COMPLETED - XxJoshxX's Plain ol' tele
Discussion in '2014 TDPRI Tele Build Challenge' started by XxJoshxX, Mar 1, 2014.
  1. XxJoshxX
    XxJoshxX Tele-Holic
    FLORIDA
    Or maybe not :twisted:
  2. TeleSky
    TeleSky Tele-Holic
    Highland, Utah
    Was that plain or plane? Or un-plain?
  3. DrASATele
    North of Boston
    Good luck!
  4. jim the plumber
    jim the plumber Tele-Holic
    muskoka ont. ca.
    good luck
  5. BluesBlooded
    BluesBlooded Friend of Leo's
    Sherbrooke, Qc, Canada
    Good luck Josh! Will be watching what you have in mind!
  6. kissTheApex
    kissTheApex Tele-Afflicted
    Silver Spring, MD
    Good luck Josh
  7. XxJoshxX
    XxJoshxX Tele-Holic
    FLORIDA
    Thanks guys!
    Specs:
    Double F-hole Thinline
    26.5 scale
    Set neck
    Walnut Body
    Zebrawood top
    Walnut or maple neck
    Wenge fretboard
    Cream soapbar p90s
    Would it be against the rules to use pre-cut inlays?
  8. XxJoshxX
    XxJoshxX Tele-Holic
    FLORIDA
    My proof of start is weak, I still dont have my walnut.
    Ooh zebrawood
    Fretboard template attached
    Heres a little trick I learned to make a fretboard quickly.
    Take a piece of Mdf with one straight side
    And run it thru the table saw
    Without moving the fence, line up the edges of the fretboard with the end of the mdf, and run It through
    Repeat
    Sanded
  9. oldrebel
    oldrebel Friend of Leo's Gold Supporter
    Lynchburg Tennessee
    Okay, good start!!!
  10. XxJoshxX
    XxJoshxX Tele-Holic
    FLORIDA
    Would precut inlays be allowed?
  11. Deegatron
    Deegatron Tele-Meister
    Alberta, Canada
    I would suspect this would cross the line as "not doing all the work yourself" but you could make an argument that it's no different than using precut pearl dots... and nobody cuts their own pearl dots... totally grey area dude....
  12. barbrainy
    barbrainy RIP
    Northampton, UK
    Hmmmmm. Already a debate on the rules.
    I must admit, I thought this was an easy 'yes, it's fine'. But now I've read the rules again, I'm not so sure.....
    There's one obvious way to be on the safe side.....
  13. XxJoshxX
    XxJoshxX Tele-Holic
    FLORIDA
    I went ahead and did it, If it isnt allowed, Ill use a different fretboard
    So after an hour of drilling and chiseling I have this
    But It doesnt look so bad with the inlay in
  14. nosmo
    nosmo Friend of Leo's
    Lake Jackson, TX
    Don't see why not. Do the rules say you have to cut your own?
    I plan on using precut saddles on my bridge and I'm not too worried about that :lol:
  15. XxJoshxX
    XxJoshxX Tele-Holic
    FLORIDA
    Thanks for the reassurance.
    I chiseled out the second inlay and it actually turned out quite well.
  16. R. Stratenstein
    Loganville, Ga.
    Sounds like this isn't going to be just a "plain" old Tele, but a pretty dang nice one. Looks good so far, Josh.
    I would have to agree with Nosmo, inlay pieces are something most of us buy already shaped --yes, a body could make them, or cut them out, but regular dots or trapezoids are usually purchased. And--the rules are moot regarding inlay fabrication, so I think you're good. Hope a moderator can chime in here before you get too far down the road so you'll know.
  17. XxJoshxX
    XxJoshxX Tele-Holic
    FLORIDA
    Thanks!
    The way I see it, the worst case scenario is to use a different fretboard, I dont think I would get DQd over fretboard inlays.
  18. XxJoshxX
    XxJoshxX Tele-Holic
    FLORIDA
    Mo wood.
    Resawed the zebrawood
    In fifth period today I thought about what I really wanted for this guitar. I decided I wanted It to be light and comfortable, but I dont feel up for a thinline with contours. The plan is to make it a really thin. It should rnd up around 1 1/4".
  19. DesmoDog
    DesmoDog Tele-Afflicted
    SE Michigan, USA
    Just make sure that leaves enough depth for your controls. A body that thin might rule out using a typical Tele style 3 way switch, you may have to go with a toggle or something that is shallow enough to fit in a 1" deep hole. (Assuming you leave 1/4 for the bottom surface)
  20. XxJoshxX
    XxJoshxX Tele-Holic
    FLORIDA
    I was already planning on a toggle switch, so that works out good
