Delta-Tone vs. TBX
Discussion in 'Tele-Technical' started by James W, Aug 6, 2003.
  1. James W
    James W Tele-Meister
    Los Angeles, CA
    For some reason I thought that delta tone and TBX tone controls were the same things. I understand now that they're different but what's the difference?
    Thanks!
    --James W
  2. gottliver
    gottliver Tele-Meister
    delta tone is a tone pot w/a dedent at 10. 1-9 is a basic tone at 10 it clicks and takes the tone out of the circuit. = more treble. The TBX is (Treble/Bass/XCut) from 0 thru 4 its a treble cut, at 5 its neutral and from 6 -10 its a bass cut. Anybody use one?
  3. Kevin
    Kevin Friend of Leo's
    Terre Haute, IN
    From Mr. Gearhead
    So, the TBX doesn't "boost" anything, although that's a popular misconception. Passive controls will never "boost" a signal; only active electronics can do that. How it works is like this: Increasing the resistance of the pot allows more of the natural highs to come through; that's why most people use 500K pots with humbuckers. The 1Meg portion of the pot simply lets more highs through. Unfortunately -- to my ears, at least -- the TBX is pretty muddy from 1 to 5 and doesn't really sound like a full 250K pot. The wiring of the pot is a bit more complex, as you have to basically wire one pot with a cap and the other with a resistor. Also, the detent is pretty annoying cos you can't just turn the knob past it with a pinky...
    The Delta Tone pot ostensibly gives the same effect -- allowing more highs to come through -- by essentially taking the tone control out of the circuit. It's a lot easier to wire, too, as you are only wiring one pot in the traditional manner. Same problem as with the TBX, as far as getting out of the detent position.
    If you are $$-challenged, but like to tinker, you can get the same effect as the Delta Tone pot by opening up the tone control pot and applying fingernail polish to the carbon track at the extreme of the wiper's travel. This will also take the pot out of the circuit. Best of all, you won't have that (IMHO) annoying detent to deal with.
  4. curtisstetka
    curtisstetka TDPRI Member
    Allentown PA
    I think the Deltatone is a significant improvement in guitar electronics. I have a 2002 MIA tele with one and just love it. I keep thinking that when I have the urge to open up my part-o-caster again I'm going to change the pots to Deltatones.
    The detente doesn't really bother me at all.
    A friend of mine got a Strat Plus off ebay recently with a TBX control. After a month he couldn't stand it anymore. I replaced it for him with a standard 250k pot. I didn't care much for the TBX either.
    Perhaps it's just a matter of what you're used to.
  5. Bob Mc
    Bob Mc Friend of Leo's
    Mo'town NJ
    Handled 2-3 TBXs
    when I removed them. Funny thing is one guy didn't even know he had it; the repair ticket said 'bad pot'. I made him come in and try it out before I removed that one.
  6. Mike D.
    Mike D. Tele-Holic
    Chicagoland
    I have a TBX...
    on my 91 Strat Plus. I kind of like it. I don't use it all of the time but it definitely increases the presence of the bridge pickup. I've never been inclined to put one in as a mod though. For the time being, I am leaving it alone and have kept that guitar completely stock - for now. I love the body and finish on it, but I've worn down the frets pretty low. I'm thinking of going with a vintage/modern replacement neck and upgrading the pups from the Lace Sensors to something cooler.
  7. rebelern
    rebelern Tele-Holic
    Swampyville, Australia.
    I like the Delta Tone , it's really effective,and you quickly get used to the detent,it's worth a look at!.
    Ernie.
  8. LPBlue
    LPBlue Tele-Holic
    Markdale, Ontario
    TBX control
    My 94 40th Ani.MIA Strat came with one and I installed one into my 92 MIM Std.Tele. Both guitars have Bardens and the TBX responds very nicely to them. The best way to describe the effect is more "air" to the sound. It has it's place, particularly for recording but for the most part I only use the lower half of the sweep as a tone control and ignore the rest for live use.
    J.R.
  9. stratohiker
    stratohiker Tele-Meister
    Mountains Of Western NC
    TBXs for me......
    I use them primarily on strats. I've got a Beck strat (the newer series), I dropped 2 TBXs in it and it works well for me. I just put one in a new HWY 1 tele also. And yes, in a tele because of the heavier chrome knob, it makes it hard to detect where the detent is. Esp, live and on the fly. I usually have them set at the detent. But, sometimes later on at night when the high end is shaved off your hearing, they come in handy. Or even in a "saturated" room, they can help you "cut thru" the mix.
