different 4 way switching
Discussion in 'Tele-Technical' started by Pinetar, Aug 12, 2018.
  1. Pinetar
    Pinetar TDPRI Member
    20
    Dec 19, 2017
    Oregon
    I want to wire my Tele in a non standard way. I want it to be standard 3 way with the 4th position being a tone bypass, basically the 3rd position of a Esquire. I don't want to use a additional switch or a no load tone pot. I would like to keep it all in this one 4 way switch. Is it even possible with a standard 4 way switch?
  2. jonrpick
    jonrpick Friend of Leo's
    Mar 17, 2014
    Marietta, GA
    Probably not difficult. But it'll only work in one pickup position (I assume the bridge?). With a 2 pole 4 way should work.
  3. Pinetar
    20
    Dec 19, 2017
    Oregon
    Yes, the bridge is what I want to bypass the tone.
  4. jonrpick
    Mar 17, 2014
    Marietta, GA
    I mispoke... (it's late)
    With a 2 pole 4 way switch I don't believe it's possible. I'm trying to find out if a 4 pole 4 way exists. I need it for a different application, but your example is yet another reason why it's needed.
  5. Pinetar
    20
    Dec 19, 2017
    Oregon
    Ahhh. 4 pole 4 way. Gotcha. I will look that up. Thank you.
  6. knockeduptele
    knockeduptele Tele-Meister
    183
    Dec 15, 2017
    London
    If you find one let us know - been looking for a while to drop the round off the bottom of the vol pot in pos 4
  7. jonrpick
    Mar 17, 2014
    Marietta, GA
    I was playing with wiring diagrams last night for my own needs. I had a moment of inspiration. I am now back to my original thought that this can easily be accomplished with a 4 way 2 pole. I'll update once I get home.
  8. jonrpick
    Mar 17, 2014
    Marietta, GA
    You mean you want position 4 to be brighter?
  9. knockeduptele
    183
    Dec 15, 2017
    London
    And louder - I currently do it on a minature toggle on the control plate between the pots but want to be able to do it on a single switch throw rather than two controls - pull switches on pots arent available to me as Im a leftie and wire controls with LH CTS pots
    Probably 4 gang 5 pos strat switch is the solution but it would be nice to contain it in 4
  10. jonrpick
    Mar 17, 2014
    Marietta, GA
    So.... same as the OP, you just want to lift the tone control in position 4? Or do you want a "blow" switch where it's just bridge pickup straight to the output jack?
  11. knockeduptele
    183
    Dec 15, 2017
    London
    along those lines but its actually the series position ie std pos 4 rather than the bridge (I actually lift the vol pot so its wide open as well but that's me) just the bridge would be easy
  12. jonrpick
    Mar 17, 2014
    Marietta, GA
    Ok... you lost me. I don't play Teles so I'm unfamiliar with how they're wired when a 4 way is used.
