Change from a 5 way to a 3 way switch
Discussion in 'Telecaster Discussion Forum' started by texmck54, May 28, 2011.
  1. texmck54
    texmck54 Tele-Meister
    I have a Jerry Donahue CIJ Tele & i want to change out the mij
    switch & pots I would like to change the 5 way to a 3 way switch
    is there anything special i need to do where the neck pickup is a
    strat. pickup to get it to a traditional tele setup
  2. Twinkie
    Twinkie Tele-Meister
    283
    Jun 4, 2010
    Seattle
    I did a mod to my 60 Start with a set of dual 3-Way switches allowing for the traditional neck and bridge arrangement sending the output of the first 3-Way switch to the second 3-Way that selects between the bridge/neck combo with the middle pickup. The additions to the traditional 5-Way Strat combo are neck & bridge (without a middle pickup) and all 3 pickups together.
    I can see performing a mod of this nature to a 3 pickup Tele by drilling a hole between the volume and tone pot and installing a 3-way mini toggle.
  3. Mark Davis
    Mark Davis Telefied Ad Free Member
    Mar 2, 2003
    Bakersfield Ca.
    Nothing special just wire it up like this. You will probably wanna get a new switch the MIJ ones are weak.
  4. texmck54
    Thanks for the diagram Mark i've installed the new pots & 3 Way
    switch neck & bridge positions sound fine but the middle position
    has a drastic volume drop & it sounds out of phase at least i think
    that's the word what could i have done wrong
  5. Mark Davis
    Mar 2, 2003
    Bakersfield Ca.
    If the middle sounds thin weak and nasal one of the pickups wires needs to be reversed.
  6. texmck54
    Thanks again Mark i'll try that when i get a chance & let you
    know how i made out
  7. Mark Davis
    Mar 2, 2003
    Bakersfield Ca.
    Ya its simple anytime the middle position doesnt sound right that will fix it.
    Let us know how it turns out.
  8. texmck54
    Mark i'd like to pick your brain a little the original change a buddy did
    for me being that i'm not the handiest with a soldering iron anyway my friend
    is an hours drive away so i'm going to see if i can correct this problem on
    my own is there a diagram or easy instructions on how to reverse a
    pickup wire keeping in mind my neck pickup is a strat pickup any help would
    be much appreciated
    thanks Kim
