Chords that don't sound great on electrics but do on acoustics, & vice versa?
Discussion in 'Tab, Tips, Theory and Technique' started by RoscoeElegante, Apr 26, 2019.
  1. RoscoeElegante
    RoscoeElegante Friend of Leo's
    TooFarFromCanada
    (Changed the original thread title, FWIW.)
    Even with all the tones and tools available to put electrics into near-acoustic sounds and to color acoustic sounds with electric guitar qualities, are there chords that just sound better on an electric than on an acoustic, and vice versa, to you?
  2. Chunkocaster
    Chunkocaster Friend of Leo's
    In space with Ziggy
    I think the Hendrix chord sounds much better on electric than acoustic.
    Same with a lot of power chords.
  3. GoldDeluxe5E3
    GoldDeluxe5E3 Tele-Holic
    Concord, California
    E A E A B E
    The Trower Chord
    fatcat likes this.
  4. klasaine
    klasaine Poster Extraordinaire
    NELA, Ca
    No.
    It depends on 1) tuning stability and 2) musical application.
    Wally likes this.
  5. aerhed
    aerhed Friend of Leo's
    Boulder, WY
    Nope. A chord is a chord. Intonation issues not withstanding.
    Jim622 and Wally like this.
  6. Whatizitman
    Whatizitman Tele-Afflicted
    WV
    My yammy acoustic is very boomy, so strummed and muted 5ths actually sound pretty cool on it. However, it doesn't translate to a piezo. You have to be in ear-shot, or it has to be mic'ed to work.
    ANY acoustic plugged in will sound awful with power chords. It's just the way it is. Not just bad, but gawdawful. Cowboy chords are only marginally better. Have I mentioned lately how much I hate acoustic pick-ups?
  7. JL_LI
    JL_LI Friend of Leo's
    Long Island, NY
    Sometimes chords with open strings sound better on an electric because the fretted notes have better sustain. Sometimes chords strummed across all six strings sound muddy on an electric but can be heard with clarity on an acoustic. I play both. I play mostly the same songs on both. I play them a little differently on an electric and an acoustic because of the subtleties and nuances of the instruments. Is one better than the other? They’ve just different, but in a good way.
    Random1643 and ftbtx like this.
  8. Pualee
    Pualee Tele-Meister
    Virginia
    I never thought about it this way.
    However, I have a few songs that I have to play very differently if I am on acoustic vs electric.
    The chords are all the same, but the way I fret, pick, strum, mute is what I do differently. Most of the songs I play this way are in the key of E with 'cheater chords' (e.g. A/C# B/G#).
    With electric, I have to artificially make the notes decay faster. The tension is less noticeable on acoustic and I can let it ring out a lot more.
  9. SixStringSlinger
    SixStringSlinger Friend of Leo's Silver Supporter
    Space
    I haven't usually been crazy about barre chords on my acoustics. But that's probably more to do with the particular guitar than the chords.
  10. twangking
    twangking Tele-Afflicted
    Out in the woods.
    I haven't had this problem.
  11. beninma
    beninma Tele-Afflicted Silver Supporter
    Massachusetts
    I don't know if I can say it's an electric/acoustic thing.
    I think there are some chords that sound bad on electric depending on the tone the electric guitar is setup for with the amp. More gain, fuzz, overdrive, etc.. and some of the big open chords start to break down. But again depends on how it's played. Bang an open chord and let it ring out on a gainy electric tone, that might be fine. Sit there and strum that same open chord many times in the bar the way you might on acoustic and it might sound bad.
    On acoustic I think almost everything sounds good but it's sometime hard to play some of them on some acoustic guitars. Barre chords further up the neck, etc...
    As I play more though more of these things seem to be doable.
  12. SixStringSlinger
    Space
    I think a lot of this (where it's experienced) has to do with electrics being generally easier to set up and adjust, and whatever you do is more easily reversed than on an acoustic (turning saddle-adjustment screws vs. sanding down a bridge, etc.).
  13. fasteddie42
    fasteddie42 Tele-Holic
    Tip of the Mitt
    I've always thought the open cowboy chords sound great on an acoustics but muddy and less pleasing on an electric.
    I figure its my lack of skill.
  14. BigDaddyLH
    Kelowna, BC, Canuckistan
    I think guitars that produce more overtones can make complex chords sound more dissonant, or more clashy, if that makes sense.
    Archtops seem to do better with complex chords, but is that because I'm thinking more about jazz when i pick mine up? Notes on a archtop do seem to produce a stronger fundamental.
    JL_LI likes this.
  15. wtk0315
    wtk0315 Tele-Holic
    Houston area
    I ran into this the other day. I wanted to practice the lead fills to "chasing that neon rainbow" so I attempted to play the rhythm/acoustic part in my looper using the cowboy chords. I was not impressed with the play back. It sounded boomy, with too much sustain. I'm going to have to figure out an arrangement that works with electric.
  16. Jimmy Dean
    Jimmy Dean Tele-Afflicted
    Portland, OR, houseboat
    Since I am not a finger picker, I play exactly the same on acoustic as I do on electric. Never gave it any thought before.
  17. Obelisk
    Obelisk Tele-Afflicted
    NW USA
    Depends on how the amp is set. If you are using an overdriven amp, then chords with upper harmonics can sound very discordant on electric guitar. Power chords usually sound better with some extra distortion, but I love doubling harsh sounding power chords with acoustic guitars playing similar chords. Fingerstyle players seem to be able to go from acoustic to electric with less fanfare than plectrum players.
    Then why did chord maestro Ted Greene often play a Telecaster? He might answer that the solidbody doesn't color the sound as much as an archtop. Though he loved his Guild archtops, Ted mostly played older Telecasters. Many jazz players gravitated towards the archtop because it project a fuller tone than a flattop in the days before amplification. The archtop became the standard for jazz players when pickups were adapted to the body, but some of the best jazz tones I have ever heard emanate from a Telecaster.
    Ted playing solo at a wedding in the late 80's. He owned a bunch of old Telecasters. It's funny that he preferred the anonymity of teaching to only become a legend. He was really a great player though.
  18. BigDaddyLH
    Here's a test chord. Arpeggio it and let it ring -- does it sound good?
    Bb Lydian: 685755
  19. BigDaddyLH
    I don't know, but Ted could string up a broomstick and make music with it.
  20. VWAmTele
    VWAmTele Friend of Leo's
    FL
    I call that the "A Day In The Life" chord (A add9) - Beatles. Sounds great on both electric and acoustic.
