Butterscotch Blonde Tele in Amber shade?
Discussion in 'Telecaster Discussion Forum' started by RoCkstAr256, Apr 26, 2019.
  1. RoCkstAr256
    RoCkstAr256 Tele-Afflicted
    Poland
    I known it might be a weird question but i do not get along with yellow . Were there any BSB teles with blackguard in Amber shade? I believe Player series and Original 50 is.
    Any ideas folks?
  2. EddieLocrian
    EddieLocrian Tele-Afflicted
    Isle-of-Wight
    You want this...
    don't you...
    RoCkstAr256 likes this.
  3. RoCkstAr256
    Poland
    Yes i do
  4. Kitarkus
    Kitarkus TDPRI Member
    Land of the Living
    IMO the late 2012 and later 52 reissues were very yellow. My 2008 is more butterscotch amber with lots of grain showing through. Variances abound, however, > 2011 and likely to lean yellow. YMMV.
    Here's mine:
  5. rze99
    rze99 Poster Extraordinaire
    South London UK
    The earlier AVRI 52s were more amber as per @Kitarkus post. Check out some used examples on line.
    RoCkstAr256 and Kitarkus like this.
  6. Kitarkus
    Land of the Living
    I will say mine does not have the 'pumpkin' tinted neck...but some of my era have necks that lean towards a pumpkin orange (which I did not particularly fancy). GREAT guitar by the way...I bought on a lark and didn't play it for a long while...only recently to discover how excellent it is.
    Edit...to be clear..."Original 50's" refers to the new ones of which I am less familiar. The older AVRI run(s) thru late 2012 tend more toward your preferred shade...the 2012 and later but pre 'original 50's' models were coined "pure vintage"....and these are generally the yellow(er) ones.
  7. RoCkstAr256
    Poland
    Ok avri52 Shade is perfect i need it, my bank account does not
  8. Ronkirn
    Jacksonville, FL
    BSB was never a color option... the color is the results of the lacquer being impacted by UV light and crud in the air... it causes it to become more and more amber..
    but since Leo used lacquers from different suppliers, and the crud in your air may be different from the crud in someone else air... the resulting shades of BSB can vary considerably...
    so whatever color of yellowish, beige, golden, tan, kakahi, kinda of color is absolutely perfect dead on correct as long as you like it..
    I might mention.. if you're painting a guitar BSB... the correct way is to paint it vintage white.. then clear coat it with a tinted clear... that way, as it ages, it does so correctly,, so the underlying white can be seen as the clear is worn away, most noticeably around the edges of the guitar..
    rk
    Obsessed, Chunkocaster and Piggy Stu like this.
