BYOC Green Pony
Discussion in 'The Stomp Box' started by Paul in Colorado, Jun 26, 2019.
  1. Paul in Colorado
    Fort Collins, CO
  2. 11 Gauge
    11 Gauge Doctor of Teleocity
    Near BWI Int'l
    It's not really a klone, but is an OD820 with some tweaks.
    The OD820 is mostly a Tube Screamer with a charge pump and a gain control that blends between clipping and clean, but differs from the Klon in that it doesn't use hard clipping, and as BYOC noted, you don't get the "tone loss" when the gain knob is set somewhere in the middle.
    The OD820 also has a "high performance buffer" (which IMO is a poor way to put it - either a buffer "properly performs," or it doesn't).
    ...Just given that the Green Pony is roughly half the cost of the OD820 could possibly add to the appeal of getting one. It also has the switches for adjusting the bass and clipping characteristics.
    Probably the main thing to consider is that the OD820 will sound like a Tube Screamer, for the most part. Even though the Green Pony can have more bass and less midrange emphasis vs. the OD820, it's still going to sound TS-like. If you don't like how TS-based ODs sound, you may not care for how the Green Pony sounds.
  3. Paul in Colorado
    Fort Collins, CO
    Thanks for that, 11 Gauge! It helps. I have plenty of TS type pedals already, so I may or may not try it. I would like to have something smaller then my BBE Green Screamer, though. Maybe a Silver Pony might be a better way to go for something I don't already have.
  4. DrThunder
    DrThunder TDPRI Member
    Nebraska
    I bought one pre-built, its my favorite dirt pedal...its pretty sweet
  5. FenderLover
    FenderLover Friend of Leo's
    Minnesota
    Clearly, the 820 is already a better sounding TS in its stock form. Changing a diode or cap could make it less 'TS' too, like any other modded pedal. I would look at it as a better design to start with because most 'good' sounding overdrives sound pretty similar.
