Can a bulging electrolytic capacitor still be good?
Discussion in 'Shock Brother's DIY Amps' started by brokenbones, Apr 18, 2019.
  1. brokenbones
    brokenbones Tele-Meister
    Indy
    I was doing some prep work for a recap and decided to test a bulging capacitor still in circuit. One of the ESR meters I use has that capability. Anyways, the capacitor tested good, great actually. I'll probably pull it to double check with a different meter. Is this possible?
    If it tests good out of circuit would it be okay to leave it in? The reason I ask is that I intended to replace it, because of the bulge, but the replacement I bought is too tall. It's a $5+ cap from mouser and even more expensive locally. Could this be a false reading?
  2. Dacious
    Dacious Poster Extraordinaire
    Godzone
    If it's oozing stuff it's likely to pop. I'd change it.
    When they let go, the electrolyte is like acidic Araldite.
    awasson likes this.
  3. boredguy6060
    boredguy6060 Friend of Leo's
    Sou Cal
    It’s good right up until it isn’t, then it causes serious damage and inconvenience.
    Change it, it’s not worth the risk.
  4. telemnemonics
    I can play in tune on strings so worn out the windings are coming off at the frets where they were worn through.
    So measurements aren't always a good measure!
    boredguy6060 likes this.
  5. RLee77
    RLee77 Friend of Leo's
    Nevada
    That’s kind of like asking if it’s ok to eat meat that smells off.
    You might get away with it, but is it really worth the risk?
  6. stratclub
    stratclub Tele-Meister
    PNW
    Or continuing to drive on a tire with a tread separation developing. It holds 32 PSI, so why shouldn't I keep driving on it?
    A bulge in the side of a cap is a gift that will help you avoid some nasty damage if you change the cap before it makes a nasty mess.
  7. Commodore 64
    Commodore 64 Friend of Leo's
    Kent, OH
    Supposed to be 220uF. So they measure pretty good. Would you put those back in?
    corliss1 likes this.
  8. jvin248
    jvin248 Poster Extraordinaire
    Lions & Tigers oh Mi !
    With all the 're-capping' going on tube amps ... Just buy new and replace those since you already have them out of the chassis. Caps only reliably last a decade or two of use inside the high voltages of tube amps. Remember that caps are not much more sophisticated than layering aluminum foil and wax paper from your kitchen and rolling that up into a tube so you can apply several hundred volts to it. Take one apart sometime to see.
    Solid state amps run much lower voltages and thus caps in those can last longer.
    Doctorx33 and boredguy6060 like this.
  9. 24 track
    kamloops bc
    why wait for the carnage, the elecrtolyte will eat right through the PCB traces and really make a mess , and if the unit is apart already .....
    its kind of like dopping the transmision on your car , while its out replace the rear seal, because if you dont and the seal goes you have to pull the tranny to get at again.
  10. KyAnne
    KyAnne Tele-Afflicted
    Swamps of Louisiana
    No. Replace it.
    kbold likes this.
  11. galaxiex
    galaxiex Tele-Holic Silver Supporter
    Edmonton, Alberta Canada
    That would be the front seal...
    24 track likes this.
  12. DavidP
    DavidP Friend of Leo's
    Vancouver, BC
    ... as others have said, replace now! You have a ticking time bomb there...
  13. galaxiex
    Wanna risk it? ;)
  14. 24 track
    kamloops bc
    lol now you know why I work on gear not cars......LOL:lol::lol::lol::lol::lol::lol:
    thanks, but the point is the same!
    galaxiex likes this.
  15. 24 track
    kamloops bc
    that cant be fixed, it will need an exorcism may be on multiple layers!
  16. galaxiex
    Better yet...
  17. Blrfl
    Blrfl Tele-Meister
    Northern Virginia
    Electrolyte is like capacitor blood. If it ain't in there, it ain't gonna capicitate.*
    *Yes, I made that word up.
  18. peteb
    peteb Friend of Leo's
    Cascadia
    the problem with testing the cap is that it is probably not tested at full operating voltage.
    by the way, what voltage does the cap see? and what does the cap do?
    some are non critical and others are
  19. galaxiex
    This ^^^^
    To properly test high voltage rated caps.... you need to test them at.... wait for it...
    High voltage...
    .. but not more voltage than the cap is rated for.
    You need something like this....
    Test for (electrical DC) leakage, cuz the cap MAY test ok for capacity and esr...
    but can still leak DC like a sieve.
    Regardless... if it's bulging/leaking/oozing... it needs to go...
  20. schmee
    schmee Poster Extraordinaire
    It can test fine, but still may cause noise etc and of course fail at the wrong time.
