Chalkboard finish opinions
Discussion in 'Finely Finished' started by Rockdog, Oct 18, 2011.
  1. Rockdog
    Rockdog Tele-Afflicted
    Heart of the Commonwealth
    My next build is going to be an Esquire and I'm thinking about doing something out of the norm for the finish on the body. One idea I'm kicking around is using a chalkboard spray paint. I noticed Krylon makes both a green and a black finish.
    Cool idea, or lame?
  2. Zenzeypher
    Zenzeypher Tele-Afflicted
    Oxford, UK
    You just wanting a matte finish ?
    I think it's a great idea, I love them with shiny scratch plates...I don't think a colour choice could be considered lame...but it will just look like matte i feel.
  3. Rockdog
    I would like the matte finish aspect of it, but I'd also like the functionality. I just think it could be cool to have people draw/write things in chalk on my guitar that I could erase at any time.
  4. TheEmptyCell
    TheEmptyCell TDPRI Member
    Columbia, SC
    Cool, unless it feels like a chalkboard, if so... avoid running your nails across it! I've been wanting to a stealth black finish (super-flat black) and put DR colored strings on it, as well as colored fret markers as a sort of Guitar Hero tribute guitar.
  5. Zenzeypher
    Oxford, UK
    If you like the functionality too id go for it, but be prepared for multiple coloured smears all over your sleeves, trousers and guitar :D
    I think after some time it might start to gloss as it gets worn but you can always top it up.
  6. jkingma
    44°55'09.9"N 79°25'39.1"W
    Admin Post
    You could write your set list on it.
    or maybe some cheater notes for lyrics you can't remember.
    :D
  7. Zenzeypher
    Oxford, UK
    or tabs or chords if youre learning something new.
  8. Bolide
    Bolide Friend of Leo's
    Rocky Hill, CT
    Why am I imagining a certain guitar builder doing one with a Martinsburg slate body and a granite neck for next year's challenge?
  9. Colt W. Knight
    Tucson, AZ
    I think its a cool idea. You can have your kids, gfs, or etc. etc. draw on it before a gig. I noticed that stuff in Homedepot of few years ago, and I have always been curious to how well it works. You can also get the glow in the dark stuff in the same section.
  10. slapshot
    slapshot Tele-Meister
    put a little mic on it so you can scrape your fingernails across it .better than a pick slide
  11. Rockdog
    Thanks Colt--I have a 1-year-old daughter and definitely had her in mind when I came up with the idea.
    That would be awesome :twisted:
    I think you guys have convinced me.
  12. SixShooter
    SixShooter Friend of Leo's
    Cincinnati
    I suggest doing a test using that finish. I like to use mdf because it is pretty flat. Though do sand it first to get it absolutely smooth. Put down a good couple coats of primer. Sand lightly with about a 400 or 600. Then apply you chalkboard paint. You might need to sand in between coats. The question I have is how to get the final coat smooth without sanding? Perhaps you could sand it up to about 1000 or 1200. It will look matte if you don't polish it. Same technique may work using any black spray paint. The matte finish will get gloss marks where is gets rubbed like around your strap or the forearm area.
  13. chillman
    chillman Tele-Afflicted
    The first thing that pops into my mind is, how will it age? I know chalkboards are very susceptible to skin oils but they usually get wiped right off. I'd be curious to know what a few weeks worth of gigs would look like.
    That said, I still like the idea! It would be one of the most unique teles I've ever heard of.
  14. Rockdog
    I definitely plan on doing a test run on scrap. I'll probably use BIN shellac-based primer. For final sanding, I figure I'll cross that bridge when I come to it. Because of its intended use, I would think that chalkboard paint contains a good amount of flattening agent.
    FWIW, my scrap is going to be the original body I'd planned on using for this project. It's from an old Saga kit I assembled years ago. This weekend I took it apart and tried fitting the new parts, but they're not really fitting. The measurements are off. No surprise there. So now I need a new neck AND a new body. I'll probably go All Parts on the neck (one of the fat ones), but I can't afford to spend much on a body. The pine bodies from Red Dirt look good, but I'm also considering one of those paulownia bodies from GFS. I'm checking ebay, too.
  15. SixShooter
    Cincinnati
  16. boilerup2004
    boilerup2004 TDPRI Member
    Indiana
    Plexiglass doesn't have the density of granite...
    ...this would weigh a TON! It would be cool, though.
    I took a dead 112combo and painted a small piece of hardwood with the krylon chalkboard to fill the void where the chassis was. It worked out great and was fun on stage (great if you're in more than one band!), but I don't know how it would work on an axe.
    I made a small chalkboard for the kids out of a piece of mdf, and it's a pain to keep clean. It also does not like being wet. Maybe make a pick guard first? If you like it, then go for the gusto. Maybe make a chalkboard first to see how the feeding and care goes.
  17. Rockdog
    Duly noted. I'll test it out on a few different surfaces and see how it holds up.
