Join TDPRI Today
"Burnt" Finish Help?
Discussion in 'Finely Finished' started by toddfan, Feb 12, 2013.
  1. toddfan
    toddfan Tele-Holic
    890
    Dec 15, 2010
    USA, Midwest
    This is supposedly a "blow torch burnt" finish on an ASH body.
    I have a basic idea of how to achieve the "burnt" part....my question is this...
    Would you "burn" the body, and then still do grain filling, since it is ash? Or, would you grain fill first, and then do the "burn"? I would like to attempt this with a swamp ash body.
    Stain before, or after the grain fill?
    THANKS for any advice!
  2. swla
    swla TDPRI Member
    27
    Feb 19, 2011
    Northridge, CA
    I'm not sure you would really be able to burn the grain if you filled it first. You might just end up burning th efiller and causing an uneven finish anyway.
    Here's one I just finished. Burned, then stained, then applied poly. You can feel the grain (which is what i wanted), but seeing how the poly smoothed it out some, it should be possible to get a smooth finish.
  3. big country
    big country TDPRI Member
    49
    Apr 20, 2010
    lake elsinore
    instead of burning it you could stain it using a very dark stain then sand the stain off in hopes that the grain will absorb stain deeper in the hard part of the wood
    different woods and grains, hardness and how deep they absorb will vary with species
    (oak color grain with ash figure)
    delicately color the stain just on the grain to limit the mass amount of sanding it takes to get the dark stain off the non grain part of the wood
  5. swla
    swla TDPRI Member
    27
    Feb 19, 2011
    Northridge, CA
    You could also use a dark grainfiller to simulate the burnt grain look
  6. Mongo Park
    Mongo Park Tele-Meister
    424
    Nov 28, 2010
    Winnipeg
    I would tend towards a heat gun than a blow torch, does not sound as cool but results are more controlable, nobody will know but your hairdresser, old joke.
    Cheers Ron
  7. swla
    swla TDPRI Member
    27
    Feb 19, 2011
    Northridge, CA
    Butane torch works really well
  8. barbrainy
    barbrainy RIP
    Mar 2, 2012
    Northampton, UK
    Can't post a link cos I'm on my phone, but if you search for a recent thread in this section, started by flyingbanana about a blue and black strat, you may change your mind about needing fire to achieve that result...
  9. Vizcaster
    Vizcaster Friend of Leo's
    Sep 15, 2007
    Glen Head, NY
    Yeah, I'm still puzzled where the "burnt" comes in. When Flyinbanana has demonstrated how it could (should) be done with tinted filler, I'm not sure why you'd be tempted to attempt something that's so much harder to control (like fire). When it's done you can call it anything you want (nuclear fallout for instance), it doesn't have to actually be "burnt."
  10. lookslikemeband
    lookslikemeband Tele-Holic
    558
    Apr 10, 2011
    CO - again
    I've tested this method with a heat gun and a mini torch..... the heat gun is a little more controlled... but keep in mind the resins in the wood crystalize and definitely effect the finishing...
  11. SixShooter
    SixShooter Friend of Leo's
    Sep 20, 2008
    Cincinnati
    Can you elaborate on this?
  12. Zillinois
    Zillinois Friend of Leo's
    Feb 25, 2009
    Seattle
    I haven't actually started on refinishing "Smokie" here, due to my lousy "work/life balance", but someone mentioned in a previous thread that I might want to burn the rest of the body to make it consistent before applying a nitro or poly cover.
  13. barbrainy
    barbrainy RIP
    Mar 2, 2012
    Northampton, UK
    Ah-hah! He's back!
    Remember, we mostly voted for 'leaving this guitar alone as it is'!! And I even offered to buy it off you as is. PLEASE PLEASE don't change it's finish. It is genuine and has a great story. It's unique. Leave it alone!!
    Having said that, it is your guitar....
  14. AussieAndrew
    AussieAndrew Friend of Leo's
    Nov 7, 2012
    Vic AU
    I 2nd that. That baby looks like it was rescued out of impending doom (a fire). If it were mine I'd be hap hap happy to play "as is" :)
  15. toddfan
    toddfan Tele-Holic
    890
    Dec 15, 2010
    USA, Midwest
    That is my quandry....I mostly hear that Swamp Ash would need grain filling,...but if I grain fill first, then "burn" (or, heat, etc.) the "fill" might pop out or consume....and if I burn first, then fill, I would just be covering the "burn".
    I appreciate all of the responses above....looks like I may have to get some scrap Swamp Ash to practice upon!
    I also realize that "it's only a name" and I could get a similar effect by using a dark grain filler, then sanding back before adding color....but, since the TDPRI is such a fantastic resource for experience of others whom have gone down that road before, I thought I would ask...just in case anyone else had some insight!
    BTW....if anyone else has some first hand experience with this process....PLEASE add to this thread!
    THANKS!
  16. toddfan
    toddfan Tele-Holic
    890
    Dec 15, 2010
    USA, Midwest
    This suggestion has the added benefit (for ME) of the fact that I already own a Heat Gun :!: So, this method will definitely get tried out.
