Join TDPRI Today
Can too much heat kill a volume pot - UPDATE
Discussion in 'Tele-Technical' started by JohnK24, Nov 29, 2005.
  1. JohnK24
    JohnK24 Friend of Leo's
    Mar 16, 2003
    Western PA
    I've soldered at least 6 sets of pups into my tele and during an experiment with different cap values a few weeks ago I noticed a drop in output and fullness in my tele. I don't have a powerful solder iron and I'm wondering if applying so much heat to melt the solder over time as killed the pot and affected the tone ? My iron is 25 watts, if that means anything.
    J
    UPDATE: Well, I changed out both pots and the capacitor tonight (parts from acme guitars)...and the conclusion...YES, heat can kill, at least harm the output. Both pups sound better, more fullness, much better clarity...so there you have it.
  2. Caper
    Caper Friend of Leo's
    Mar 30, 2003
    John, if you have an ohm meter you can check the pot to verify just how close to 250k you are, the cap may be causing your problem.
  3. BB
    BB Friend of Leo's
    May 17, 2003
    Great Pacific NW
    Re: Can too much heat kill a volume pot ?
    Yes. too much heat can and will destroy a pot. I posted in a different thread about killing several pots when I first strated changing pups back in the 70's. I had no inkling of the proper way to solder ( probably still don't! ) and had a heck of time getting the solder to stick to the pot. I was fortunate enough to have someone come in the store as I was killing yet another and he told me I needed to scratch the pot's surface for better adhesion and invest in something called flux! Still, I couldn't figure out why my pots wouldn't work!
    Even though I've changed out probably 50-60 pickups and as many pots and wiring harnesses, I am by no means an expert....but, I do belive a 25 watt gun is still powerful enough to kill a pot.
    Hopefully, someone who actually knows will post.
  5. Mark Davis
    Mark Davis Telefied Ad Free Member
    Mar 2, 2003
    Bakersfield Ca.
    Takes alot of heat but it can kill the pot.
    WHat I do is solder a lug to the vol pot and then attach all my grounds to that lug. Its way cleaner and you dont have to melt a big pile of solder everytime you wanna change something.
  6. red57strat
    red57strat Friend of Leo's
    Oct 4, 2003
    Massachusetts
    I tin the spot on the pot where I'll be soldering to, tin the wires and the connection happens almost instantly.
    It's important to keep the soldering iron tip clean and tinned. Put a bit of solder on the tip before each joint. Put solder on it when you shut down as well to make the tip last longer.
    CTS puts do not need to be sanded or scraped to solder to. Many imported pots do.
    I use a 40 watt iron with a screwdriver tip on all guitar electronics and a 25 pencil tip on PCBs.
