Diagnosing Deluxe Reverb Frequency Ringing and Distortion - Audio Clips
Discussion in 'Amp Tech Center' started by jondom22, May 13, 2019.
  1. jondom22
    jondom22 TDPRI Member
    Brooklyn
    I've noticed recently that my ears have been very fatigued playing my deluxe reverb. After some investigation, I realized there is an upper midrange frequency ring around 2-3kHz. I poked around my tubes to test for microphonic tubes and performed the test with and without reverb, and on both channels.
    Additionally, when using a load box (suhr reactive load), I can hear what I assume might be subtle tube distortion even when playing the amp on "clean" levels (2 on the volume dial).
    Here's a clip of just ringing out some chords so you can hear. Any insights and tips are appreciated.
    Soundcloud Link
  2. gianluigi
    gianluigi TDPRI Member
    Italia
    Check and clean tube sockets if needed retension. It worked with my amp.
    Inviato dal mio LLD-L31 utilizzando Tapatalk
  3. robrob
    United States
    Have you tried different tubes? A bad tube can cause your symptom.
    If it's not a bad tube then try chopsticking your socket leads around.
    Axis29 likes this.
  4. Axis29
    La Quinta, CA
    Always start with the simplest test first... Which you did, by tapping the tubes. Next would be replacing the tubes one by one with known good ones, as Rob states.
  5. jondom22
    Brooklyn
    Just experimented a bit more with rolling preamp tubes, taking the reverb tank out of the combo, tapping away at the tubes chassis, and sparying some E-Line tech spray on the tube pins to clean the sockets, and haven’t been successful at sourcing the high frequency ringing/resonance.
  6. robrob
    United States
    Did you try other power tubes?
  7. jondom22
    Brooklyn
    I did not as I didn't have any spares and I'm not experienced with biasing an amp. Takin it into the shop tmrw.
  8. robrob
    United States
    The distortion could be caused by a bad power tube. Have the tech start with trying different power tubes.
    jondom22 likes this.
