Chopper T split, series, parallel wiring not as expected
Discussion in 'Just Pickups' started by wpf69, Nov 8, 2018.
  1. wpf69
    wpf69 TDPRI Member Silver Supporter
    South Carolina
    Hi All, I've used the wiring diagram from Dimarzio that lists the switch positions as 1)parallel, 2)split, 3)series. I assume they are counting 1 - 3 from the bridge to the neck, but when I test the output lead with a multitester I get 1 and 2 as about double the output of 3. It doesn't matter to me which way the switch goes, but the middle and "1" position are definitely meatier than "3." What could be happening here? Can anyone clarify what could be going on here?
