Join TDPRI Today
Dang...
Discussion in 'Tele Home Depot' started by Deed_Poll, Dec 23, 2013.
  1. Deed_Poll
    Deed_Poll Tele-Meister
    281
    Feb 8, 2013
    Brighton, UK
    I was just test fitting my Schaller ST-6 tuners on my USACG neck and… well, I'll let the pictures do the talking.
    So what the hell? I'm pretty damn sure the USACG holes aren't the problem, I've never had this issue before. But it's my first time using trapezoid type tuners… Do they take a different hole spacing? Surely not…
    So what on earth do I do now? Get in contact with Schaller? Gawd almighty…
  2. guitarbuilder
    guitarbuilder Doctor of Teleocity Ad Free Member
    Mar 30, 2003
    I think you look at the dimensions on the peghead holes and get a different brand. The tuners are no doubt fine as is.
    An excerpt from the link below:
    kylek35010-15-2008, 06:38 PM
    I talked with Tommy @ USACG. He only has the vintage spacing (non "F" tuners). He said that if that what's you want, he will provide a blank head for you to drill yourself.
    http://www.thegearpage.net/board/archive/index.php/t-451890.html
  3. Deed_Poll
    281
    Feb 8, 2013
    Brighton, UK
    Thanks for the link. Yeah it looks like that's my only option, I don't think there's enough spare material to grind them down even.
    It'a a bit of a shame as I'm really going for a '70s aesthetic with this build. Does anyone have any suggestions? Will Klusons fit a 10mm hole if it comes to it?
    Cheers
  5. R. Stratenstein
    R. Stratenstein Doctor of Teleocity
    Aug 3, 2010
    Loganville, Ga.
    Bummer. I agree with you, you'd grind right into the mounting holes if you tried to grind them to fit. Best to find the closest tuners you can, that fit, and will have maybe some of the aesthetic you're looking for. StewMac sells "conversion" tuner ferrules that, if I recall correctly, will allow you to use Klusons or Gotoh look-alikes in 10mm holes.
  6. Deed_Poll
    281
    Feb 8, 2013
    Brighton, UK
    Cheers Stratenstein, it's good to know there are ferrules out there if I completely bugger this up… but I'm going to have a go at grinding them. Welp!
    What I'll have to do is cut a bit of wood, screw another piece in at the appropriate angle then I can line all the casings up, with the screws into the wood (on the back side), butted up to the piece I screw on. Then I can very carefully run this flat back and forth along the grinder to make sure the amount / angle is the same.
    I figure even if I do wear into the holes a little it won't matter too much as the heads of the screws should cover this up - and the fact each tuner has 2 screws should mean that the tuner is nevertheless located properly. If that fails I have a spare set of Klusons and will buy the ferrules.
    Thanks
  7. R. Stratenstein
    Aug 3, 2010
    Loganville, Ga.
    You're a braver man than I, :eek: DP, in any case it will be a close-run thing, and I wish you the best. for better or worse, let us know how it comes out.
  8. guitarbuilder
    Mar 30, 2003
    Why screw up a set of tuners you can use on another guitar? That makes no sense to me when you have klusons available. It's not like they'll be "period" correct after the grinding.....
  9. Deed_Poll
    281
    Feb 8, 2013
    Brighton, UK
    I understand your concerns, and I know it's far from vintage correct - owing in large part to the fact that the body will be Jazzmaster inspired! So even though I get the big stuff wrong, I like all the little details to be just right. I even got the headstock sprayed with an extra layer of tint to imitate the '70s pegheads.
    I agree the tuners won't be vintage correct when I've ground them down but I only need to take 1/2 or 3/4 of a mm off each side. What I want to keep is the Trapezoid shape as I feel it is very evocative of a '70s aesthetic.
