Cabronita & TV Jones Universal Mount
Discussion in 'Telecaster Discussion Forum' started by 29er, May 13, 2019.
  1. 29er
    29er NEW MEMBER!
    Illinois
    I just grabbed a MIM Cebronita semi hollow and it seems like the TV Jones universal mount classic model is a drop in replacement for this guitar. Just wondering if this is the case. Honestly, the stock bridge pup sounds pretty good to my ears, but the neck is a bit muddy. I'm sure the Jones would be a huge upgrade. Thanks for the input!
  2. ricardo1912
    ricardo1912 Tele-Afflicted
    Kent, UK
    I've got a couple of Cabs and from experience it's worth experimenting with pickup and polepiece height. The Fidelitrons are fairly weak and can sit pretty close to the strings.
  3. 29er
    29er NEW MEMBER!
    Illinois
    You are right. I need to do this before I jump into replacement.
  4. JUSS10
    JUSS10 TDPRI Member
    West Michigan
    Pretty sure my Brother in law did this. I helped him with the swap. The TV Jones went in fine but if i remember right i cut him a 1/8" spacer shim that we placed in the bottom of the pickup cavity as it was too deep. That said, I don't know if his body was stock or previously modified or what. May not be the solid answer you are looking but thought I'd toss it out there.
    Justin
  5. King Creole
    King Creole Friend of Leo's
    Colorado
    I think the Fidelitrons are pretty good. I haven't seen the need to replace them. You might consider a cap on the neck pickup to cut some bass. I've been meaning to try soldering a .0.047uf cap between the neck pickup and the pickup selector to act as a high pass filter.
  6. brookdalebill
    Austin, Tx
    Yup, I had the same guitar, and did the same mod!
    TV Jones pickups rule!
  7. Ian T
    Ian T Tele-Holic
    Tampa Bay
