Cheap but good tele bodies?
Discussion in 'Tele Home Depot' started by butlerdidit, Aug 5, 2018.
  1. butlerdidit
    butlerdidit Tele-Meister
    Cleveland
    Looking for cheap but good tele bodies, finished, preferably lighter weight. Don't care if the finish is perfectly done as long as it looks decent and everything lines up right. I have read the comments on GFS and Eden bodies. Are there any other sources that are better?
  2. Luthi3rz
    Luthi3rz TDPRI Member
    AZ
    Define cheap?
  3. Festus_Hagen
    Festus_Hagen Tele-Meister
    Jeff City, Mo.
    Depends on what ya want ...
  4. butlerdidit
    Cleveland
    Under $300? I thought I described pretty well what I want...
  5. Mad Kiwi
    Mad Kiwi Friend of Leo's
    Land of the Long White Cloud
    Don't the Stratosphere do Tele bodies for around that?
    Otherwise I would suggest used Squires as donor guitars.
  6. NothingGoatboat
    NothingGoatboat Tele-Meister
    Southern California
    GFS makes really good bodies. I've never had something not line up. The finish is usually really good to, and you get more options than if you used a Squier body. The normal bodies are Paulownia, which is super light. Brad Paisley gets it in his Crook guitars, and he doesn't have an issue with the density. The XGP weigh a tiny bit more, but are firmer. The GFS bodies are really the best bang for the buck. Another option is to find a used MIM body, or even a Classic Vibe body. Reverb has lots of good bodies from Stratosphere, usually under or around $300. Good luck!
    nojazzhere likes this.
  7. Festus_Hagen
    Jeff City, Mo.
    Fender bodies are under 200.00 on ebay. There is a nice sunburst squire loaded on there for 130.00.
    You can always go the cheap wood route and get paulownia, as was said. I'd at least get alder, but that's just me.
    Good luck!
  8. Luthi3rz
    AZ
  9. sleazy pot pie
    sleazy pot pie Tele-Holic
    austin
    Yeah, for 300 bucks you can get a pretty wide selection of great finished bodies.
    Ebay has fender bodies all day for well under that. Mjt for a relic look.
    Do yave already have a neck and hardware/pickups?
  10. LutherBurger
    LutherBurger Friend of Leo's
    NYC
    Slowisfast likes this.
  11. Sollipsist
    Sollipsist Tele-Afflicted
    I've heard of many people having no issues with their GFS bodies. My one and only experience was less satisfying.
    I eventually made it work, but if (when) I was going to do it again, I'd probably grab something from Stratosphere if I wanted real Fender/Squier, or Warmoth if I needed something specific & different.
  12. Slowisfast
    Slowisfast Tele-Meister
    Mt. Rainier
  13. warrent
    warrent Friend of Leo's
    toronto
  14. TRexF16
    TRexF16 Friend of Leo's
    Tucson
    You did a fine job of describing what you were looking for but not of describing what "cheap" meant to you. I would have guessed you were in the $100, +/- range when you said "cheap." And as you can see from the responses, $300 is not at all cheap, and if this is the budget you can stomach, you have a lot of very fine options available. For a number of reasons I'd recommend you start at the Stratosphere, as have several others.
    Good luck with the search - let us know what you choose.
    Rex
  15. HolyTele Tube
    HolyTele Tube TDPRI Member
    Prosperity, Sc
    300$ at Warmoth.com will buy you almost any standard body in all configurations. They do great work.
  16. DarkshipDan
    DarkshipDan TDPRI Member
    Cape Cod
    Yet another vote for Stratophere. I also got a really nice roasted maple neck from them for my Tele.
  17. PARCO
    PARCO Tele-Meister
    VA
    Check out Musikraft.
  18. butlerdidit
    Cleveland
    Thanks for all the suggestions. I guess what is making it harder for me is that my preferred colors are foam green or fiesta red or sonic red. The pulled bodies are mostly black, white, candy apple red, some sort of burst.
  19. Luthi3rz
    AZ
    http://www.warmoth.com/Showcase/ShowcaseItem.aspx?Body=2&Type=2&i=PT7273
    http://www.warmoth.com/Showcase/ShowcaseItem.aspx?Body=2&Type=2&i=PT7227
    http://www.warmoth.com/Showcase/ShowcaseItem.aspx?Body=2&Type=2&i=PT7194
    http://www.warmoth.com/Showcase/ShowcaseItem.aspx?Body=2&Type=2&i=PT7040
  20. butlerdidit
    Cleveland
    Yup, I did indeed end up going with the Warmoth Seafoam green. At $295, it is not cheap, but at least it should be good quality.
    Luthi3rz likes this.
