Clean Amp Opinions please.
Discussion in 'Amp Central Station' started by DougF, Dec 5, 2018.
  1. BigDaddyLH
    They get a lot of love on the jazz forums (steel guitar forums, too, I assume).
  2. rebelwoclue
    rebelwoclue Poster Extraordinaire Silver Supporter
    Jan 15, 2012
    kentucky
    Fender Deluxe Reverb or if you want to spend some real cash, a hand-wired boutique amp like a ZLux or Two Rock Studio Pro 35
  3. twotone60
    twotone60 Tele-Meister
    215
    Sep 14, 2011
    Charlottesville, va
    As noted, the answer depends a lot on what exactly you are after. If you want light, inexpensive, and with decent headroom, a Katana 50 or 100 is a great choice. If your budget is larger, an Allen Sweet Spot or Accomplice. Somewhere in the middle, a Deluxe Reverb reissue.
    DaphneBlue likes this.
  4. Bowpickins
    Bowpickins Tele-Meister
    112
    May 29, 2018
    Somewhere In TX
    Fender Mustang III V2 with an Eminence Swamp Thang speaker on the 65 Deluxe reverb preset. :)
    Vespa_One likes this.
  5. MMARSH
    MMARSH Tele-Meister
    392
    Jun 21, 2015
    CA
    Super good cleans from Carvin tube amps. They are discontinued, sadly, but you can nab one pretty cheap on reverb. The Bel Air or VIntage 16 or X100B.
    stevemc likes this.
  6. Papa Joe
    Papa Joe Friend of Leo's
    Jun 30, 2007
    Swanton Ohio
    Gotta agree on the Deluxe Reverb..
  7. beyer160
    beyer160 Friend of Leo's
    Aug 11, 2010
    On Location
    Deluxe Reverb.
    There are plenty of great sounding clean amps, but the Deluxe rules them all.
    Geo likes this.
  8. stevemc
    stevemc Tele-Meister
    215
    Mar 7, 2018
    cape cod
    DRRI or if you want ss a fender champion.
  9. Fearnot
    Fearnot Friend of Leo's
    Jan 17, 2010
    Decatur, GA
    Ironically these days, you can likely find bigger Fenders used for about the same price as a new DRRI.
    JustABluesGuy likes this.
  10. Jakedog
    Mar 26, 2003
    The North Coast
    My answer would be my DV Mark FGC121. It’s discontinued, but totally amazing if you can find one.
  11. Telecastoff1
    Telecastoff1 Tele-Meister Silver Supporter
    343
    Apr 28, 2009
    Minnesota
    SFTR UL 135 WATTS. The cleanest amp Fender ever made...IMOOC. and, because these have been so wrongly misaligned over the years, they can still be had pretty cheaply.
    Paul in Colorado likes this.
  12. Bartholomew3
    Bartholomew3 Friend of Leo's
    Dec 8, 2010
    Montreal
    Absolutely true - but had to put $200 into the head to re-build the power section after 2 years and the bass pot just crapped-out last week so here we go again.
    Cheap Asian junk and useless with a loud drummer - has no balls for stage use with a medium volume band and too much treble. Celestion 70/80 speaker is tinny sounding also too much top end so changed that to a WGS ET65...huge improvement.
    Already have an original sf twin from 68 that I bought for approx $425 that year, wanted lower volume, less weight. Should have bought a Blues Jr instead of the junker Ibanez - my mistake, be forewarned.
  13. markal
    markal Tele-Holic
    573
    Mar 24, 2016
    Colorado
    Peavey Bandit. I’ve had a bandit, studio pro and now an envoy and all of them have fantastic cleans.
    I would also vote for the Orange Crush 60. Different voice, kind of woody, but dry clean.
    If you can relax the 1x12 requirement, the Roland jc-40 gives the iconic JC clean in a smaller package.
    545454 and SolidSteak like this.
  14. Gmountain
    Gmountain Tele-Holic Silver Supporter
    710
    Jun 7, 2015
    It really is. Excellent amp.
    The Humboldt Hot Rod Blues Jr IV from MF is also very clean.
  15. SolidSteak
    SolidSteak Friend of Leo's
    Apr 27, 2016
    Peavey Bandit. Any of them. Some are different than others though...
  16. mexicanyella
    mexicanyella Tele-Holic
    797
    Jan 26, 2012
    Troy, MO
    I agree with all of that, and expanding on those thoughts:
    I like the cleans on my Peavey Special 150, which is just a Bandit 75 (the next version after LGOberean's Bandit 65...'87-'88ish) with double the power.
    Peavey made some EQ changes between the Bandit 65/Special 130 years and the Bandit 75/Special 150 years. The semi-parametric mids went away, leaving the 75/150 amps with standard passive bass/middle/treble controls and an active presence control that can boost or cut 5 kHz by 15 dB. I haven't played the earlier 65/130 amps, but on the 75/150 clean channel that active presence interacts with the passive mid and treble controls, and the bright switch (which boosts 6 dB at 2 kHz).
    I find I can tweak a pretty nice bright tone but roll it off before the tooth-shattering frequencies come in by working the treble and presence against each other. Varying combinations of bright on/off, treble and presence can give me a pleasing, lively sound with humbuckers or single coils.
    My main axe is a one-humbucker hardtail Squier strat...not anyone's idea of an ideal "clean machine," but the Special 150's eq allows me to dial in a bright, cutting-but-not-harsh clean that works well on hybrid picking, Tele-style pedal-steel-emulating bendy licks, strummed chords...and when I play a guitar with a neck humbucker and roll the tone off a bit I can get a "smoky jazz tone" too.
    The amp's reverb is a little on the dark side, with a long decay, which may be good or bad. I almost always play dry (but the long/dark Peavey reverb sounds great with my lap steel).
    With my guitar's bridge humbucker (adjusted pretty low to drop the output a bit and soften its character a little) into the amp's low-gain input, the clean sound begins to break up above 5 on the clean volume knob. You can detect a little bit of grit and snarl at 4 when you really whack it. But at this point it is LOUD. I've run the clean channel up to 7-8 before and at that point it gets pretty crunchy, and cleans up well when you back off, but the crunch is pretty harsh and it's so loud at that point that I have yet to mess with the EQ and try to optimize it. I can't imagine needing to be that loud.
    The downside of the 75/150 era of Bandits/Specials is that on the distortion channel, the amp uses a preset "thick" eq, leaving only the presence control adjustable. Just as the Scholz Rockman turned every riff into a Boston riff, the 75/150 amps turn every distortion channel riff into Zakk Wylde on Ozzy's "No More Tears."
    But that doesn't matter if you only use the clean channel. It's a powerful, no-frills amp that can blow your pants across the room with a useful clean sound. Specials aren't as common as Bandits, but Bandits get plenty loud as well and they show up used at pawnshops and on CL all the time. I've seen dusty, dirty cosmetically challenged Bandit 75s priced at about a dollar per watt plenty of times. Well worth considering. My Special came in at about $0.50 per watt and an epoxy repair to the baffle board...an easy fix for a lot of amp.
    Final thought...goosing a Bandit/Special clean channel with a conservatively set compressor pedal is awesome fun. All the beef and even more singing sustain.
    LGOberean likes this.
  17. mexicanyella
    797
    Jan 26, 2012
    Troy, MO
    Another amp I liked the cleans on a lot was an old Yamaha G50-112 combo...the first version, with the kind of stripey grille cloth and the weird thin fuzzy distortion circuit. The thin fuzz was kind of fun, but the cleans were serious.
    Also, my buddy's "cyclops era" Peavey Classic 30 has a really nice-sounding clean channel, which turns into the classic rock crunch channel when you turn it up. But it gets quite loud while still staying clean. Too bad about that goiter-looking logo/cyclops eye thing. But the odd visuals don't affect the sound.
  18. bcorig
    bcorig Tele-Holic Silver Supporter
    720
    Mar 11, 2018
    Chino Hills CA
    Blues Jr. IV. Clean at any volume
  19. Tonetele
    Jun 2, 2009
    South Australia
    Fender twin. 6L6 valves- you have to set it a certain way for itto distort and plenty of power for gigs.
  20. mad dog
    mad dog Friend of Leo's
    Jun 27, 2005
    Montclair, NJ
    Many good choices. I've been greatly enjoying old polytone minibrute SS amps for this lately. A MB II with 12" speaker, a MB IV with 15" speaker. They sound very good at low volumes too.
