Danelectro style Tele Build
Discussion in 'Tele Home Depot' started by sjohnbruton, Jun 1, 2012.
  1. sjohnbruton
    sjohnbruton Tele-Holic
    900
    Aug 13, 2009
    Mobile, AL
    My recent (ill-timed) attempt at the 2012 Build Challenge
    (located here) was to be a hybrid of a Tele and several design elements of Danelectro guitars.
    Ever since I played a copper colored Silvertone like this one
    I have wanted to own one. The guy who had it flat refused to sell it, by the way.
    So, using Dano the style of construction of a plywood frame capped top and back with hardboard, like these,
    my intent is to make a light weight, very resonant, mojo loaded, retro style, bad-ass of a Tele. :D
  2. sjohnbruton
    900
    Aug 13, 2009
    Mobile, AL
    I want the hollow body, sound hole, and front pickup of the Convertible,
    the pickguard of the 59,
    and the dolphin nose of the U series.
    It also will have a Fender style nut in aluminum (like a Dano). Throw in some wide vinyl edge banding and the finished product will look very similar to this:
    bricksnbeatles likes this.
  3. sjohnbruton
    900
    Aug 13, 2009
    Mobile, AL
    The first step is the body.
    Instead of using the cheapest available, I went "all-out" and bought a sheet of 1/2" Birch ply. I then cut this full sheet into fifteen 16x19 panels. Following the same process, I cut a sheet of 3/16" hardboard into the same size pieces.
    Once I had these panels, I face glued three of them together to get an over all thickness of 1.5" Sadly, my inexperience shined brightly and the resulting blank was badly warped due to crappy cauls...
    The second attempt was successful when I realized I could screw the panels together since the ply core was not going to be visible in the finished product. I ended up with this:
    I then rough cut the blank to shape on my benchtop bandsaw.
  4. Tonetele
    Tonetele Friend of Leo's
    Jun 2, 2009
    South Australia
    I bought my then 14 year old son a Danelectro re-issue U-2, Les Paul shape two p/ups, in the early 90'2. I play it now as part of my colection and won't part with it. Love those "lipstick p/up". Apparently Dan Erlewine collects the old ones and his Brown U-2 is his personal favourite. I'd love to get a double cutaway Like Jimmy page used. Good choice for a build sjohnbruton!
  5. sjohnbruton
    900
    Aug 13, 2009
    Mobile, AL
    Next up - pattern routing!
    Since the blank is too thick for my 1" bit, I need to do two passes. First up is the top-bearing-that-really-is-a-bottom-bearing-when-its-in-the-router-table bit:
    Then, flip and repeat with the opposite bit:
    Since I want a soundhole, I can't use a center block that extends from the neck pocket to the bridge. I do, however, want a bit more rigidity than the "island" bridge block of the Convertible. So, I decided to attach the island block to the frame with a narrow strip running from the end pin to the bridge.
    To cut the inner cavity of the body, I first used several sizes of Forstner bits to drill out the inner corners of the pattern.
    I then played "connect the dots" with my jig saw.
    Here is the rough cut body core:
    I decided to leave enough material for a mild arm contour. Here she is after knocking off most of the interior saw marks with an 80 grit sanding drum.
    Ready for hardboard!
    FYI: I can totally see why Danelectro used these materials and construction methods. Even upgrading to birch ply, I spent a total of $60 for the plywood and hardboard combined. When cut to 16x19 and processed into blanks, I will get 5 finished bodies and still have hardboard left over. That's only $12 a body!! Gotta love that. :cool:
  6. sjohnbruton
    900
    Aug 13, 2009
    Mobile, AL
    Thanks, I hope it turns out half as cool as a real Dano! Those lipstick pups do sound great. For this one I'm sticking with Tele pups and electronics, though. Mostly because this is kind-of an experiment (prototype) and I already have the Tele setup. Oh, and I'm cheap, too! ;)
  7. Doc Rorick
    Doc Rorick TDPRI Member
    97
    Mar 14, 2012
    Napa, CA
    I love it. The convertible sound hole will be aces.
    You're making me itch to start a hollow-body build before I'm done with my current (maiden) solid body effort.
    Dig the ply method, too!
  8. Mike Simpson
    Mar 19, 2006
    Gilbert, AZ (PHX)
    Didn't Dano use pine instead of plywood for the center?
  9. Greg M
    Greg M Tele-Holic
    857
    Sep 4, 2003
    Virginia
    This will be a cool build to watch. I had intended to do a Dano-style build at some time but ended up forgoing the hardboard for plywood. Good luck on the rest of the build.
    Guitarbuilder: that is some mojo right there! :D
  10. Picton
    Picton Friend of Leo's
    Feb 7, 2009
    Reading, Massachusetts
    I did one of these last year with a polycarbonate cutting board instead of a top layer of hardboard; they're a blast to make, and I'll echo what everyone else has said about the lipstick pup. It's my favorite pickup. The GFS low-output versions sound great, especially wired in series.
    I hadn't thought of stacking plywood; I just pieced together offcuts of poplar, plus some mahogany (for the bridge island). Since they were all pieces I just had lying around, the body cost something like $28.
    Nice build!
  11. sjohnbruton
    900
    Aug 13, 2009
    Mobile, AL
    Thanks. I'm hoping it works out like I imagine... :lol:
    Honestly, I'm not entirely sure. Best I could figure out (without too much research), is that some were pine ply and some were pieces of solid pine. Truth is I don't really know.
    Cool! That would be pretty slick... I'm not sure about a 23.5" scale though. I've never heard of a Dano that short. Of course, what do I know? :confused:
    Thanks, I'm gonna need the luck! And all the extra time I can find laying around. Too bad you can't but that on ebay...
    Thanks. Sweet build, BTW. I love using out of the ordinary materials for stuff like this. What did you use for the edge banding? I think I saw you mention wallpaper? I've decided to go with vinyl shelf liner...
    I'm definitely going lipstick on the next one. They are one of my faves, too! ;)
  12. Picton
    Feb 7, 2009
    Yeah, I just cut some wallpaper into strips. I found a sample that matched the off-white of the back; it had a nifty texture, too. Yellow glue and a coating of epoxy took care of it.
  13. stinkey
    stinkey Tele-Afflicted
    Apr 4, 2010
    malmö sweden
    Love it so far.
    I have had an similar idea, but you'rs better so i'll rip it, if thats OK with you.
  14. sjohnbruton
    900
    Aug 13, 2009
    Mobile, AL
    Nice idea. I'm hoping the vinyl won't require any top coat.
    I heard a quote once that went like this: "If you steal from me, you're stealing twice!" - No worries. :p
  15. Walter Broes
    Walter Broes Tele-Afflicted
    Antwerp, Belgium
    Cool project! As far as I know, the reissues are/were ply core, the originals several pieces of solid wood.
  16. fezz parka
    fezz parka ---------------------------
    I think they used Poplar...
    I love this build. Very cool.
  17. crazydave911
    Feb 23, 2010
    East Tennessee
    If that's accurate, not many were. Most were 25" scale (Danelectro built) except for the original Pro, which was 21". FWIW, 23.5" is very playable and sounds cool with modern pups, but seeing your pup selection, 25.5 or 25 would be better. For those that have never tried one, a 25" scale is very versatile, just play a PRS sometime ;)
    Here ya' go LINK, the humbuckers are a gas. I wired them in series with a shorting switch for single-coil, then a single coil tube in the neck position for a friend's Squier 51.................I've been trying to buy it from him ever since :lol:
  18. jeremyb
    jeremyb Tele-Meister
    175
    Jun 23, 2009
    Chch, NZ
    Loving this build!!
  19. chuck_zc
    chuck_zc Tele-Meister
    436
    Feb 25, 2006
    Newfoundland Canada
    I have lipsticks and pots lol!
