *That Bbº7 is really functioning as an A7b9 (sans root) as mentioned in Alex's excellent post.
  9. the embezzler
    the embezzler Tele-Holic
    Yes - this is one of the most useful ways of employing diminished arpeggio's.
    If you play a diminished arpeggio from the third of a dom7b9 chord you will spell 3-5-b7-b9.
    So take the first four bars of Beautiful Love for example -
    Em7b5/A7b9/Dm7/D7b9
    You can play something based on Mixolydian b2 b6 (A,Bb,C#,D,E,F,G) over the Em7b5 and A7b9 then play a D Dorian (D,E,F,G,A,B,C) line in bar 3 before playing the diminshed arp over the D7b9 which would be F#-A-C-Eb.
    Not only does the diminished arp nail the sound of the 7b9 chord it pushes your ear towards the next chord (a Gm7) in a very musical way.
  10. Alex Strekal
    142
    Dec 25, 2012
    Euclid, OH
    Right. Good example.
    Just to illustrate the dominant relationship, I would intuitively view and hear this progression as a colorful alternative to:
    Ex1
    | Cmaj7 A7 | Dm7 B7 | Em7 A7 |Dm7 G13 |
    And if we take the progression w/o7's and choose to add a bassline targeting the roots of the progression w/dominants (Ex1), the net effect is:
    Ex2
    | Cmaj7 A7b9 | Dm7 B7b9 | Em7 A7b9 |Dm7 G13 |
  11. ac15
    ac15 Poster Extraordinaire Ad Free Member
    May 9, 2005
    CHICAGO, IL.
    You just have to learn a lot of standards and old tunes that use diminished chords and you'll just know how to use it from that point on. Just get used to hearing it. I know you're looking for a general "rule" of how to use it. Several posts have addressed that, but there really are no shortcuts unfortunately.
  12. klasaine
    Nov 28, 2006
    NELA, Ca
    Slightly OT
    Once one gets the hand of how to use º7 chords and how they may be sub'd with 7b9 chords it's REALLY important to also know when to just play the actual º7 change.
    For example: the first bar of 'Don't Get Around Much Anymore' ...
    "missed the saturday dance" CΔ7 Dm7 D#º7 Em7 - that one kinda needs to be an actual diminished chord.
    Or, 'Corcovado', second change - | Am6 | % | Abº7 | % | etc.
    (I like the Fº7 going to Fmaj7 in bars seven and eight too).
    *I've been playing 'Stella by Starlight' recently as written by Victor Young (from the movie The Uninvited) with a big fat Bbº7 right at the top voiced like this: 6X5655 - yes, with the A natural on top! It's friggin' gorgeous in an ugly/beauty kinda way.
    My point is, don't get carried away with always subbing out a dim7 for 7b9.
  13. Alex Strekal
    142
    Dec 25, 2012
    Euclid, OH
    Point taken. If it's specified as o7, stick with o7, unless you're taking creative license.
  14. klasaine
    Nov 28, 2006
    NELA, Ca
    Actually my point was that a lot of times guys (probably not you Alex) get carried away with substituting every diminished chord they run into with some type of alt/dom (a half step down). It'll always work - but IMO it's not always the best musical choice.
    Much of the time those written diminished chords in sheet music really are a 7b9 (sometimes their even m7b5 chords - but that's another thread) and it's good to know when to sub them out. My examples listed in my previous response are the times when the 'composer knew best' - and an editor wasn't trying to dumb it down just to sell easy sheet music editions.
  15. Alex Strekal
    142
    Dec 25, 2012
    Euclid, OH
    "Sometimes a diminished 7th chord is just a diminished 7th chord" - Zombie Frued
  16. the embezzler
    Sure. If you are comping you can't take liberties with the harmony but you can when soloing. If I was soloing over that section in Don't Get Around Much.... I would just think C and then maybe treat the A7 as an A7b9 (diminished arp from C# works here) as it goes into the Dm-G7, the II-V. You dont need to 'cut' every change.
    There are lots of bad charts out there though so you have to find your way and use your ears. Try and find a nice chart for Chick Corea's Windows - there are some really awful versions out there.
    As above - I trust the chart as much as I trust the government. :rolleyes:
  17. BigDaddyLH
  18. backporch guy
    backporch guy Tele-Afflicted
    Music Theory:p
  19. rphunt2002
    rphunt2002 Tele-Holic
    550
    May 19, 2009
    New York City
    There's a lot of good info here. What I thought I would add is basically a rule of thumb about dim7s (also just called dim or º chords) which kind of repeats some of the previous replies.
    They can be thought of as wanting to resolve a half step up, e.g. Eº -> F, Bº -> C, and this is mainly b/c they function as a substitute for a V7 chord, e.g. (C7 or Eº) -> F. Yes you can also think of it as a V7b9.
    Of course this doesn't mean that all I->II7->V7 progressions can be turned into I->Iº->VIIº, b/c substitutions have to be chosen based on the music being played.
    But what it can mean is that a cycle of V7 chords, e.g. A7 -> D7 -> G7 -> C can be played as C#º -> Cº -> Bº -> C (when suitable).
    A progression I like is CΔ7 -> C#º (or A7b9) -> D9 -> G13b5 or
    x-3-5-4-5-x
    x-4-5-3-5-x
    x-5-4-5-5-x
    x-4-3-4-5-x
  20. hal
    hal Tele-Afflicted
    Apr 4, 2006
    Memphis, TN
    Alex Strexal is smarter than me.
