Cracked neck on both sides of Les Paul... What to do?
Discussion in 'Other Guitars, other instruments' started by DrGnosis, May 21, 2019.
  1. DrGnosis
    DrGnosis TDPRI Member
    Reading, MA
    Greetings Gentlemen...
    I just noticed that my '11 Les Paul is cracked lightly on both sides of the neck (see pictures). I have no clue when or how it happened. The two cracks don't come close to meeting each other, but they are in the same place on both sides of the neck.
    I use this as my live guitar. Is this something that I should nip in the bud before it gets worse or just wait it out. Full disclosure: I LOVE this guitar.
    Any input, advice, or comments would be greatly appreciated.
  2. Chunkocaster
    In space with Ziggy
    It looks like it will likely break off completely in the near future. I would get some glue in there and clamp it if you can. Does it open up more when pulling on the headstock?
    Piggy Stu and nojazzhere like this.
  3. El Marin
    El Marin Tele-Holic
    Madrid, Spain, EU
    Does it opens when you pull back the headstock?
  4. Milspec
    Milspec Friend of Leo's
    Nebraska
    Welcome to the very large club of cracked Les Pauls. I had one crack just from sitting in the case years ago, it just comes with the territory. The good news is that they seem to break very cleanly and can be repaired. After that, they will be stronger than before and likely be a one and down affair.
    As to stopping it? I don't think you can. Might have to play it until it breaks away and then repair it.
  5. DrGnosis
    Reading, MA
    No, it does not open when you pull back on the headstock. It's pretty tight.
  6. Cysquatch
    Cysquatch Tele-Meister
    Grovetown, GA
    If if opens when you pull back on the headstock, get some Titebond in there and clamp it down. Otherwise, either play it until it does start opening up, or take it to a good luthier and see if they can fix it before the fact.
    At this point, I'm half convinced Gibson leadership has stock in Titebond.
  7. Chunkocaster
    In space with Ziggy
    I think if it was mine I would make a jig up to support the neck and try to open the gap enough to get a decent amount of titebond in there without breaking it off completely. Then clamp it up and let it set.
    nojazzhere and verb boten like this.
  8. Artunes
    Artunes Tele-Meister
    Oshkosh, B'gosh
    Isn't that an odd place for a headstock break? Most breaks that I've seen are in the other direction:
    You can see that the string tension pulls the break apart in these two examples.
    The OP's guitar is breaking as if the string tension is keeping it together. Odd.
    DonM, hellopike and Sev112 like this.
  9. hrstrat57
    hrstrat57 Tele-Afflicted
    Rhode Island
    You’re in Reading, MA
    I’d make an appointment with Noll Guitar in Cranston for an evaluation now.
    Good luck!
    hdvades and jim777 like this.
  10. viking
    viking Friend of Leo's
    Denmark
    That kind of break is very common , too
    jvin248 likes this.
  11. jondanger
    jondanger Poster Extraordinaire
    Charm City, MD
  12. schmee
    schmee Poster Extraordinaire
    On that I would use hobby shop (or any I suppose) 5-10 second glue. It wicks into cracks very well and is very strong. (Same glue used for frets) Tape off the surrounding area, it attacks finish, apply glue liberally (watch for runs... it's thin!) Clamp tight. It looks like you could use a Capo or two for clamping maybe if you have the kind that are strong. Otherwise figure out a clamping arrangement before you glue. Let it harden for a while. Then sand excess smooth.
    DonM likes this.
  13. Artunes
    Oshkosh, B'gosh
    If you loosen the strings, you may be able to open the cracks up a little to get the glue in.
    DonM and Jerry_Mountains like this.
  14. charlie chitlin
    Spring City, Pa
    It's one of those jobs that appears huge and daunting, but is very simple.
    It has to be done right the first time, or you're screwed.
    Because it seems like such a big deal, many will charge big money to do it, when, in fact, someone who really knows what they're doing can get it done in about 20 minutes; which includes assessing it and fishing out the proper tools/supplies.
    I figure a scrupulous repair person should charge 60-$75 for such a job.
  15. jim777
    jim777 Tele-Meister
    South New Jersey
    If it were my guitar, and I really liked it, I would bring it to a pro to repair. Isn't Mouradian up around Wilmington? I would bring it to him before playing it again, but that's just me.
  16. Milspec
    Nebraska
    The concern that I would have with trying to push some adhesives into the crack is that if it fails, fixing the repair will be that much tougher due to the glue bed.
    It is a Les Paul and cracking headstocks have been a trademark of that guitar as much as the sound is so luthiers have a lot of experience repairing them. I wouldn't be surprised if that was the first repair work that they start out learning since it is so common. I would not go with the DIY route here, hand it off to a luthier who will likely view it as something very simple.
    horseman308 likes this.
  17. nvilletele
    nvilletele Friend of Leo's
    California
    There is only one correct answer to the question “What to do?”
    Get. A. Tele.
    ‘nuf sed.
  18. StrangerNY
    StrangerNY Friend of Leo's Gold Supporter
    Long Island, New York
    Yeah, I noticed that, too. Looks like it's cracking in the totally wrong direction.
    - D
  19. Artunes
    Oshkosh, B'gosh
    I'm still trying to wrap my head around it. What sort of physical force would cause a break like this. It had to have been a force from the front of the headstock, and pretty good one, to cause it to break the way it did.
    StrangerNY likes this.
  20. harold h
    harold h Friend of Leo's
    If it wont open up enough to get glue in there, then you can use superglue on
    the crack in place of Titebond.
    Superglue wicks into cracks and doesnt require the crack to be wedged open
    in order to work.
