Did something really dumb... how can I fix it?
Discussion in 'Tele Home Depot' started by John Nicholas, Feb 14, 2019.
  1. John Nicholas
    John Nicholas Friend of Leo's
    Poughkeepsie, NY
    One of the dangers of building more then one guitar at a time I suppose... and not enough room. When moving another body a pickup that was not attached fell out and hit the Walnut body.
    Leaving two pretty deep dings.
    How can I fix this? I'm open to any and all suggestions.
  2. unclearty
    unclearty Tele-Holic
    South central Mass.
    The top one...that looks like a hole...drill out and insert either a small stone or circle of contrasting wood....then fill the little ding. The eye will be focused on the insert...won't even notice the little ding
    teleman1 and Peregrino69 like this.
  3. guitarbuilder
    I'd vote to leave it alone. Guitars get dinged up. If you drop fill it, it'll look like you drop filled it. Unless you go opaque, there isn't much you can do to hide it in my opinion.
  4. eallen
    eallen Tele-Afflicted
    1- Make sure your wife or significant other isn't home.
    2- Sneak into laundry room and place clothes iron under your shirt. (Make sure it is turned off first. Wish someone would have told me that first)
    3- Get a damp cloth, not that damp, ring a little more out.
    4- Turn the iron on high. (Take it out from under your shirt first. Wish someone would have told me first)
    5- Place damp cloth over dent and pres lightly with the iron where the dent is located.
    The steam will be forced down into the wood fibers and expand them. You may need to do it several times to expand as much as possible. Let it dry thoroughly and see where you are. Whatever indentation is left I drop fill with layers of CA glue. It may look like a slight wave in the grain when done but muchhhhh better than some glob of putty that doesn't quite match.
    Look forward to pics of progress.
    Oh, and welcome to the "did something dumb club." Your in good company.
    Eric
    Sent from my SM-G892A using Tapatalk
    dswo, zippofan, Artslap and 10 others like this.
  5. Armo
    Armo Tele-Holic
    Wales
    What eallen says. Damp cloth and hot iron works really well.
    eallen likes this.
  6. Milspec
    Milspec Friend of Leo's
    Nebraska
    Good place for a tour sticker
    Dismalhead likes this.
  7. Fatcat211
    Fatcat211 Tele-Meister
    Nyc
    I’ve had good success steaming out dings. Although with those in particular. I would use a soldering iron and damp rag. You might even want to drop that pickup on some scrap and practice your technique.
    If it doesn’t work, you can relic or let it be the first of many natural wear marks.
  8. fasteddie42
    fasteddie42 Tele-Holic
    Tip of the Mitt
    Steam them
  9. John Nicholas
    Poughkeepsie, NY
    Great idea about dropping the pickup on a scrap and testing!!
    Honestly I'd even be willing to sand the body down and re-finish it. Only problem is that one ding is far too deep. :(
  10. jvin248
    jvin248 Poster Extraordinaire
    Lions & Tigers oh Mi !
    Don't do a strip and refinish -- way too much work and the value drips precipitously.
    Steam will lift the dings some, but you have broken fibers. It will lift quite a bit not all the way.
    Key is make sure the cotton t-shirt is damp so the iron sizzles -- that ensures the guitar is not seeing a temperature above the 212F where the water boils away. Otherwise you'll melt and burn the finish.
    Get some tint, stain, or shoe polish to color in the broken fiber ends and then use the CA glue to drop fill. Use a razor blade with both ends taped giving you a lift section of blade exposed to scrape the glue back. Use small strips of 400, 600, 800, 1500 grit paper to put under your finger over the spot and pull the strip. Lift your finger, reposition the strip, press, pull. Do that over and over until it seems flush then go with the next finer grit. Eventually you can get it all smoothed out and polish up with car polish (swirl remover) to buff it out then car wax.
    dswo and jrblue like this.
  11. guitarbuilder
    For the amount of work that it will take to make a repair invisible, I'd ask myself whether it would be less work to just do another body and make that a keeper or add a few more dings, add some used parts, and sell it as a used guitar. I had a Norlin era LP Custom with a " repaired" ding in the same spot. It stuck out like a sore thumb the whole time I had it. Sometimes you just have to move on. You gotta know when to fold em….. and only you know that. If you are gonna try and save it, an opaque paint could be your friend. YMMV.:).
    El Tele Lobo likes this.
  12. Ronkirn
    Jacksonville, FL
    since the fibers are cut.. there is no simple way to repair it and have it be invisible... while steaming will force the compressed fibers to swell. they will not swell to exactly the pre ding state,. thus some refinishing will be necessary....
    so... you have to ask is the scar the two un repaired ding leave more objectionable than the scars and the refinished area will leave...
    it is possible to do a perfect repair, but you're talking about a considerable amount of effort... and that effort has to be magnified by considerable talent... That's fare more trouble than just making a new body and not dinging it this time..
    rk
    8barlouie, El Tele Lobo and getbent like this.
  13. noah330
    noah330 Friend of Leo's
    Maryland
    fill it and do a sunburst?
  14. SecretSquirrel
    SecretSquirrel Friend of Leo's Ad Free Member
    PNW USA
    I had some success steaming out a neck dent. The technique I learned (here on TDPRI): a drop of water in the dent, then touch it with a hot pin. Repeat as needed.
    Worth a try -- even if the dent doesn't completely steam out, you might be able to reduce it from a nasty "dent" to a milder "ding."
    I like Noah's sunburst solution above.
    dswo and El Tele Lobo like this.
  15. John Nicholas
    Poughkeepsie, NY
    Just an FYI, this dent happened over a month ago... I knew it was bad, so I put it away and didn't look at it until today.
    I have to admit that just making another one sounds like my best bet!!
    Thank you everyone for your time in offering suggestions and ideas....
  16. John Nicholas
    Poughkeepsie, NY
    Just an FYI...
    Not sure a sunburst would look good on this body...
    And it would be a shame to cover this walnut...
  17. Marc Morfei
    Marc Morfei Tele-Holic
    Philadelphia, PA
    If you decide to make a new one, maybe you can sell that body. I think it's pretty nice, even with a couple dings....
  18. SAguitar
    SAguitar Tele-Meister
    Oregon
    As Mick Jagger might have sung...
    I want to see it painted, painted black
    Black as night, black as coal
    I want to see the sun, blotted out from the sky
    I want to see it painted, painted, painted, painted black
    Yeah
    gwjensen likes this.
  19. charlie chitlin
    Spring City, Pa
    I have gotten amazing results by drop-filling with CYA.
    Not invisible, but MUCH less visible.
    The fact that it's clear makes it appear the color of the surrounding wood.
    MickM likes this.
  20. zhyla
    zhyla Tele-Meister
    Northern Hemisphere
    Assuming it’s already got finish on it, I would just lay down another coat or two of finish. The smaller ding will just disappear and the other won’t be as noticeable.
