CS 356ish build
Discussion in 'Tele Home Depot' started by 1bad914, Apr 11, 2019.
  1. 1bad914
    1bad914 Tele-Meister
    Michigan
    It has been awhile since I worked on the. I started to route the terraces on the back. Trying to perfect the method. It is not perfect, but it will work. I have the final top route to do now. It is very light. FADC1CF3-1C83-46CB-8FB2-E51D01BF657F.jpeg 11F7143D-2D69-4F63-B197-7E3435AE5B1D.jpeg
    Ekko likes this.
  2. 1bad914
    Michigan
    Well. I did not think this all the way through. After I used the last template. I measured and realized that I need to make one more 1/8 inch cut for the remaining middle flat spot. So Mr. Brain Bucket (me) decided I could do it on the router table. Think about that for a second.....
  3. 1bad914
    Michigan
    Bit sticking out of the table 1/8 inch, run the body over the bit back and forth. Think about it....who can figure out what happened? This is what happens when you don’t think things through and work on something on 4 hours sleep.
  4. 1bad914
    Michigan
    Good news is that it is recoverable. I will post pics once someone can point out my stupidity. Sigh.
    nnieman likes this.
  5. Freeman Keller
    Freeman Keller Tele-Holic
    When I did my lester I just ran two "terraces" - one at the recurve and one just slightly higher. I then just simply carved the top with chisels and planes doing the shape by hand and by eye. Its not a perfect gibson curve but it looks and feels pretty good. The terrace is probably much more accurate, I'll keep watching.
    1bad914 likes this.
  6. 1bad914
    Michigan
    If you look you can see the screws. This is the bottom. That should not be there, but I made a conscious decision to do it as the attempt at using two way tape was a total failure. It would not hold at all. Not sure why, but ver little adhesion even after a good cleaning. So now I plug 2 holes. Sigh. No guess on the big mess up?
  7. Freeman Keller
    Bad, I don't trust double stick tape at all and I always back it up with either flat head screws into some part of the guitar which will go away (neck and p/u pockets on the top) or I try to add some clamps to back up the tape. I've never done a carved arched back but if I wanted to I would just route the recurve ledge and hand carve down to that like I did the top of my LP.
    Are you planning to bind the back? If so you probably should route that channel before you get too deeply into the arching or you will need to float the router (which is what I did on the pressed back guitars).
  8. Freeman Keller
    If I read that correctly, you didn't have the follower bearing against the template so you routed 1/8 off the template, not the back (or top or whatever it is you are working on). You should have had the bit sticking out of the table 7/8 with the bearing riding on the MDF.
  9. 1bad914
    Michigan
    Hard to explain so a visual may help. Shield your eyes. It is not pretty. Good news is that it is recoverable.
    81A970D5-2661-450E-B65C-7E4ED2582ADC.jpeg 75B384AD-665D-4244-9CDE-2A684B537668.jpeg
  10. 1bad914
    Michigan
    I should have used a router sled or planed it. Oh well. Lesson learned.
  11. Freeman Keller
    nnieman likes this.
  12. nnieman
    nnieman Tele-Meister
    ontario, canada
    Dude that could have been so much worse!!
    Nathan
    1bad914 likes this.
