Join TDPRI Today
Buzz in f/x loop
Discussion in 'Amp Central Station' started by MintBerryCrunch, Nov 19, 2012.
  1. MintBerryCrunch
    MintBerryCrunch Tele-Meister
    163
    Aug 17, 2012
    United States
    What could it be?
    Tried all individual pedals and none make it better or worse.
    Changed cables and still there.
    Unplug the loop and it goes away...
  2. Tle4
    Tle4 Tele-Afflicted
    Dec 28, 2010
    Warrington, Pa. USA
    If it is tube driven reverb, it could be a tube.... or maybe try cleaning the loop jacks with some contact cleaner and work a plug in and out
  3. MintBerryCrunch
    163
    Aug 17, 2012
    United States
    The f/x loop is tube driven... literally peaceful without the loop engaged... time to go shopping...
  5. MintBerryCrunch
    163
    Aug 17, 2012
    United States
    new 12At7, same old hum... possibly slightly better.
    I'll get some contact cleaner as suggested before I go ape**** about this
    Would any other tube be even quieter, like an ECC82 maybe?
  6. bunny 7
    bunny 7 Tele-Holic
    787
    Apr 14, 2012
    Louisville, Ky.
    ECC 82 (12au7) is a lower gain than a 12at7 so it would be less noisy to some extent in most circumstances. The transconductance is lower than 12at7, but it's designed as a "driver" tube like a 12at7 is as far as function.
    You didn't mention what amp this is in so if it's just an effects loop I'd still give it some contact cleaner and run a cable thru the jacks a few times just to clean any oxidation that might be there.
    Also, check the recovery tube and make sure it's seated firmly.
