Delay with tap tempo and dotted 8th
Discussion in 'The Stomp Box' started by Bikersluggo, May 28, 2019.
  1. Bikersluggo
    Bikersluggo Tele-Holic
    Dayton, OH
    I am interested in a new delay pedal with tap tempo and a dotted eighth setting. Preferably something I could find for less than $100 used?
    I'm aware of the ehx deluxe memory boy, and I think tc electronics has something but what are my other options?
  2. schenkadere
    schenkadere Friend of Leo's
    NY
    Take a look for a used DOD Rubberneck. There's a lot of love for these. Has everything you could need. May be a bit more than $100, but you'll probably never need another delay.
  3. Mark the Moose
    Mark the Moose Tele-Meister
    Erie, CO
    More money: Boss DD500. I got mine used for $169 and have never looked back, it’s amazing at whatever you want in a delay.
    Another option is to learn to tap the dotted eighth against a quarter note beat. It takes a little practice, but really not that much. Then you just pick the tap delay that has the right tonal qualities for you and have one less feature to worry about.
    SixStringSlinger likes this.
  4. SixStringSlinger
    SixStringSlinger Friend of Leo's Silver Supporter
    Space
    I was going to suggest this. So long as you can work out the "math", you don't need a delay with a specific dotted-eighth setting.
  5. basher
    basher Tele-Afflicted
    Washington, DC
    Check out the EHX Canyon. There are a few on Reverb now for $100.
    Ecadad likes this.
  6. popthree
    popthree Poster Extraordinaire
    a hawk makin lazy circles
    Nux time force will do it.. 50ish used
    Bikersluggo likes this.
  7. Guitarteach
    Boss DD7.
    Great little pedal. Does all the great digital delay tones, has a great analogue mode and has tap tempo and dotted 8th and a looper function. An external tap tempo switch makes it highly intuitive.
    middy likes this.
  8. sonicsmitty
    sonicsmitty Tele-Holic
    Clarksville, TN
    I have a TC Electronics Nova Delay. I don't think they're making them anymore. I saw some used for around $100. I like mine, though I don't use all of its capabilities. I am slightly challenged when it comes to using delay, so I just use mine for a little added space. It does have the dotted eighth note function as well as others including reverse.
  9. middy
    middy Friend of Leo's
    Dallas, TX
    No math involved just tap out the first three beats of a “Bo Diddley” beat.
    codamedia likes this.
  10. Mexitele Blues
    Mexitele Blues Tele-Meister
    Westminster, CO
    Boss DD-5 does it well. Should come in around budget with a tempo switch.
    Bikersluggo and Lawdawg like this.
  11. dombar335
    dombar335 TDPRI Member
    Pennsylvania
    TC Flashback 2. You can audio tap tempo by hitting your strings or add an external tap tempo if you don't play in stereo.
  12. patient81
    patient81 TDPRI Member
    Scotland
    No audio tap tempo in the flashback 2 unfortunately.
  13. dombar335
    Pennsylvania
    Really? I only have the first one. You hold down the pedal until the sound cuts out and then tap the tempo on your strings. So the only way to tap tempo on the 2 is with an external switch?
  14. patient81
    Scotland
  15. beninma
    beninma Friend of Leo's Silver Supporter
    Massachusetts
    Another option is a Digitech Obscura if you can find one used it might be reasonable.
    Its tap tempo requires you to hold the footswitch for 2 seconds and then start tapping. That could be a deal breaker. I found it workable for just practicing, but ISTR some people found it unworkable in a gig situation.
    It is a nice sounding delay with a bunch of options and it's built like a tank and relatively small.
    I had one, got rid of it, not necessarily sure it was the right move now?
    I have had a lot of delays in only about 2.5 years.
    Flashback -> Obscura -> Obscura + Memory Boy -> Memory Boy -> Memory Boy + DMM 1100TT
    Memory Boy will possibly go soon.
    Note I have the regular Memory Boy, the Deluxe Memory Boy is a lot nicer. It does 99% of what the Deluxe Memory Man Tap Tempo/1100TT do, it just has 700ms max delay, a darker sound, and a different selection of oddball features.
    The DMB has a low cut (lets you cut bass) option that the DMM does not have, and it has a hidden mode called Tap Divide Sequencer. When you enter the Tap Divide Sequencer Mode it cycles through the tap tempo divisions all by itself which results in a constantly changing sound. All Memory Boys also have square wave functionality in their Oscillator, which Memory Man units do not have.
    The DMM Tap Tempo models do not have the Tap Divide Sequencer mode or the Low Cut feature. Instead the Tap Tempo DMM models have a feature that lets you set a second feedback level and you can cause it to ramp up to the higher feedback level by holding the tap tempo switch. This feature uses the same controls the Sequencer/Low cut features use on the DMB.
    DMB is a nice option to pay a lot less than a DMM if you like the way it sounds. I bought my DMM a month or two ago, I had a really hard time deciding to get a DMM vs a DMB. In some ways I think the Memory Boy line does better chorus because of it's darker tone & lower minimum delay time.
    J-Flanders and Bikersluggo like this.
  16. MatsEriksson
    MatsEriksson Tele-Holic
    Sweden
    DigiTech TimeBender used one....
    It has both immaculate tap tempo (no holding for two seconds) and the first ever (tc electronic) STRUM tempo which is far better and way more accurate than any tap tempo. You can choose between them, and it has a switch at the front that divides the tempo into half dotted 8s and so on.
  17. dombar335
    Pennsylvania
  18. Ecadad
    Ecadad Tele-Holic
    I second this. Best Delay pedal I've ever had on my board. Worth every penny and easy to find at a decent price used. Tons of usable settings (DD, Mod, Memory Man, Tape, Shimmer...), tap tempo, one button to switch to dotted 8, if you want to get really into it you can edit all the parameters of most the delays. Probably the most pedal in something that small and affordable and high quality available. I love it- I might add a second Canyon to my board...
  19. Daytona.57
    Daytona.57 TDPRI Member
    Calabogie, On, Canada
    Diamond Counterpoint, has galloping eights with subtle rhythmic blended quarter notes and tap tempo.
    Simple and straightforward.
    YMMV
  20. die Fliege
    die Fliege TDPRI Member
    Planet Earth
    I would recommend the TC Electronic Flashback. I’ve seen them on reverb s low as $120.
