Custom 50's style Flying V
Discussion in 'Tele Home Depot' started by joekumpan3, Jan 3, 2017.
  1. awasson
    awasson Friend of Leo's Gold Supporter
    Vancouver
    Regarding that fuzzy volume concern... I'd pull the tone stack out of the circuit entirely and just have the volume pots connected. See how the volume control acts when it's just pickups, selector switch, volume pots and output jack. That will tell you a lot.
    I had a volume pot go squirrelly recently and because it was still in circuit with the tones (Strat wiring), I couldn't tell where the issue was. I eventually figured it out but it was a weird one.
  2. joekumpan3
    joekumpan3 Friend of Leo's
    Kaneohe Hawaii
    A few photos IMG_4498.JPG IMG_4499.JPG IMG_4500.JPG IMG_4502.JPG IMG_4503.JPG
    fenderchamp, Southpole and Zepfan like this.
  3. awasson
    Vancouver
    Wow! That's another beautiful guitar you've built. A real piece of art.
  4. joekumpan3
    Kaneohe Hawaii
    Thank you, I think it being korina/limba it gives it a neat depth to it. It definitely looks best in the light!
  5. oldrebel
    oldrebel Friend of Leo's Gold Supporter
    Lynchburg Tennessee
    Great job Joe!!
  6. joekumpan3
    Kaneohe Hawaii
    That is a good idea, if I am not satisfied with the treble bleed I might try that. It's not that bad, but it does get bassy really quick when I roll the volume down. The humbucker is less dramatic than the p90 and the humbucker also has the split/parallel switch which I'm liking, it's like a treble booster. I really just would like the tone not consistant as the volume goes lower. Anyway we will see, in going to alagator clip the treble bleed in first. It sucks waiting for parts though.
  7. joekumpan3
    Kaneohe Hawaii
    Thank you sir!
  8. Revv23
    Revv23 Friend of Leo's
    Michigan
    That finish out came great!
  9. zorgzorg2
    zorgzorg2 Tele-Meister
    Norrköping, Sweden
    Nice build ! I heard somewhere that too much treble from the pu can be that the magnets are too strong, so one would degauss them a bit...
  10. joekumpan3
    Kaneohe Hawaii
    Thanks, it's got some spots but it looks ok, I like the color.
  11. joekumpan3
    Kaneohe Hawaii
    Thank you. Actually I need treble, as soon as the volume gets to about 8 1/2 it sounds like a blanket over the amp. The mod should help that.
  12. joekumpan3
    Kaneohe Hawaii
  13. joekumpan3
    Kaneohe Hawaii
  14. joekumpan3
    Kaneohe Hawaii
    I soldered and bent them up to go into the cavity, I also put some tape and the inside sleeve of some pullback wire on them. IMG_4531.JPG
    I had to undo the zip ties to temporarily get around the wiring. I had to wiggle and cuss a little to get them just right. Here is the neck installed. IMG_4532.JPG
    There isn't a lot of room but it will work.
    Here is the bridge installed. I'll put the zip ties back on and cram everything back in. I probably could have stood to use small ceramic disc capacitors here but that's no fun!
    Southpole likes this.
  15. sgt.minor
    sgt.minor NEW MEMBER!
    Hamburg Germany
    Resitence is futile ;-))
    joekumpan3 likes this.
  16. joekumpan3
    Kaneohe Hawaii
    Here it is next to the V made from the other half of the wood. When I bought lumber I got enough to make two the second one took a long time but it is cool. IMG_4536.JPG
    The last thing I need to do is put the strap locks on, they should be here tomorrow.
    Snfoilhat and Southpole like this.
  17. sgt.minor
    Hamburg Germany
    Sorry, I couldn't resist.
    I know that it's a bit shady for a first post ...
    E.
    fenderchamp likes this.
  18. Lupo
    Lupo Tele-Holic
    Genova-Italy
    Sorry fro the stupid question, but... why the resistor connected in that fashion? Are you going to cut then the capacitor lead? Otherwise it would be completely short circuited and the resulting treble bleed would be the "simple" an no the "kinmann" in spite of the presence of the resistor.
  19. joekumpan3
    Kaneohe Hawaii
    No problem. Welcome to Tdpri!
  20. joekumpan3
    Kaneohe Hawaii
    Hey, I didn't really think about that. Thanks. I'll go in and cut the wire out from between the resistor, that should fix it. Thought I being fancy, I forgot it has to go through it, then through the cap. Thanks again.
