COMPLETED - Guitarbuilder's 2014 Monterey II Guitar
Discussion in '2014 TDPRI Tele Build Challenge' started by guitarbuilder, Mar 1, 2014.
  1. guitarbuilder
    Trim the lines back
  2. guitarbuilder
    The transition curve from the fretboard down to the peghead from the side view
  3. guitarbuilder
    A transition curve from the back of the neck to the peghead bottom surface along the centerline
  4. guitarbuilder
    Extrude out the a transition curve into a curved surface
  5. guitarbuilder
    trim back the peghead lines to that surface
  6. guitarbuilder
    I added a line across there and made the top of the peghead surface.
  7. guitarbuilder
    I went back and pasted in the outline of the peghead on the bottom...I deleted it earlier.
  8. guitarbuilder
    I split those lines apart because I needed the parts highlighted in yellow
  9. guitarbuilder
    Then I extruded those lines into the side surfaces of the peghead transitions
  10. guitarbuilder
    trimmed one side
  11. guitarbuilder
    and trimmed the other side
  12. guitarbuilder
    connected that surface to the previous surface...that's the top of the peghead
  13. guitarbuilder
    I split one side
  14. guitarbuilder
    and the other side to get rid of excess surface that I don't want
  15. guitarbuilder
    leaving me with this
  16. guitarbuilder
    I drew in an arc to the fretboard where the back of the neck starts to transition to the peghead
  17. guitarbuilder
    I drew another arc to the other end of the transition from the fretboard
  18. guitarbuilder
    I put a cutting plane through the neck shaft surfaces to split them at the transition point curve
  19. guitarbuilder
    I split and deleted the short section
  20. guitarbuilder
    Now I create a surface from all those lines...first one side
