Chainsaw problem
Discussion in 'Bad Dog Cafe' started by HotRodSteve, Mar 25, 2018.
  1. HotRodSteve
    HotRodSteve Friend of Leo's
    The Hudson Valley
    Hey guys, need some advice if possible. I have an old Husqvarna 137 chainsaw that hasn't been started in over ten years. It's gummed up and won't start, I was bad and let it sit with old fuel. What is the best way to clean out the carb and fuel line to get it going again? We just got nailed with some Nor'easters and I have a few downed trees to cut up.
  2. Johnson johnson
    Johnson johnson Tele-Holic
    Memphis
    Empty any old gas, remove air filter and clean it up (compressed air is good), replace spark plug, add new premix and let her rip. I've got Stihl and Husky saws and I'm bad about leaving old gas in them.
  3. Obsessed
    Obsessed Doctor of Teleocity Ad Free Member
    Montana
    You could try running some chainsaw gas additive through it after cleaning the air filter and exhaust with compressed air, but odds are after 10 years, it is a carb rebuild time and if you have never done one, then take it in for a rebuild.
    It is best to have the chainsaw up and running before the Nor 'esters. Just sayin'
  4. kranz
    kranz Tele-Meister
    Atlanta
    I have a Stihl that only sees occasional use when a storm blows through. When it would no longer start, I bought a new carb online for a modest sum. It was quick and easy to install. Purrs like a kitten.
    stratofortress, drf64 and Obsessed like this.
  5. Obsessed
    Montana
    Hey, that is a great idea. If that carb can be found on Amazon Prime, you could have that saw running by Tuesday or Wednesday or even pay extra for overnight delivery.
  6. aerhed
    aerhed Tele-Afflicted
    Boulder, WY
    Yup new cheap carbs proliferate online.
  7. william tele
    william tele Doctor of Teleocity Ad Free Member
    Kansas City, MO
    I would do all the cleaning and soaking stuff...but do you chainsaw junkies ever use ether to get the blood flowing? I'm kind of 2 cycle ignoramus.:oops:
  8. screefer
    screefer Tele-Meister
    kildonan
  9. Wrong way
    Wrong way TDPRI Member
    Washington the state
    New carb time. The Ethanol that's in our gas these days gets syrupy, crystallizes and fouls the jets and other parts in the carb. The smaller the carb, the worse it is. You can get a rebuild kit but new carbs are fairly cheap and much easier. Try to get ethanol free gas for your small engines and of course always run the carb dry when it's not going to be used for awhile. There's a product called Sea Foam which works great in your small engines and will help this problem as well.
  10. 6stringcowboy
    6stringcowboy Tele-Afflicted
    Central North Carolina
    Sea Foam, premium no ethanol gas (if you can find it) keeps mine purring
    TequilaCaster likes this.
  11. flyingbanana
    flyingbanana Poster Extraordinaire
    Southern, California
    Get the carb and fuel lines cleaned. Throw fresh premix in and bam. Done. Except for if your fuel lines have disintegrated. Sometimes that happens.
  12. schmee
    schmee Friend of Leo's
    remove carb and clean it out? Buy non ethanol gas.
    I have a small Outboard for sale. It's been in the garage 3-4 years sitting. Got it out today put in gas mix and after loosening up the throttle valve a bit, started in 5 pulls. I was disappointed, it usually started in 2 pulls if only left for a year. Non ethanol gas last used and carb ran dry before those years of storage.
  13. Recce
    Recce Tele-Afflicted
    Northern Alabama
    You can go to Lowe’s, Home Depot, etc and they sell quart containers of 50:1 premix with 93 octane fuel. A little pricey but works really well and doesn’t go bad near as quickly.
    getbent and don71 like this.
  14. dogmeat
    dogmeat Tele-Holic
    Alaska
    go to the airport and buy some 100 low lead... very stable... last for years. and all older style engines love leaded fuel, especially high compression engines. Seafoam, as mentioned works as a system cleaner. I've rescued a few just by installing fresh mix with Seefoam added. squirt a shot into the sparkplug hole and/or ether in the air filter to get it going if needed. I park my equipment with a shot of Stabil and some Marvel Mystery Oil... run it until you smell it in the exhaust & its good 'till next fall/spring... usually more, but we don't have alky fuel
    stratofortress likes this.
  15. TeleTucson
    TeleTucson Tele-Afflicted Ad Free Member
    Tucson, AZ
    My trusty Stihl 028 Wood Boss has always amazed me. Sits there for many years and then starts and runs like a champ when I need it. Amazing.
  16. Obsessed
    Montana
    Non ethanol gas is a must for 2 cycle anything nowadays. I was told never to use ether or any starting fluid derivative on 2 cycles. Main thing is to run it dry for long term storage or use the new Stihl storage fluid mix which seems to be doing fine on my stuff for two years now.
  17. HotRodSteve
    The Hudson Valley
    I'll mix up some fresh fuel and pour a shot into the sparkplug hole first and see if it'll start. If that don't work I'll go to Plan B. Thanks for the advice guys.
  18. Milspec
    Milspec Friend of Leo's
    Nebraska
    Just drain it, re-fill with quality fuel mix, disconnect the plug, give it a few pulls, let it sit for an hour, add a teaspon of fuel in the plug hole, reinsert plug and it should fire up. Been doing that for 20 years.
    kuvash likes this.
  19. muudcat
    muudcat Tele-Holic Silver Supporter
    Fountain City, Wi
    carburetor cleaning is easy, usually vids on youtube. I pulled an O34 Stihl out of the recycle trash at our local recycling location, had to put some new parts on( air filter, bar and chain) but just cleaned the gas filter and pulled the carb, it was an easy clean. Next time use gas conditioner before you put it away or drain all the gas out
  20. stxrus
    stxrus Friend of Leo's
    St. Croix, USVI
    Get the carb cleaned, use a premium fuel, add a stabilizer (Stabil, etc) & run that sucker dry after every use.
    Our weed eater has not been started since before the first storm. I took it to the shop for servicing.
    kuvash likes this.
