COMPLETED - photondev's teleMira
Discussion in '2014 TDPRI Tele Build Challenge' started by photondev, Mar 1, 2014.
  1. photondev
    photondev Tele-Holic
    San Diego, CA
    Last year I accidentally made a smaller PRS Mira style template, and it has become one of my favorite bodies, I also am going to keep the costs as close to $0 as possible using wood and parts I already have. I am going for the most comfortable guitar in terms of weight and contours.
    mahogany body and maple top
    mahogany or maple set neck with rosewood fretboard
    pickups, need to decide between humbuckers, P90s, or some strat pups
  2. DrASATele
    North of Boston
    Good luck!
  3. photondev
    San Diego, CA
    thanks DrAsat - good luck to you to and to all other participants, wish I could start today :D
  4. kissTheApex
    kissTheApex Tele-Afflicted
    Silver Spring, MD
    Good luck!
  5. BluesBlooded
    BluesBlooded Friend of Leo's
    Sherbrooke, Qc, Canada
    This is going to be interesting to follow! Good luck
  6. photondev
    San Diego, CA
    thanks Apex and BluesBlodded - good luck to you too
  7. photondev
    San Diego, CA
    Here is the wood I will be using
    6/4 really light African mahogany for the body
    0.6 " lightly figured soft maple for the top
    Indian rosewood for the fretboard
    African mahogany for the neck
  8. nickhofen
    nickhofen Friend of Leo's
    HELLAS, Land Of Heroes .
    Good luck and have fun.
  9. photondev
    San Diego, CA
    thanks nick, I wondered whether you were going to participate this year
    preparing the body
    I made sure the template will fit within my measurements before cutting the body
    after cutting the two halves with a scroll saw, checked the joint and it looks pretty good, I am glad because I don't have a jointer, this supplier prepares the sides really cleanly
    getting it ready for the gluing
    clamped and ready
  10. photondev
    San Diego, CA
    working with the maple top
    after the two halves cut and checking the template fit
    the sides look great, no need again for a jointer :D
    gluing and clamping the top
  11. oldrebel
    oldrebel Friend of Leo's Gold Supporter
    Lynchburg Tennessee
    Looks like another great build. Good luck!!!
  12. nosmo
    nosmo Friend of Leo's
    Lake Jackson, TX
    I like that body shape.
  13. photondev
    San Diego, CA
    thanks oldrebel
    thanks nosmo, it is very close to an LP Jr., I find it very comfortable
  14. photondev
    San Diego, CA
    to comply with the Open class rules, I will be modifying the original Mira neck; it is a set neck with a 25" scale length, by only replacing the headstock with the tele headstock, as this:
    before deciding about the challenge's guitar, I did a mock-up with another project's body and a tele neck:
  15. Captain Nutslot
    Captain Nutslot Friend of Leo's
    Rochester, NY
    dig it!
  16. flatfive
    flatfive Friend of Leo's
    Monterey, CA
    Who doesn't like a comfy guitar? Anyway, I like that body
    shape a lot. With the woods you're using I expect it'll be
    beautiful.
    Are you going to do a one-piece neck, scarf joint, laminated, ...?
  17. photondev
    San Diego, CA
    thanks Captain
    thanks flatfive, looks like you are going to start your build
    the plan for the neck is one piece (two if you add the rosewood fretboard), no scarf joint since I am assuming that if I follow the tele neck construction, the height difference between the fretboard and headstock will give enough tension to keep the strings in place; since I will be using a wraparound bridge there needs to be an angle at the heel, I will compute that angle once I have the fretboard and the neck, but based on previous builds it should be somewhere around 2.5 - 3 degrees
  18. Deegatron
    Deegatron Tele-Meister
    Alberta, Canada
    You could always recess the wrap around bridge... would look totally bad ass and keep your angles nice and strait...
  19. photondev
    San Diego, CA
    thanks Deegatron for the suggestion - that will simplify things quite a bit, I am also considering this
  20. photondev
    San Diego, CA
    preparing to roughly cut the top and body
    relief cuts
