D-Size Tele Body Blueprint Files HERE
Discussion in 'Tele Home Depot' started by tdowns, Apr 27, 2007.
  1. yazam2014
    yazam2014 Tele-Meister
    malaysia
    reading this thread make me want to make my own tele:) But I'm "0" in this area.
    Ok..... If i print terry's tele drawing...... so i just attached to the wood and cut it ...is it?
  2. Stroudy
    Stroudy TDPRI Member
    Peachtree City, GA
    Typically, most people would print out the drawing full size and glue that to MDF (medium-density-fibreboard) using spray adhesive. They would then cut this out and shape it, then use this as a routing template for their actual wood.
    A great place for beginners to... begin... is the challenge build subforums. Usually the entire build is documented in the contender's thread, and there is a lot of great info. Good luck!
  3. yazam2014
    malaysia
    Tq
  4. burninwordz
    burninwordz TDPRI Member
    isabela puerto rico
    JMo426,thanks for the reply ,but can you verify with your template if my measurements are right,thanks
  5. JMo426
    JMo426 TDPRI Member
    Chicago, IL
    When I draw something up in CAD, I can get measurements accurate to five decimal points and better. But no matter how accurate the CAD file is, when it's printed, it could end up being off. The first drawings I had printed out were out of scale and I had to have them make sure all the settings on their plotter were set right and had them do it again. They got it right the second time. Precise accuracy is one reason plotters aren't as cheap as printers.
    I can't verify the measurement you gave because I don't know where it was made. If you give me the exact location, I can tell you what the CAD drawing measures at that point, but how it was plotted on your drawing, only you know.
    There are not a lot of critical measurements in making a clone, unless you're trying to pass it off as the real thing. But if you want it to play right, there are very few measurements that need to be dead-on accurate. Even the scale length doesn't have to be dead-on as long as you can make up the difference in saddle adjustment.
    But getting back to properly scaled drawings, I put a 1" x 1" box on my drawings for scale verification. If you'd like, I could take Terry's CAD drawing and do the same. That way all you have to do is check the 1x1 box. If that's right, everything else should be right, unless the plotter isn't working properly.
    Julie
  6. CustomWerx
    CustomWerx Tele-Meister
    Fairfield Bay, AR..USA..
    i have downloaded the template from here before, but now the link isn't working? any ideas?
    i can attach it, perhaps?
  7. nickhofen
    nickhofen Friend of Leo's
    HELLAS, Land Of Heroes .
    Try again, it works fine for me, I just download it again.
  8. ricky1918
    ricky1918 TDPRI Member
    Italy
    Can someone please post CAD files of a telecaster body? previously posted download links do not work!!
    Thanks!
  9. Glen Smith
    Glen Smith RIP
  10. LeroyBlues
    LeroyBlues Tele-Holic
    Michigan
    Have the links to the drawings, Terry's, been removed, or hacked?
    I'm talking about the ones on the very first page of this thread. I've downloaded them in the past, with no problems, but today, when I'm trying to help a friend get them, it sends me off to another web page.
  11. guitarbuilder
  12. Glen Smith
    Glen Smith RIP
  13. Mialn
    Mialn NEW MEMBER!
    rotterdam
    blueprints or the CAD files of a Fender Thinline '69
    Hello, I'm new to this forum so i don't know if this the right place but so...
    Does someone have and want to share the blueprints or the CAD files of a Fender Thinline '69? I am trying to build one, so i need some dimentions obviously :)
    Thanks
  14. tt8
    tt8 TDPRI Member Silver Supporter
  15. Glen Smith
    Glen Smith RIP
    The link I posted is for the E rev.
  16. katsbls
    katsbls NEW MEMBER!
    Clayton, CA
    Hi, I new here and building my first Telecaster, I bought a kit but the head stock is the weird square shape. I am looking for a template to cut it to the 50's Telecaster shape. I tryed the link for the plans and get an advertivement. I am doing something wrong? Or is there a different link?
    Thanks
  17. barbrainy
    barbrainy RIP
    Northampton, UK
    https://sites.google.com/site/guitarplanscollection/pdf-files/fender-ish
    That'll do you.
  18. guitarbuilder
  19. Stratmech22
    Stratmech22 NEW MEMBER!
    Baltimore
    Hello Terry,
    I see your the guy to talk to about plans. I am building my first tele. I have a beautiful 1 piece curly cherry body with aflame maple top. I've also hollowed it out before gluing the cap on. What I need now is a scale / printable tele neck plan. Do you know where I could find one? Any help would be greatly appreciated. Thank you so much
  20. Glen Smith
    Glen Smith RIP
    This thread contains several neck pdf's.
