Coffee, so what is your favorite brew??
Discussion in 'Bad Dog Cafe' started by Shuster, Feb 6, 2019.
  1. BigDaddyLH
    A picture is worth 1,000 words!
    Buttered Biskit and Tony474 like this.
  2. DrPepper
    DrPepper Tele-Holic
    776
    Nov 24, 2017
    I am Café...
  3. uriah1
    uriah1 Doctor of Teleocity Ad Free Member
    Feb 12, 2011
    Around
    Thanks...
    Too much timing is everything and work. I can't see doing that at 5:30am running around house. Maybe for weekend if you have time.
    Tony474 likes this.
  4. Toto'sDad
    Toto'sDad Telefied Ad Free Member
    Jun 21, 2011
    Bakersfield
    No you're doing fine just as you are. Your taste buds are shot, and it's won't make any difference what you drink. I've been using a Keurig for five years, I can at least two out of seven times tell the difference between tea and coffee right off.
  5. BigDaddyLH
    This got me thinking about how you used to be able to set your Mr.Coffee on its timer and literally wake up and smell the coffee!
    uriah1 likes this.
  6. BigDaddyLH
    Chinese green is quite different from Japanese green, it seems to me.
    Another post mentioned water temperature differences for tea versus coffee. That was back tea that wanted water at a rolling boil! The instructions for my Japanese green tea asks for water at 80 degrees, and the tea itself only steeps for 30 seconds.
    24 track likes this.
  7. chris m.
    If French Press is too much of a hassle then a drip brewer is probably your next best bet. Either manual or automatic.
    Old school manual where you hand pour the water (heated to correct temperature) over the grinds (ground to correct
    size with a burr grinder, electric or manual) in a Melita filter, typically produces better results, but some of the automatic
    machines do a pretty good job of approximating this, such as by using a shower type head over the filter instead of
    a single dripper. Here's a review.
    Filtered water makes a big difference if you don't have really good tasting tap water.
    I've gotten lazy and have been using our crappy Southern California tap water,
    but I can most definitely taste the difference.
    I find French Press to be very easy and not a hassle, but we keep our sink empty
    of dishes and have a garbage disposal so it's not a problem rinsing it out in the sink and then washing the grinds down
    into the drain. The grinds actually help keep the drain from smelling yucky.
    http://nymag.com/strategist/2017/02/11-best-coffee-makers-machines-brewing-at-home.html
  8. chris m.
    That would be 80 degrees Celsius, obviously...
  9. BigDaddyLH
    Yes! Japan (like every other country but one) uses Celsius ;)
    24 track and Tony474 like this.
  10. BigDaddyLH
    +1. My wife used to warn me that pouring grounds down the drain was risking a plug-up, but it seems to me grease is the main culprit. if anything, coffee grounds might help scrub that grease out!
  11. Tony474
    Tony474 Poster Extraordinaire
    Apr 16, 2007
    North Bushey, England.
    Splendid! You've saved me a lot more typing... :p
    uriah1 likes this.
  12. GuitarKid
    GuitarKid Tele-Meister
    250
    Nov 29, 2013
    Here
    When I sense my tinnitus going up like a train whistle in my head, I know I'm good to go
  13. Ben Bishop
    Ben Bishop Tele-Meister
    300
    Mar 4, 2010
    Victoria, BC
    In my moka pot I usually use Lavazza's Crema e Gusta, or the Gold (Oro). With the gold, which is really smooth, I'll sometimes add one or two sections of broken black cardamom. In my drip I'll use a good grocery store brand like Nabob Tradition or, my local preferred brand, Saltspring Island Peru. I use my Aeropress almost like a french press; I put in upside down, put in coffee, pour in the water, attach the cap with the filter in place, and let it brew for a few minutes. The finer the grind the shorter the brew, of course. The filters are quite fine and rarely pass even espresso grounds.
  14. chemobrain
    chemobrain Friend of Leo's Ad Free Member
    Nov 5, 2016
    oakland ca.
    starbucks =overpriced pee-pee water.
    my favorite tea is Lapsang Souchon
    Peets use to sell it but alas no more
    Paul Jenkin likes this.
  15. edvard
    edvard Tele-Holic
    916
    May 15, 2016
    Bremerton, WA
    Now just hold on one cotton-pickin' minute... where on God's green earth are you finding Torrefazione? That was the absolute BEST coffee ever, ever, ever and then Starbucks went and ruined the party by buying them out. SB's used to sell it still branded Torrefazione, but I'm pretty sure that went away.
    That is, until I saw your picture there. Do you have a secret stash? Shady supplier? What is your secret, man?
  16. telemnemonics
    Mar 2, 2010
    French roast for coffee and yerba mate for tea.
  17. telemnemonics
    Mar 2, 2010
    Dude appears to be nodding off, coffee maker must be defective...
  18. rghill
    rghill Tele-Afflicted Silver Supporter
    Oct 16, 2007
    Glendale, AZ
    My go to is Kirkland House Blend. I grind the beans in a Mr Coffee burr type grinder. When I run out, sometimes I'll get Trader Joe's Colombia Supremo coffee, the one with the Toucan on the container.
    I got a package of Death Wish coffee for Christmas. It tasted OK, but did have a pretty good caffeine kick!
  19. DonM
    DonM Tele-Afflicted Silver Supporter
    Apr 21, 2016
    Henderson,NV/SLC,UT
    I used to grind the special beans thing but got lazy with the Keurig. I now use this in a reusable K-cup. May go back to grinding my own again sometime.
  20. rghill
    Oct 16, 2007
    Glendale, AZ
    You got to make your coffee like this guy:
    Tony474 likes this.
