Chris Shiflett Tele Deluxe // Change String Spacing
Discussion in 'Tele-Technical' started by hogan666, Apr 24, 2017.
  1. hogan666
    hogan666 TDPRI Member
    5
    Feb 8, 2016
    Germany
    Hello Tele-Fellas from Germany :)
    after a lot of google'ing I'm more and more confused.
    I bought a used Shiflett Tele Deluxe as a backup for live.
    The Guitar is great but I don't feel like at home with my Jim Root Tele.
    After a bit of chating I found out, that Fender uses two different string spacings. :-/
    And I'm kinda sure that it's the fact I don't like. All my other guitars have the modern spacing.
    Did I mention that it isn't that easy to get a conversion hardtail?!
    Modern Fender Hardtails don't match in terms of mounting & position as I read.
    The only thing that looks ok to me is the Hipshot Hardtail with modern Spacing.
    Can anyone confirm that this matches vintage mounting holes and works as a conversion?
    It's not that easy 'cause in Germany we calculate in metric sizes not inches. So one more issue to confuse me. :D
    Hipshot isn't that easy to get in Germany. So I have to order in the States.
    Would be great to have an alternative.
    Thanks, Markus.
  2. Wally
    Welcome, hogan. I went to that linked site. They offer that bridge in two different spacings....
    2 1/8"(modern) and 2 1/4"(vintage). I did not go to the 'dimensions'....link. Check it out, make measurements of the bridges on the guitars that you like and don't like....compare.
    Fwiw, there may be other differences such as fingerboard radius being a major thing, ime.
    hogan666 likes this.
  3. Tuxedo Poly
    Tuxedo Poly Tele-Afflicted
    Dec 19, 2011
    Merseyside UK
    Fender uses 3 string spacings, narrow modern 52mm, vintage Tele 54mm and vintage Strat 56mm. There are exceptions, as always.
    Your Chris Shiflett has a Sung Il BN005 bridge with 54mm string spacing.
    The Fender (not Squier) Jim Root uses a black version of the American Standard hardtail bridge which has narrow 52mm spacing.
    The chrome version is Fender part number 0032909000, Thomann item number 114488, price €77 https://www.thomann.de/de/fender_hardtail_bridge_chrome.htm
    The Fender hardtail should fit the Chris Shiflett with a slight modification to the string through holes.
  4. hogan666
    5
    Feb 8, 2016
    Germany
    Wow @Tuxedo Poly!
    Thats great news and to be honest the first answer, which brings me a step closer to my goal.
    Thanks a lot Mate! I'll give it a try.
    Cheers, Markus.
  5. hogan666
    5
    Feb 8, 2016
    Germany
    Die the mod a few days ago. Works like a charm :)
    Had to redo 2 screwholes, but the string through holes aligned perfectly.
    Thanks @Tuxedo Poly
  6. A_D_B
    A_D_B TDPRI Member
    7
    Jun 29, 2010
    Brazil
    Do You have some pictures With the new Fender hard tail? It seems black for muito eyes... Thanks
  7. hogan666
    5
    Feb 8, 2016
    Germany
    Hey A_D_B,
    here are the pictures. Not the best craftmanship (appearance), but it gets the job done. ;-)
    Cheers, Markus.
      File size:
      265.2 KB
      122
      File size:
      247.5 KB
      129
      File size:
      158.9 KB
      134
      File size:
      201.8 KB
      123
      File size:
      268.6 KB
      124
      File size:
      245.2 KB
      120
      File size:
      207.3 KB
      121
  8. A_D_B
    A_D_B TDPRI Member
    7
    Jun 29, 2010
    Brazil
    Thx for the answer and pics. It fits (in terms of colour) with de Seymour Duncan pickup. Good Job.
  9. hogan666
    5
    Feb 8, 2016
    Germany
    With the stock chrome humbucker it looks even better.
