CV Tele-- no treble bleed capacitor?
Discussion in 'Telecaster Discussion Forum' started by wpkg, Jul 24, 2008.
  1. wpkg
    wpkg TDPRI Member
    Bloomfield, NJ, baby.
    Hi,
    I just opened up the control plate on my CV tele to tighten up the jack cup, (its now crooked and still loosening up again) and saw that there was no treble bleed capacitor on the volume pot. I thought this was a standard tele thing. are they not on any teles any more or just this model? I will put one on as it did wonders for my LP, but was curious as to whether or not this was no longer a standard tele thing.
    and since im going to operate... will cts pots fit through this control plate and into the stock knobs? and what value should my treble bleed cap be for single coils? it was .001 for humbuckers...
    thanks!
  2. cotecj
    cotecj Tele-Holic
    I don't think any Telecasters come stock with a treble bleed cap. I would highly recommend doing the "50's mod". Do a search on this site and you will find tons of info. You move the tone control from the input of the volume pot to the output. It eliminates the treble cut when turning the volume down, and I feel it makes the tone control more sensitive. Plus, you only have to move one wire, no added components.
  3. wpkg
    wpkg TDPRI Member
    so it does the same thing as a treble bleed cap? that sounds cool. i will check it out... thanks
  4. Mark Davis
    Mark Davis Telefied Ad Free Member
    Bakersfield Ca.
    I think the HWY1's come stock with a treble bleed Fender calls it the greasebucket but its really just a treble bleed mod.
  5. cotecj
    cotecj Tele-Holic
    No, the greasebucket is a different tone circuit. It has a second capacitor and a different arrangement of the tone pot to give a steeper curve to the treble cutoff. No treble bleed cap there.
    http://www.tdpri.com/forum/tele-tech/100934-greasebucket-tone-control.html
  6. Mark Davis
    Bakersfield Ca.
  7. Twang Tone
    Twang Tone Friend of Leo's
    Hey cotecj, As you suggested, I did a search for '50's mod' on this site and either got no matches or way too much info regarding the '50's Classic Tele!
    Is there a wiring diagram that exists of the mod you descibe? I'd like to give it a go on my oldest '52RI. I've always left the little ic503Z cap in there, but would like the idea of 'treble bleed' on the volume if the '50's mod' works.
    Also, does the .022uF mylar cap that comes with the AV52 do the same job? (i.e. retain treble frequencies when you roll the volume down).
    Thanks,
  8. tonyguitargoat
    tonyguitargoat Tele-Meister
    I've now done the "50's" mod on nearly all my guitars - Fenders, Gibsons and others, and love it. I can't believe I've spent over 30 years fiddling about with treble-bleed caps and resistors trying to compensate for treble loss, only to find that different values were needed for different pickups, different amps, and different cables (!). This mod is SO easy, and makes perfect sense - putting the tone cap AFTER you've dropped the level, not before. Why didn't I discover this years ago?
  9. Scotland
    Scotland Poster Extraordinaire
    Aberdeen, Scotland, Yewrup
  10. wpkg
    wpkg TDPRI Member
  11. cotecj
    cotecj Tele-Holic
    What this diagram does not show is that, on a stock tele, the wire represented by the red line goes from the top (in the picture) lug of the tone pot to the top lug of the volume pot. You are going to move it to the middle lug on the volume pot, as indicated.
  12. Twang Tone
    That's great cotecj, thanks!
    Scotland, thanks for the diagram!
    Thanks,
  13. ProToneThinline
    ProToneThinline Tele-Holic
    Pittsburgh, PA
    I just did this mod to my Squier Standard Tele. It works GREAT!!!
    Thanks!!!!!!!!!!!
  14. TeleHH
    TeleHH TDPRI Member
    Waldo, WI.
    Works On a HH Too!
    Hey, I just did this mod on my Tele HH...! Works great! I had used a
    .001 treble bleed setup and it was ok but seemed to suck a slight amount of tone I wanted, so I removed it. This works sweet and as someone else commented, 'makes so much sense'
  15. Doug Ferguson
    Doug Ferguson Friend of Leo's
    Indianapolis, IN
    IMHO, this mod's better than a bleed cap. I run it on one of my tele's. The others have neither bleed caps nor the fezz parka, since I tend to run the vol. wide open all the time.
  16. Home Grown Tele
    Home Grown Tele Tele-Holic
    The Queens
    Do yourself a favor and change that stock jack out to an Electrosocket. You'll eliminate the headches you are now experiencing!
  17. Guitar_Ninja
    Guitar_Ninja Friend of Leo's Ad Free Member
    Saskatoon, Saskatchewan
    The only thing with that mod is that the tone and volume pot end up having a weird interaction where the tone pot will actually roll off volume as you turn it down.
    Some people don't mind it or even like it but to me it was annoying. I switched over to Gibson 50's wiring instead:
    Just something to be aware of.
  18. wpkg
    wpkg TDPRI Member
    this is the same thing but with the tone cap in line between the two pots right? wouldnt this also cause Tone to roll of Volume?
  19. Guitar_Ninja
    It doesn't seem to, though I suppose I could be hearing things.
    I'm not great with schematics so someone please pipe in if any of these are wrong, but the difference between the two seems to be the location of the tone cap in the circuit:
    Like I said, I'm not great with electrical schematics or electrical logic in general, but with both mods the circuit is altered such that the signal travels through the volume pot and then exits into the tone circuit. With the Fezz Parka mod the signal seems to travel through the tone pot first and the output of the tone pot then goes through the cap to ground. Whereas with the 50's mod you change the wiring of the tone pot such that the signal travels through the cap first, then enters and exits the tone pot to ground.
    Now electrically speaking I have no real idea what the difference is, if any, but there certainly seems to be a difference to me.
    Edit: I suppose it should say "from switch" but I'm too lazy to change it now.
  20. fezz parka
    fezz parka ---------------------------
    Del Floria's Tailor Shop
    This'll do it to.
    I just do the other one 'cuz it involves moving just one wire, and I kind of like what it does with the volume rollof thing. It accentuates the "wah" thing when you roll it up. YMMV.:D
