COMPLETED - Guitarbuilder's 2014 Monterey II Guitar
Discussion in '2014 TDPRI Tele Build Challenge' started by guitarbuilder, Mar 1, 2014.
  1. thecableguy
    thecableguy Friend of Leo's
    Sherwood Park, Canada
    Cool concept Marty! Best of luck!
  2. guitarbuilder
    Thank you Sir! I guess I should do something on it today...LOL.
  3. guitarbuilder
    Found a corner of the basement to glue up the alder after jointing the surfaces. I had a remnant of another board I used years ago to add to make the 13+ width. Since I know my planer won't be capable of moving wood when it is 6 degrees out.... I'll let this dry and do something else.
  4. guitarbuilder
    Obligatory wild animal picture...that's Bert on the right....he likes to be close to you.
  5. guitarbuilder
    I had heard about the Murphs... and found this website. I love the Squire shape! Imagine a Squire before the Squier.
    http://www.murphguitars.com/
    OK...back to work.:)
  6. guitarbuilder
    Isolate the pickguard from the working drawing.
  7. guitarbuilder
    Took the pickguard and divided it into two toolpaths. One for the bevel and hole locations to be used with a pointed tool and the other is the pickguard cutout with the pickup and switch routs.
    The point of the bevel would follow the regular perimeter of the pickguard...I'll mark the holes too. This will not rout through the material... only about .075 deep...I hope.
    The switch routs and perimeter toolpath to be used with a 3/16" bit. This is offset half the tool diameter and you can see the path is below the line at the bottom as compared to the top drawing where it is right on the x axis.
  8. guitarbuilder
    I guess I should see if the CNC will fire up in the 7 degree F temp. and check what I will end up with in plywood before I waste any pickguard material.
  9. thecableguy
    Haha, that's awesome! Took me a minute to figure out that Bert is a canine. He looks nice n warm but he can still breathe! :lol:
  10. flatfive
    flatfive Friend of Leo's
    Monterey, CA
    I really like the design and scenario. The design looks
    great and looks totally plausible.
    But I wonder: in response to Hendrix's performance at
    Monterey, would Leo work on the tele?
    How many rock players were interested in teles in '67?
    What was the ratio of tele to strat sales among rock
    musicians? I see that as early as '67 Page and Beck
    were using teles; Harrison's rosewood tele was '68, I think.
    Also, I wonder: how widely-known and influential was Jimi's
    performance right after it happened in '67? If it was really
    big, would Leo focus on the tele?
    Not criticisms at all -- sincere questions.
    Nice Fender article on the two faces of the tele:
    http://www.fender.com/news/the-two-faces-of-the-telecaster/
  11. ItZaLLGooD
    ItZaLLGooD Tele-Holic
    northeast ohio
    Looks good so far. How are you getting the screen shots? I thought it would be cool to put up some of those in my thread.
    My thought was that I could cut the perimeter of my pickgaurd with an angled bit (60 or 90). I noticed that you are doing it with a straight cutter. Is this personal preference or do the angled bits not work well for profile cuts in the pickgaurd material?
  12. guitarbuilder
  13. guitarbuilder
    I'm hitting Control-Print Screen and putting that image into Paint. Then I crop out the extra junk and that leaves just the graph paper and image. Then it goes into photobucket like a picture.
    I'm going in with a pointed tool almost all the way through the material, to create the bevel I want. The cutter goes in .075 deep.Then I'm going to cut it out with a straight bit...leaving just a small straight edge. The pickguard material is .100 or close to that. The straight portion would be about .025 or so. I always take a scraper to the edge afterward.
  14. guitarbuilder
    Man alive is it cold in the shed.
  15. ItZaLLGooD
    northeast ohio
    That pickgaurd looks good. Thanks for the pointers on cutting.
  16. RogerC
    RogerC Poster Extraordinaire
    Oklamerica
    Great to see you doing this, Marty! I love the whole back-story on the concept. I think this is the perfect kind of build for the challenge.
    Good luck!
  17. Captain Nutslot
    Captain Nutslot Friend of Leo's
    Rochester, NY
    Maybe ya want to whip up another one of those guards? you know, for me :)
  18. guitarbuilder
    No problem. Good Luck!
    Thanks !
    You can have the plywood one...:)
  19. guitarbuilder
    Neck modeling for the modeling challenged like myself
    Let's model a neck. Get yourself a 2d drawing of a neck or draw it from scratch using a fret calculator and whatever measurements you like. I flipped it upside down in my Cad program..which is Rhino because I am building a wire frame upwards. Kudos to Ed Hawley for providing this drawing to the forum. I started this drawing with his 3d drawing and deleted some stuff from it and saved it as a 2d drawing.
  20. guitarbuilder
    The heel is 1" thick so I drew some straight lines up from some strategic locations, the 16th fret, where the neck joins the body, and the end of the neck where the radius ends on both sides. You can do one side and then mirror it too.
